Driver Shield ============= The Driver Shield runs two 3 A motors or four independent 1.5 A line drivers from a wide 6-36 V supply, giving the OpenMV Cam a rugged motor-control front-end with reverse-voltage and surge protection. .. image:: ../driver-shield-hero.jpg :alt: Driver Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Driver Shield product page `_. Highlights ---------- * Dual 3 A motor drivers OR quad 1.5 A line drivers, 6-36 V * Reverse-voltage and transient-surge protection on the input * 0-5 V ADC input with ±36 V overvoltage protection * 0-5 V digital I/O for camera-sync triggers, short-circuit protected Pinout ------ .. image:: ../pinout-driver-shield.png :alt: Driver Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "DIR for output pair O1/O2" "P1", "DIR for output pair O3/O4 (alternative)" "P2", "DIR for output pair O3/O4 (default)" "P6", "Level-shifted AIN readback (0–3.3 V on P6)" "P7", "PWM for output pair O1/O2" "P8", "PWM for output pair O3/O4" "P10", "SYN — open-drain digital I/O on the terminal block" "PWR in", "6–36 V wide input on the terminal block (reverse-voltage tolerant)" "AIN in", "Analog input on the terminal block" "VIN out", "5.4 V at up to 600 mA from the on-board regulator" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: AIN is overvoltage-protected up to ±36 V and defaults to a 0–5 V voltage input, scaled down to 0–3.3 V on P6. Bridge the 4–20 mA mode shunt on the front of the shield to switch AIN to a 4–20 mA current-loop input. .. note:: SYN is an open-drain digital line, pulled up to 3.3 V on the camera side and 5 V on the SYN terminal side. By default it's an input — the shield level-shifts 0–5 V on SYN down to 0–3.3 V on P10. Change the on-board solder jumper to flip P10 into an output, level-shifting 0–3.3 V on P10 up to 0–5 V on SYN. .. note:: Each of P0, P1, P2, P6, P7, P8, and P10 can be reclaimed for unrelated use. P0, P2, P6, P7, P8, and P10 are connected by default through back-side solder jumpers — open the jumper on any pin you want to free. P1 defaults to disconnected: bridge its front-side jumper to route DIR for O3/O4 to P1 instead (and open P2's back-side jumper to release P2). .. note:: Two mode jumpers on the back of the shield — one per H-bridge — independently set each output pair into one of three modes. Each jumper has L and H markings to show which side selects which state: * **Low (default)** — DIR/PWM mode: one DIR pin + one PWM pin per bridge. * **High** — H-bridge mode: both pins drive the bridge directly via the chip's two-input truth table. * **Float (no connect)** — independent mode: each pin becomes a stand-alone line driver routed to one output. Each DRV8876 is current-limited to 3 A total per chip — that's 3 A through one bridge (DIR/PWM or H-bridge mode) or 1.5 A per output split across the two outputs (independent mode). Usage ----- DIR/PWM mode (default) ~~~~~~~~~~~~~~~~~~~~~~ Drive a brushed DC motor on output pair O1/O2 — set direction on P0 and apply a PWM speed signal on P7. The loop below ramps the duty cycle up to full speed and back down, then flips direction and repeats:: from machine import Pin, PWM import time direction = Pin("P0", Pin.OUT) speed = PWM(Pin("P7"), freq=20_000, duty_u16=0) def ramp(target): for duty in range(0, target, 1024): speed.duty_u16(duty) time.sleep_ms(10) for duty in range(target, -1, -1024): speed.duty_u16(duty) time.sleep_ms(10) while True: direction.value(1) # forward ramp(65_535) direction.value(0) # reverse ramp(65_535) The two H-bridges can also drive a bipolar stepper — hold both PWM channels at full drive and step the DIR pins through the four-phase sequence:: from machine import Pin, PWM import time dir12 = Pin("P0", Pin.OUT) dir34 = Pin("P2", Pin.OUT) PWM(Pin("P7"), freq=20_000, duty_u16=65_535) # full drive on O1/O2 PWM(Pin("P8"), freq=20_000, duty_u16=65_535) # full drive on O3/O4 SEQUENCE = [(1, 1), (0, 1), (0, 0), (1, 0)] def step(forward=True): for a, b in SEQUENCE if forward else reversed(SEQUENCE): dir12.value(a) dir34.value(b) time.sleep_ms(5) while True: for _ in range(50): # ~1 revolution forward (200 phases) step() for _ in range(50): # ~1 revolution backward step(forward=False) H-bridge mode ~~~~~~~~~~~~~ With the mode jumper set high, both bridge pins drive the H-bridge directly. For O1/O2 the truth table is: * ``(P0, P7) = (L, L)`` → coast (outputs Hi-Z) * ``(P0, P7) = (L, H)`` → forward (O1 = H, O2 = L) * ``(P0, P7) = (H, L)`` → reverse (O1 = L, O2 = H) * ``(P0, P7) = (H, H)`` → brake (outputs both low) (O3/O4 follows the same table with P1/P2 and P8.) The loop below cycles a motor through forward → brake → reverse → coast on output pair O1/O2:: from machine import Pin import time p0 = Pin("P0", Pin.OUT) p7 = Pin("P7", Pin.OUT) def drive(a, b): p0.value(a) p7.value(b) while True: drive(0, 1) # forward time.sleep(1) drive(1, 1) # brake time.sleep_ms(500) drive(1, 0) # reverse time.sleep(1) drive(0, 0) # coast time.sleep_ms(500) Either pin can be swapped for a :class:`machine.PWM` channel for proportional drive — e.g. ``(P0=0, P7=PWM)`` gives forward/coast at the PWM duty, ``(P0=1, P7=PWM)`` gives reverse/brake at ``(100 % − duty)``. The loop below ramps the duty up and back down with P0 held at 0 (forward/coast):: from machine import Pin, PWM import time p0 = Pin("P0", Pin.OUT, value=0) p7 = PWM(Pin("P7"), freq=20_000, duty_u16=0) while True: for duty in range(0, 65_536, 1024): p7.duty_u16(duty) time.sleep_ms(10) for duty in range(65_535, -1, -1024): p7.duty_u16(duty) time.sleep_ms(10) Independent mode ~~~~~~~~~~~~~~~~ With the mode jumper floating, each pin becomes a stand-alone line driver routed to one output — useful for solenoids, relays, or any on/off load that doesn't need an H-bridge. The mapping is P7 → O1, P0 → O2, P8 → O3, and P1 (or P2) → O4:: from machine import Pin import time outputs = [ Pin("P7", Pin.OUT), # O1 Pin("P0", Pin.OUT), # O2 Pin("P8", Pin.OUT), # O3 Pin("P2", Pin.OUT), # O4 ] while True: for o in outputs: # walk a single high pulse across O1–O4 o.value(1) time.sleep_ms(200) o.value(0) Any of the four pins can also be PWM'd via :class:`machine.PWM` for proportional drive — for example, fade each output up and down in turn:: from machine import Pin, PWM import time outputs = [ PWM(Pin("P7"), freq=1_000, duty_u16=0), # O1 PWM(Pin("P0"), freq=1_000, duty_u16=0), # O2 PWM(Pin("P8"), freq=1_000, duty_u16=0), # O3 PWM(Pin("P2"), freq=1_000, duty_u16=0), # O4 ] while True: for o in outputs: for duty in range(0, 65_536, 1024): o.duty_u16(duty) time.sleep_ms(5) for duty in range(65_535, -1, -1024): o.duty_u16(duty) time.sleep_ms(5) Other I/O ~~~~~~~~~ Read the AIN terminal-block input through the level-shifted P6 pin:: from machine import ADC import time ain = ADC("P6") while True: v = ain.read_u16() * 3.3 / 65535 print("AIN:", v * (5.0 / 3.3), "V") time.sleep_ms(100) React to a falling edge on the SYN line — for example, to sync the camera with another device pulling SYN low:: from machine import Pin def on_sync(pin): print("SYN falling edge") syn = Pin("P10", Pin.IN) syn.irq(on_sync, Pin.IRQ_FALLING)
