Battery Shield ============== The Battery Shield powers OpenMV Cams from a 1.8-5.5 V source through a 2.1 mm DC barrel jack, making it ideal for alkaline-battery deployments. It also accepts a wide 6-36 V input with reverse-voltage protection. .. image:: ../battery-shield-hero.jpg :alt: Battery Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Battery Shield product page `_. Highlights ---------- * 1.8-5.5 V DC barrel jack input for battery deployments * 6-36 V wide input with reverse-voltage and surge protection * 0-6 V ADC input on P6 for monitoring the DC barrel jack voltage .. tip:: Use the :doc:`battery life estimator <../tutorial/battery_life>` to model how long an OpenMV Cam powered through this shield will run on a given battery for a given active / deep-sleep duty cycle. Pinout ------ .. image:: ../pinout-battery-shield.png :alt: Battery Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P6", "0–6 V ADC input (level-shifted to 0–2.8 V on P6) for monitoring the DC barrel jack voltage" "BARREL in", "1.8–5.5 V input on the DC barrel jack" "PWR in", "6–36 V wide input on the terminal block (reverse-voltage tolerant)" "RAW out", "3.5 V at up to 800 mA — direct from the barrel jack" "VIN out", "5.6 V at up to 600 mA — regulated from the wide input via OR'ing diode" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: The barrel-jack voltage divider feeds P6 through a 0-ohm resistor on the back of the shield. Remove the resistor to free P6 for unrelated use. .. note:: A single 0-ohm resistor on the back of the shield selects whether the DC barrel jack feeds RAW out (default) or VIN out — move the resistor to the other pad pair to switch. Useful for legacy OpenMV Cams that take their power on VIN rather than RAW. Usage ----- Read the DC barrel jack voltage on P6 (the shield level-shifts 0–6 V down to 0–2.8 V before driving the pin):: from machine import ADC import time barrel = ADC("P6") while True: # 0–6 V on the input scaled to 0–2.8 V on P6 v = barrel.read_u16() * 2.8 / 65535 print("Barrel jack:", v * (6.0 / 2.8), "V") time.sleep_ms(500)
