LCD Shield ========== The LCD Shield is a 1.8 inch 128x160 SPI TFT for showing live frames or debugging information directly from the OpenMV Cam. Ideal for field robotics and stand-alone deployments. .. image:: ../lcd-shield-hero.jpg :alt: LCD Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `LCD Shield product page `_. Highlights ---------- * 1.8 inch TFT LCD, 128x160, RGB565 * Controllable backlight Pinout ------ .. image:: ../pinout-lcd-shield.png :alt: LCD Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "SPI MOSI — data out to the LCD" "P2", "SPI clock" "P3", "SPI chip select" "P5", "Backlight control" "P7", "LCD reset" "P8", "SPI command (data / command select)" "3.3V rail", "Powers the LCD" "GND rail", "Common ground" .. note:: Cut the solder trace on the back of the shield to disconnect P5 from the backlight; the backlight is then permanently on. Usage ----- Stream camera frames to the 128×160 SPI display:: import csi import display import image import time csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize((128, 160)) lcd = display.SPIDisplay() clock = time.clock() while True: clock.tick() lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps()) Drive the backlight via PWM for adjustable brightness. Wrap :class:`machine.PWM` in a small backlight controller class and pass it to :class:`display.SPIDisplay` through its ``backlight`` argument — :class:`~display.SPIDisplay` calls ``backlight(value)`` on the object whenever it needs to update the level:: import csi import time import display import image from machine import Pin, PWM class PWMBacklight: """Drives a backlight pin with machine.PWM (0–100 %).""" def __init__(self, pin, frequency=200): self._pwm = PWM(Pin(pin), freq=frequency, duty_u16=0) def backlight(self, value): self._pwm.duty_u16(int(value * 65535 / 100)) def deinit(self): self._pwm.deinit() csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize((128, 160)) lcd = display.SPIDisplay(backlight=PWMBacklight("P5")) lcd.backlight(50) # 0–100 clock = time.clock() while True: clock.tick() lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps())
