CAN Shield ========== The CAN Shield gives the OpenMV Cam a CAN-bus link via a DB9 connector, with an on-board 12 V to 5 V regulator so the shield can power the camera from a vehicle bus. .. image:: ../can-shield-hero.jpg :alt: CAN Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `CAN Shield product page `_. .. note:: Not supported on the OpenMV Cam RT1062. Highlights ---------- * CAN bus up to 1 Mb/s * On-board 12 V to 5 V regulator Pinout ------ .. image:: ../pinout-can-shield.png :alt: CAN Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P2", "CAN TX" "P3", "CAN RX" "P6", "CAN standby (optional — see note)" "PWR in", "12 V vehicle-bus input on the DB9 connector" "VIN out", "5 V regulator output (powers the camera)" "3.3V rail", "Powers the SN65HVD230 logic" "GND rail", "Common ground" .. note:: The SN65HVD230's standby line is disconnected from P6 by default. Connect the on-board solder bridge to tie it to P6, then drive P6 high to put the transceiver into listen-only standby mode (low keeps it in normal transmit-and-receive mode). .. note:: CANL, CANH, VIN, and GND from the DB9 connector are also broken out to through-hole pads on the bottom of the shield — solder wires there if you want to skip the DB9 entirely. .. note:: The DB9 pinout can be changed between the standard DB9 CAN layout and the OBD-II layout by changing the three solder-bridge jumpers on the bottom of the shield. .. note:: The on-board 120-ohm termination resistor is connected by default. It can be disabled via a solder bridge on the bottom of the shield for buses that already have termination elsewhere. Usage ----- .. note:: The ``CAN(1)`` peripheral number below follows the STM32 mapping. On another processor the bus wired to these pins may be different — check your board's reference. Send and receive frames on the CAN bus at 1 Mb/s:: from machine import CAN import time can = CAN(1, 1_000_000) can.send([0xDE, 0xAD, 0xBE, 0xEF], 0x123) print(can.recv()) With the on-board solder bridge connected, drive P6 high to put the SN65HVD230 into listen-only standby mode (low returns it to normal transmit-and-receive):: from machine import Pin Pin("P6", Pin.OUT).value(1) # listen-only standby
