Relay Shield ============ The Relay Shield switches two high-power AC or DC loads up to 60 W per relay from the OpenMV Cam, with a 6-36 V input plus an ADC input and a digital I/O line for sync. .. image:: ../relay-shield-hero.jpg :alt: Relay Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Relay Shield product page `_. Highlights ---------- * Dual relays — 60 W each (15-220 V DC, 125-260 V AC) * 6-36 V input with reverse-voltage tolerance * 0-5 V ADC input with ±36 V overvoltage protection * 0-5 V digital I/O for camera-sync triggers Pinout ------ .. image:: ../pinout-relay-shield.png :alt: Relay Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "Relay 1 control" "P1", "Relay 2 control (alternative)" "P2", "Relay 2 control (default)" "P6", "Level-shifted AIN readback (0–3.3 V on P6)" "P10", "SYN — open-drain digital I/O on the terminal block" "PWR in", "6–36 V wide input on the terminal block (reverse-voltage tolerant)" "AIN in", "Analog input on the terminal block" "VIN out", "5.4 V at up to 600 mA from the on-board regulator" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: AIN is overvoltage-protected up to ±36 V and defaults to a 0–5 V voltage input, scaled down to 0–3.3 V on P6. Bridge the 4–20 mA mode shunt on the front of the shield to switch AIN to a 4–20 mA current-loop input. .. note:: SYN is an open-drain digital line, pulled up to 3.3 V on the camera side and 5 V on the SYN terminal side. By default it's an input — the shield level-shifts 0–5 V on SYN down to 0–3.3 V on P10. Change the on-board solder jumper to flip P10 into an output, level-shifting 0–3.3 V on P10 up to 0–5 V on SYN. .. note:: Each of P0, P1, P2, P6, and P10 can be reclaimed for unrelated use. P0, P2, P6, and P10 are connected by default through back-side solder jumpers — open the jumper on any pin you want to free. P1 defaults to disconnected: bridge its front-side jumper to route Relay 2 to P1 instead (and open P2's back-side jumper to release P2). .. note:: The relays default to normally-open (NO). Solder bridges on the bottom of the shield switch them to normally-closed (NC). Usage ----- Toggle the two relays from P0 and P1:: from machine import Pin import time relay1 = Pin("P0", Pin.OUT) relay2 = Pin("P1", Pin.OUT) while True: relay1.on() relay2.off() time.sleep(1) relay1.off() relay2.on() time.sleep(1) Read the AIN terminal-block input through the level-shifted P6 pin:: from machine import ADC import time ain = ADC("P6") while True: v = ain.read_u16() * 3.3 / 65535 print("AIN:", v * (5.0 / 3.3), "V") time.sleep_ms(100) React to a falling edge on the SYN line — for example, to sync the camera with another device pulling SYN low:: from machine import Pin def on_sync(pin): print("SYN falling edge") syn = Pin("P10", Pin.IN) syn.irq(on_sync, Pin.IRQ_FALLING)
