PoE Shield ========== The PoE Shield adds 802.3af Power-over-Ethernet to OpenMV Cams that have an on-board Ethernet PHY — one cable to a PoE switch carries both power and the network link. .. image:: ../poe-shield-hero.jpg :alt: PoE Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `PoE Shield product page `_. .. note:: Supported only on the OpenMV Cam RT1062 and N6. Highlights ---------- * 10/100 Mb/s Ethernet with IEEE 802.3af PoE * Up to 5.67 W to the camera via 5.4 V VIN * 1500 V isolated design — stacks with dual-header shields Pinout ------ .. image:: ../pinout-poe-shield.png :alt: PoE Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 22, 78 "MDI LED", "PHY link / activity LED line" "MDI TX P", "MDI TX+ — transmit pair positive" "MDI TX N", "MDI TX− — transmit pair negative" "MDI RX P", "MDI RX+ — receive pair positive" "MDI RX N", "MDI RX− — receive pair negative" "VIN out", "5.4 V at up to ~1 A from the on-board PoE regulator (powers the camera)" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" Usage ----- When the shield is connected to a PoE switch, the camera's 10/100 Ethernet PHY appears as a :class:`network.LAN` interface. DHCP runs automatically once the link comes up:: import network import time lan = network.LAN() lan.active(True) while not lan.isconnected(): time.sleep(1) print("Ethernet IP:", lan.ipconfig("addr4")[0])
