PIR Shield ========== The PIR Shield wakes the OpenMV Cam from deep sleep on motion, draws an ultra-low 6 µA in standby, and adds eight white plus eight 850 nm infrared LEDs for illumination. Ideal for battery-powered surveillance and trail cameras. .. image:: ../pir-shield-hero.jpg :alt: PIR Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `PIR Shield product page `_. Highlights ---------- * 6 µA standby PIR sensor for years of battery operation * Eight 3500 K white LEDs and eight 850 nm IR LEDs (PWM-dimmable) Pinout ------ .. image:: ../pinout-pir-shield.png :alt: PIR Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P7", "PWM control for the white LEDs" "P8", "PWM control for the 850 nm IR LEDs" "P9", "Wakeup (alternative)" "P11", "Wakeup (default) — pulls low when the PIR detects motion" "RAW rail", "Always-on power for the PIR sensor — keeps motion detection alive while the camera is in deep sleep" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: Each of P7, P8, P9, and P11 can be reclaimed for unrelated use. P7, P8, and P11 are connected by default through back-side solder jumpers — open the jumper on any pin you want to free. P9 defaults to disconnected: bridge its back-side jumper to route the wakeup signal to P9 instead (and open P11's back-side jumper to release P11). .. note:: P11 is the wakeup pin on all modern OpenMV Cams — leave the shield on its default mapping for ``deepsleep()`` motion wake. The P9 alternative exists for legacy OpenMV Cams, which don't have a dedicated wakeup line — P9 lands on a regular GPIO that you'd poll or attach an IRQ to instead. Usage ----- PWM-dim the white and IR illumination LEDs:: from machine import PWM, Pin white = PWM(Pin("P7"), freq=50_000, duty_u16=0) ir = PWM(Pin("P8"), freq=50_000, duty_u16=0) white.duty_u16(32_768) # 50% white ir.duty_u16(16_384) # 25% IR Wake the camera from deep sleep on motion. P11 (the default wakeup line) pulls low when the PIR triggers and resets the camera:: from machine import deepsleep deepsleep() # the next motion event resets the camera
