Servo Shield ============ The Servo Shield drives up to eight hobby servos in parallel from the OpenMV Cam over I2C, using a PCA9685 servo / PWM controller. .. image:: ../servo-shield-old-hero.jpg :alt: Servo Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Servo Shield product page `_. Highlights ---------- * PCA9685 servo / PWM controller * Eight independent servo channels over I2C * Stacks with the Motor Shield and Pan and Tilt Shield Pinout ------ .. image:: ../pinout-servo-shield-old.png :alt: Servo Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P4", "I²C SCL — clock to the PCA9685" "P5", "I²C SDA — data to the PCA9685" "VIN rail", "Powers the servos (from the camera's VIN pin)" "3.3V rail", "Powers the PCA9685 logic" "GND rail", "Servo and camera common ground" The default I²C address is ``0x40``. Connect the on-board solder bridge to move the address to ``0x60``. .. note:: The shield draws servo power straight from the camera's VIN pin. USB does not feed VIN on any OpenMV Cam, so VIN must be supplied externally (battery, bench supply, or similar) — pick a source rated for the combined stall current of every servo you plan to drive. Usage ----- Drive the eight servo channels through the PCA9685 over I²C. The pulse-width range varies between servos, so tune ``MIN_US`` and ``MAX_US`` to match yours — typical values are around 1000–2000 µs:: import time from machine import SoftI2C, Pin class PCA9685: """Minimal PCA9685 driver — 12-bit PWM on any of 8 channels.""" def __init__(self, bus, address=0x40, freq=50): self._bus = bus self._addr = address bus.writeto_mem(address, 0x00, b"\x00") # reset Mode1 prescale = round(25_000_000 / (4096 * freq)) - 1 bus.writeto_mem(address, 0x00, b"\x10") # sleep bus.writeto_mem(address, 0xFE, bytes([prescale])) # prescale bus.writeto_mem(address, 0x00, b"\x00") # wake time.sleep_us(5) bus.writeto_mem(address, 0x00, b"\xA1") # restart + AI + allcall self._period_us = 1_000_000 // freq def set_duty(self, channel, duty): duty &= 0xFFF # 12-bit if duty == 0: on, off = 0, 0x1000 # FULL_OFF elif duty == 0xFFF: on, off = 0x1000, 0 # FULL_ON else: on, off = 0, duty self._bus.writeto_mem( self._addr, 0x06 + 4 * channel, bytes([on & 0xFF, on >> 8, off & 0xFF, off >> 8])) def set_us(self, channel, pulse_us): self.set_duty(channel, (pulse_us * 4096) // self._period_us) MIN_US = 1000 # full-left pulse width (microseconds) MAX_US = 2000 # full-right pulse width bus = SoftI2C(scl=Pin("P4"), sda=Pin("P5")) pca = PCA9685(bus, address=0x40, freq=50) def angle(channel, deg): pca.set_us(channel, MIN_US + (deg * (MAX_US - MIN_US)) // 180) while True: for ch in range(8): angle(ch, 0) time.sleep_ms(2000) for ch in range(8): angle(ch, 180) time.sleep_ms(2000) The PCA9685 also handles general 12-bit PWM at any frequency — reuse the same class with ``set_duty`` (0–4095) to, for example, fade an LED on channel 0 at 1 kHz. The helper below scales a 0.0–100.0% float onto the chip's 0–4095 duty range:: import time from machine import SoftI2C, Pin bus = SoftI2C(scl=Pin("P4"), sda=Pin("P5")) pca = PCA9685(bus, address=0x40, freq=1000) def brightness(channel, pct): pca.set_duty(channel, int(pct * 4095 / 100)) while True: # Ramp up 0 → 100%. for pct in range(101): brightness(0, float(pct)) time.sleep_ms(20) # Ramp down 100 → 0%. for pct in reversed(range(101)): brightness(0, float(pct)) time.sleep_ms(20)
