AE3 OLED Breakout ================= The AE3 OLED Breakout pairs the :doc:`OpenMV AE3 ` with a 128 × 128 RGB OLED, a 5‑way joystick, and a 10‑pin ARM SWD header for stand‑alone preview, simple input, and JTAG/SWD debug. .. image:: ../ae3-oled-breakout-hero.jpg :alt: AE3 OLED Breakout :width: 400px :align: center For full datasheet, photos, and ordering see the `AE3 OLED Breakout product page `_. Highlights ---------- * **128 × 128 RGB OLED** driven by an **SSD1351** controller over SPI. * **AS90R 5‑way joystick** with a centre push button, exposed on the ``P4``/``P5`` I²C bus. * **Reset button** and **recovery switch** for secure‑enclave UART access. * **OLED disconnect switch** to electrically remove the panel from the SPI bus. * Two **Qwiic** connectors on the same ``P4``/``P5`` I²C bus. * **ARM 10‑pin Cortex Debug** header for SWD/JTAG debugging. * Four ground hook test points. .. note:: Four corner **M1.6** mounting holes let you bolt the breakout down to an enclosure or fixture. Pin reference ------------- All AE3 signals on the breakout are taken from the **B2B header on the bottom of the AE3** and brought out to two side pin headers — ``P0``–``P5`` on one side, ``P6``–``P9`` on the other — both **3.3 V referenced**. The full alt function list for each pin lives on the :doc:`OpenMV AE3 ` page; the breakout uses the pins as follows: .. csv-table:: :header: "Pin", "Reference", "AE3 features", "Breakout use" :widths: 8, 10, 42, 40 "P0", "3.3 V", "SPI0 MOSI / I2C2 SCL / UART4 TX / TIM0 T1 / PDM D3", "OLED SPI **MOSI**" "P1", "3.3 V", "SPI0 MISO / I2C2 SDA / UART4 RX / TIM0 T0", "free" "P2", "3.3 V", "SPI0 SCLK / LPI2C SDA / UART5 TX / TIM1 T1", "OLED SPI **SCLK**" "P3", "3.3 V", "SPI0 SS / LPI2C SCL / UART5 RX / TIM1 T0 / PDM C3", "OLED SPI **CS**" "P4", "3.3 V", "I2C1 SCL / UART1 TX / TIM2 T1 / PDM C0 / CAN TX", "Joystick / Qwiic **I²C SCL**" "P5", "3.3 V", "I2C1 SDA / UART1 RX / TIM2 T0 / PDM D0 / CAN RX", "Joystick / Qwiic **I²C SDA**" "RESET", "3.3 V", "NRST", "Press the on‑board RESET button or pull to GND to reset the AE3" "P6", "3.3 V", "I2C1 SDA / UART3 CTS / TIM9 T0", "free" "P7", "3.3 V", "I2C1 SCL / UART3 RTS / TIM9 T1", "OLED **RESET**" "P8", "3.3 V", "I3C SDA / UART3 RX / TIM5 T0 / ADC ch S10", "OLED **DC** (register select)" "P9", "3.3 V", "I3C SCL / UART3 TX / TIM5 T1 / ADC ch S11", "Joystick **IRQ** (active low on state change)" "3.3V rail", "—", "—", "Powers the OLED, joystick expander, and Qwiic devices" "GND rail", "—", "—", "Common ground" .. note:: The **recovery switch** flips an internal USB mux on the AE3: the AE3's own USB pins are disconnected from the USB‑C port, and a USB‑to‑serial converter on the secure‑enclave UART is connected to the port in their place. With the switch engaged, host‑side Alif tools can talk to the secure enclave to reprogram the AE3's bootloader. Leave the switch **disabled** for normal operation so the USB‑C port acts as the AE3's USB. .. note:: The **OLED enable switch** has to be on for the OLED to work — it gates power to the panel and connects the OLED control pins (``P0``, ``P2``, ``P3``, ``P7``, ``P8``) through to the AE3's GPIO. With the switch off only ``P4``, ``P5``, and ``P9`` stay wired through. The current switch state shows up on the joystick expander as bit ``0x40`` — the raw expander pin reads **low when the switch is enabled**. Qwiic headers ------------- Two **Qwiic** 4‑pin JST‑SH 1.0 mm connectors sit on the breakout and share the same ``P4``/``P5`` I²C bus as the on‑board joystick expander, so additional Qwiic devices must avoid the joystick expander's address (``0x63``). .. csv-table:: :header: "Pin", "Signal" :widths: 12, 88 "1", "GND" "2", "+3.3 V" "3", "SDA (``P5``)" "4", "SCL (``P4``)" JTAG header ----------- The 10‑pin 1.27 mm ARM Cortex Debug header on the breakout is wired straight to the AE3's SWD/JTAG lines. All signals are **1.8 V referenced** — use a level‑shifting probe or one whose target voltage tracks ``VCC_REF`` (pin 1). .. csv-table:: :header: "Pin", "Signal" :widths: 12, 88 "1", "VCC_REF (+1.8 V)" "2", "TMS (SWDIO)" "3", "+1.8 V" "4", "TCK (SWCLK)" "5", "GND" "6", "TDO (SWO)" "7", "key (no pin)" "8", "TDI" "9", "GND" "10", "DEBUG_RST_N (JTAG/debug reset — separate from the system NRST)" Usage ----- Drive the OLED through :class:`display.SPIDisplay` with an :class:`SSD1351 ` controller instance. Stream camera frames to the 128 × 128 panel:: import csi import time import display import image csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.VGA) csi0.window((400, 400)) lcd = display.SPIDisplay(width=128, height=128, controller=display.SSD1351()) clock = time.clock() while True: clock.tick() lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps()) Read the 5‑way joystick through the frozen :class:`pca9674a.PCA9674A` driver. The expander asserts ``P9`` on state changes, so wire an IRQ callback that latches the new button state. The buttons are active‑low on the expander; the code below XORs the read with ``0xFF`` so a set bit in ``state`` means *pressed*: .. csv-table:: :header: "Bit", "Direction" :widths: 20, 80 "``0x01``", "Joystick right" "``0x02``", "Joystick up" "``0x04``", "Joystick left" "``0x08``", "Joystick down" "``0x10``", "Joystick centre push" "``0x40``", "OLED enable switch (set in ``state`` when the OLED is enabled)" :: import csi import time import display from pca9674a import PCA9674A from machine import I2C csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.VGA) csi0.window((400, 400)) lcd = display.SPIDisplay(width=128, height=128, controller=display.SSD1351()) clock = time.clock() state = 0 cursor_x = 0 cursor_y = 0 def read_expander(pin): global exp, state # Buttons are active‑low on the expander; XOR for active‑high bits. state = exp.read() ^ 0xFF exp = PCA9674A(I2C(1), irq_pin="P9", callback=read_expander) def update_cursor(): global cursor_x, cursor_y if state & 0x01: cursor_x += 2 # Right if state & 0x02: cursor_y -= 2 # Up if state & 0x04: cursor_x -= 2 # Left if state & 0x08: cursor_y += 2 # Down if state & 0x10: # Centre cursor_x = 0 cursor_y = 0 while True: clock.tick() update_cursor() lcd.write(csi0.snapshot(), x=cursor_x, y=cursor_y, x_scale=128 / 400, y_scale=128 / 400) print(clock.fps())
