Servo Shield ============ The Servo Shield (v3) drives up to four standard hobby servos directly from the OpenMV Cam. Its on-board regulator accepts a 6–36 V input on the terminal block and delivers 5.6 V at up to 5 A — enough to power both the camera and the servos from a single supply. .. image:: ../servo-shield-hero.jpg :alt: Servo Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Servo Shield product page `_. Highlights ---------- * Drive up to four hobby servos via P7 / P8 / P9 / P10 * 6–36 V input on the terminal block (reverse-voltage tolerant) * 5.6 V at up to 5 A on VIN — powers the camera and servos * 0–5 V ADC input with overvoltage protection up to ±36 V * Bidirectional 0–5 V digital I/O with 3.3 V to 5 V level shifting Pinout ------ .. image:: ../pinout-servo-shield.png :alt: Servo Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P6", "Level-shifted AIN readback (0–3.3 V on P6)" "P7", "Servo 1 — bidirectional 3.3 V ↔ 5 V GPIO" "P8", "Servo 2 — bidirectional 3.3 V ↔ 5 V GPIO" "P9", "Servo 3 — bidirectional 3.3 V ↔ 5 V GPIO" "P10", "Servo 4 — bidirectional 3.3 V ↔ 5 V GPIO" "PWR in", "6–36 V wide input on the terminal block (reverse-voltage tolerant)" "AIN in", "Analog input on the terminal block" "VIN out", "5.6 V regulated, up to 5 A combined for servos and camera" "3.3V rail", "Powers the shield's on-board electronics" "GND rail", "Common ground" .. note:: AIN is overvoltage-protected up to ±36 V and defaults to a 0–5 V voltage input, scaled down to 0–3.3 V on P6. Bridge the 4–20 mA mode shunt on the back of the shield to switch AIN to a 4–20 mA current-loop input. .. note:: Each of P6–P10 is tied to the camera through a 0-ohm resistor on the back of the shield. Remove the resistor on any pin you want to reclaim for unrelated use. .. note:: On the v2 version of the shield, P6–P9 are unidirectional 3.3 V → 5 V level shifters (output only). P10 is an open-drain digital line, pulled up to 3.3 V on the camera side and 5 V on the servo-pin side. By default it's an input — the shield level-shifts 0–5 V on the servo pin down to 0–3.3 V on P10. Change the on-board solder jumper to flip P10 into an output, level-shifting 0–3.3 V on P10 up to 0–5 V on the servo pin. Usage ----- Drive a hobby servo from any of P7–P10 with a 50 Hz PWM signal. The pulse-width range varies between servos, so tune ``MIN_US`` and ``MAX_US`` to match yours — typical values are around 1000–2000 µs:: from machine import Pin, PWM import time MIN_US = 1000 # full-left pulse width (microseconds) MAX_US = 2000 # full-right pulse width servo = PWM(Pin("P7"), freq=50) def angle(deg): pulse_us = MIN_US + (deg * (MAX_US - MIN_US)) // 180 servo.duty_ns(pulse_us * 1000) while True: angle(0) time.sleep(1) angle(90) time.sleep(1) angle(180) time.sleep(1) Read the AIN terminal-block input (the level-shifted result appears on P6):: from machine import ADC import time ain = ADC("P6") while True: # 0–5 V on the AIN terminal scaled to 0–3.3 V on P6 v = ain.read_u16() * 3.3 / 65535 print("AIN:", v * (5.0 / 3.3), "V") time.sleep_ms(100)
