QWIIC Shield ============ The QWIIC Shield gives the OpenMV Cam two daisy-chainable Qwiic (JST-SH 4-pin) connectors wired to its I2C pins, so SparkFun Qwiic ecosystem boards can plug straight in. .. image:: ../qwiic-shield-hero.jpg :alt: QWIIC Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `QWIIC Shield product page `_. Highlights ---------- * Two Qwiic JST-SH connectors for daisy-chaining I2C peripherals * Routes the OpenMV Cam's P4 (SCL) and P5 (SDA) pins * Compatible with the SparkFun Qwiic ecosystem * No on-board pull-ups (use software pull-ups or external) Pinout ------ .. image:: ../pinout-qwiic-shield.png :alt: QWIIC Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P4", "Qwiic SCL — I²C clock to both Qwiic connectors" "P5", "Qwiic SDA — I²C data to both Qwiic connectors" "3.3V rail", "Powers connected Qwiic devices" "GND rail", "Common ground (also routed to both Qwiic connectors)" Usage ----- Scan for connected Qwiic devices on the I²C bus. The shield does not fit pull-up resistors on board — enable internal pull-ups in software, or rely on pull-ups built into the connected Qwiic boards:: from machine import Pin, SoftI2C bus = SoftI2C(scl=Pin("P4", Pin.OPEN_DRAIN, Pin.PULL_UP), sda=Pin("P5", Pin.OPEN_DRAIN, Pin.PULL_UP), freq=100_000) print("Qwiic devices:", [hex(addr) for addr in bus.scan()])
