Pan and Tilt Shield =================== The Pan and Tilt Shield gives the OpenMV Cam three servo channels with an NCP1117 5 V linear regulator that powers both the camera and the servos from a single 6.5–18 V battery input. .. image:: ../pan-tilt-shield-hero.jpg :alt: Pan and Tilt Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Pan and Tilt Shield product page `_. Highlights ---------- * Three independent servo channels * Stacks with the Servo Shield Pinout ------ .. image:: ../pinout-pan-tilt-shield.png :alt: Pan and Tilt Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P7", "Servo 0 (S0)" "P8", "Servo 1 (S1)" "P9", "Servo 2 (S2)" "VBAT in", "6.5–18 V battery input on the screw terminal (NCP1117 limits)" "VIN out", "5 V regulated from the on-board NCP1117 — powers both the camera and the servo rail" "GND rail", "Servo and camera common ground" Usage ----- Drive the three servo channels with 50 Hz PWM. The pulse-width range varies between servos, so tune ``MIN_US`` and ``MAX_US`` to match yours — typical values are around 1000–2000 µs:: from machine import Pin, PWM import time MIN_US = 1000 # full-left pulse width (microseconds) MAX_US = 2000 # full-right pulse width pan = PWM(Pin("P7"), freq=50) # S0 tilt = PWM(Pin("P8"), freq=50) # S1 aux = PWM(Pin("P9"), freq=50) # S2 def angle(servo, deg): pulse_us = MIN_US + (deg * (MAX_US - MIN_US)) // 180 servo.duty_ns(pulse_us * 1000) while True: angle(pan, 0) angle(tilt, 90) time.sleep(1) angle(pan, 180) angle(tilt, 45) time.sleep(1)
