RS422/RS485 Shield ================== The RS422/RS485 Shield gives the OpenMV Cam a long-distance differential serial link suited to industrial buses, with wide-input power, surge protection, and ADC/digital I/O. .. image:: ../rs422-rs485-shield-hero.jpg :alt: RS422/RS485 Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `RS422/RS485 Shield product page `_. Highlights ---------- * 10 Mb/s RS-422 or RS-485 with on-board termination * 6-36 V input, reverse-voltage tolerant * 0-5 V ADC input with ±36 V overvoltage protection * 0-5 V digital I/O for camera-sync triggers, short-circuit protected Pinout ------ .. image:: ../pinout-rs422-rs485-shield.png :alt: RS422/RS485 Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P4", "RS-422 / RS-485 TX → drives the differential line out" "P5", "RS-422 / RS-485 RX ← receives differential line in" "P6", "Level-shifted AIN readback (0–3.3 V on P6)" "P10", "SYN — open-drain digital I/O on the terminal block" "PWR in", "6–36 V wide input on the terminal block (reverse-voltage tolerant)" "AIN in", "Analog input on the terminal block" "VIN out", "5.4 V at up to 600 mA from the on-board regulator" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: AIN is overvoltage-protected up to ±36 V and defaults to a 0–5 V voltage input, scaled down to 0–3.3 V on P6. Bridge the 4–20 mA mode shunt on the front of the shield to switch AIN to a 4–20 mA current-loop input. .. note:: SYN is an open-drain digital line, pulled up to 3.3 V on the camera side and 5 V on the SYN terminal side. By default it's an input — the shield level-shifts 0–5 V on SYN down to 0–3.3 V on P10. Change the on-board solder jumper to flip P10 into an output, level-shifting 0–3.3 V on P10 up to 0–5 V on SYN. .. note:: Each of P4, P5, P6, and P10 is connected to the camera by default through a solder jumper — open the jumper on any pin you want to reclaim for unrelated use. P6's jumper is on the back of the shield; P4, P5, and P10 are on the front. .. note:: The on-board termination resistors are connected by default — open the corresponding back-side solder jumpers to disconnect them. Two cover the RS-422 A/B pair and two cover the RS-422 Y/Z pair (which doubles as the RS-485 A/B termination), four jumpers in total. .. rubric:: About RS-422 and RS-485 Both standards send serial data as a balanced (differential) signal over twisted pairs for long-distance, noise-tolerant links: * **RS-422** is full-duplex over four wires. A driver transmits on a dedicated TX pair labeled **Y/Z**, and the peer transmits back on a separate RX pair labeled **A/B**. One transmitter and up to ten receivers per pair. * **RS-485** is typically half-duplex over two wires. Transmit and receive share a single pair, called **A/B** in RS-485 terminology but physically the same Y/Z lines on this shield. Up to thirty-two nodes can share the bus and any of them can drive it. .. rubric:: How the shield supports both The shield carries two THVD1426 transceivers, each able to handle either standard: * The **first transceiver** drives the Y/Z pair (which doubles as the RS-485 A/B pair). It is the only one with its driver hooked up, so all outbound traffic from the camera goes out this pair regardless of mode. * The **second transceiver** drives the A/B pair. Its driver is tied off — this transceiver is receive-only and only matters in 4-wire RS-422 mode. Both transceivers' receivers are always enabled, and their RX outputs are AND'd together onto a single receive line back to the camera: * In **2-wire RS-485 mode**, only the first transceiver is active. Wire the bus to Y/Z; the A/B side sits idle and the AND gate just passes the first transceiver's RX through. * In **4-wire RS-422 mode**, the peer transmits to the camera on the A/B pair (picked up by the second transceiver) while the camera transmits on Y/Z (with the first transceiver's own receiver echoing its outgoing data back). The AND gate combines them — whichever pair sees a low pulse (start bit, data) reaches the camera. The terminal-block labels reflect the dual mapping: * **RS-422 (4-wire)** — TX out on Y/Z, RX in on A/B. * **RS-485 (2-wire)** — TX/RX share the Y/Z pair (= A/B in RS-485 nomenclature). Leave the A/B terminals on the shield unconnected. Usage ----- .. note:: The ``UART(3)`` peripheral number below follows the STM32 mapping. On another processor the bus wired to these pins may be different — check your board's reference. Talk to a differential serial peer on P4 (TX) / P5 (RX):: from machine import UART uart = UART(3, baudrate=115200) uart.write("hello\n") print(uart.read()) Read the AIN terminal-block input through the level-shifted P6 pin:: from machine import ADC import time ain = ADC("P6") while True: v = ain.read_u16() * 3.3 / 65535 print("AIN:", v * (5.0 / 3.3), "V") time.sleep_ms(100) React to a falling edge on the SYN line — for example, to sync the camera with another device pulling SYN low:: from machine import Pin def on_sync(pin): print("SYN falling edge") syn = Pin("P10", Pin.IN) syn.irq(on_sync, Pin.IRQ_FALLING)
