AE3 Battery Shield ================== The AE3 Battery Shield powers the :doc:`OpenMV AE3 ` from a wide range of supplies — 5–36 V, a 3.7 V Li‑Po cell, or 1.8–5.5 V for 3 alkaline cells in series — and adds an SPI microSD card socket on ``P0``–``P3``. All three power inputs land on JST terminals; the shield ships with a JST‑to‑pigtail adapter for the wide input and a JST‑to‑DC‑barrel‑jack adapter for the alkaline input. .. image:: ../ae3-battery-shield-hero.jpg :alt: AE3 Battery Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `AE3 Battery Shield product page `_. Highlights ---------- * **HV PWR** — 5–36 V, reverse‑voltage tolerant to −36 V. Powers the AE3 at **3.3 V** (up to 600 mA). * **BAT** — 3.7 V single‑cell Li‑Po. Powers the AE3 at **3.0 V** (up to 800 mA). The on‑board charger runs at a **100 mA charge current** whenever 3.3 V is available on the shield — supplied by USB, HV PWR, or 3.3 V fed to the AE3 through its Qwiic connector. A 6.25 hr safety timer caps the supported battery capacity at **625 mAh**. * **LV PWR** — 1.8–5.5 V for **3 alkaline cells in series**, reverse‑voltage tolerant to −5.5 V. Powers the AE3 at **3.0 V** (up to 800 mA). * **microSD card socket** wired to ``P0``–``P3`` over SPI, with a software‑controlled power switch on ``P11``. .. note:: The shield ships with a case that holds the AE3 firmly against the connector. Four corner **M1.6** mounting holes let you bolt the shield down to an enclosure or fixture. .. tip:: Use the :doc:`battery life estimator <../tutorial/battery_life>` to model how long the AE3 powered through this shield will run on a given battery for a given active / deep-sleep duty cycle. Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "microSD SPI **MOSI**" "P1", "microSD SPI **MISO**" "P2", "microSD SPI **SCLK**" "P3", "microSD SPI **CS**" "P6", "Charger **power‑good** (low when 3.3 V is present on the shield — USB, HV PWR, or Qwiic 3.3 V; charging only happens while this is low)" "P7", "Charger **charging** (low while the Li‑Po is being charged)" "P8", "Li‑Po battery voltage monitor — shield divides **0–5 V** down to **0–1.8 V** at the pin" "P9", "LV input voltage monitor — shield divides **0–6 V** down to **0–1.8 V** at the pin" "P11", "microSD **power enable** (drive high to power the card)" "HV PWR in", "5–36 V on a JST terminal (reverse‑voltage tolerant; JST‑to‑pigtail adapter included)" "BAT in", "3.7 V single‑cell Li‑Po on a JST terminal" "LV PWR in", "1.8–5.5 V on a JST terminal for 3 alkaline cells in series (reverse‑voltage tolerant; JST‑to‑DC‑barrel‑jack adapter included)" "3.3V rail", "Powers the AE3 and the shield's on‑board electronics" "GND rail", "Common ground" Usage ----- Plug an AE3 onto the shield and connect any one of the three power inputs — the shield ORs the rails internally and feeds the AE3 from whichever source is present. .. note:: With only ``BAT`` connected (no USB, HV PWR, or Qwiic 3.3 V feeding the shield), the AE3 runs at 3.0 V off the Li‑Po, the charger is idle, and both status LEDs are off. The microSD socket is exposed on the AE3's SPI bus through :class:`machine.SPI` and the standard ``sdcard`` driver. Drive ``P11`` high to power the card, then wrap the block device in a ``VfsFat`` and mount it at ``/sdcard``:: import os import machine import sdcard machine.Pin("P11", machine.Pin.OUT, value=1) # enable card power spi = machine.SPI(0) cs = machine.Pin("P3", machine.Pin.OUT, value=1) sd = sdcard.SDCard(spi, cs, baudrate=20_000_000) os.mount(os.VfsFat(sd), "/sdcard") print(os.listdir("/sdcard")) Watch the charger status by reading its two status pins. ``P6`` (power‑good) goes low as soon as 3.3 V is present on the shield — from USB, HV PWR, or 3.3 V fed back through the AE3's Qwiic — which is also when the charger is allowed to run. ``P7`` (charging) goes low while the Li‑Po is actually being charged. Both pins also drive on‑board status LEDs — ``P6`` lights a **green** LED, ``P7`` lights a **red** LED:: from machine import Pin pg = Pin("P6", Pin.IN, Pin.PULL_UP) chg = Pin("P7", Pin.IN, Pin.PULL_UP) if not pg.value(): print("Charger powered") if not chg.value(): print("Battery charging") else: print("Battery full or no battery") else: print("Running off battery only") Monitor the Li‑Po battery and LV input voltages on ``P8`` and ``P9``. The shield divides each supply down to the AE3's 1.8 V ADC range, so scale the reading back up by the input's full‑scale range:: from machine import ADC import time lipo = ADC("P8") # 0–5 V at the input lv = ADC("P9") # 0–6 V at the input while True: # 0–1.8 V at the pin → 0–5 V on the battery rail vbat = lipo.read_u16() * 1.8 / 65535 * (5.0 / 1.8) # 0–1.8 V at the pin → 0–6 V on the LV rail vlv = lv.read_u16() * 1.8 / 65535 * (6.0 / 1.8) print("Li‑Po:", vbat, "V LV:", vlv, "V") time.sleep_ms(500)
