Gigabit PoE Shield ================== The Gigabit PoE Shield is a 10/100/1000 Mb/s Ethernet shield with 802.3af Power-over-Ethernet for OpenMV Cams that have an on-board Ethernet PHY. One cable to a PoE switch carries both power and the network link. .. image:: ../gigabit-poe-shield-hero.jpg :alt: Gigabit PoE Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Gigabit PoE Shield product page `_. .. note:: Supported only on the OpenMV Cam RT1062 and N6. Highlights ---------- * 10/100/1000 Mb/s Gigabit Ethernet with IEEE 802.3af PoE * Up to ~6 W to the camera via 5.6 V VIN * 1500 V isolated design — stacks with dual-header shields via on-board OR'ing diode Pinout ------ .. image:: ../pinout-gigabit-poe-shield.png :alt: Gigabit PoE Shield Pinout :width: 700px Pin reference ------------- 10/100 Mb/s only uses the MDI TX and MDI RX pairs (Pairs A and B). Gigabit (1000BASE-T) is bidirectional on all four pairs A/B/C/D, so the MDI TX ± and MDI RX ± lines double as Pair A and Pair B at gigabit speeds, and Pairs C and D carry the additional gigabit-only pairs. .. csv-table:: :header: "Pin", "Function" :widths: 22, 78 "MDI LED", "PHY link / activity LED line" "MDI TX P / DA P", "Pair A positive — MDI TX+ at 10/100, BI_DA+ at gigabit" "MDI TX N / DA N", "Pair A negative — MDI TX− at 10/100, BI_DA− at gigabit" "MDI RX P / DB P", "Pair B positive — MDI RX+ at 10/100, BI_DB+ at gigabit" "MDI RX N / DB N", "Pair B negative — MDI RX− at 10/100, BI_DB− at gigabit" "DC P", "Pair C positive (BI_DC+) — gigabit only" "DC N", "Pair C negative (BI_DC−) — gigabit only" "DD P", "Pair D positive (BI_DD+) — gigabit only" "DD N", "Pair D negative (BI_DD−) — gigabit only" "VIN out", "5.6 V at up to ~1 A from the on-board PoE regulator (powers the camera)" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: The DC and DD pairs are tied to the camera through 0-ohm resistors on the back of the shield. Remove them to free P15–P18 (the gigabit-only pins on cams like the OpenMV N6) for unrelated use — the shield then drops to 10/100 Ethernet since the gigabit pairs are no longer connected. Usage ----- When the shield is connected to a PoE switch, the camera's gigabit PHY appears as a :class:`network.LAN` interface. DHCP runs automatically once the link comes up:: import network import time lan = network.LAN() lan.active(True) while not lan.isconnected(): time.sleep(1) print("Ethernet IP:", lan.ipconfig("addr4")[0])
