Thermopile Shield ================= The Thermopile Shield gives the OpenMV Cam a 16x4 thermal-sensor array over I2C for low-resolution thermal imaging and per-pixel temperature measurement. .. image:: ../thermopile-shield-hero.jpg :alt: Thermopile Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Thermopile Shield product page `_. Highlights ---------- * 16x4 thermal sensor array, 60 deg x 16 deg field of view * Object temperatures from -50 C to 300 C Pinout ------ .. image:: ../pinout-thermopile-shield.png :alt: Thermopile Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P4", "I²C SCL — clock to the thermopile array" "P5", "I²C SDA — data to the thermopile array" "3.3V rail", "Powers the thermopile" "GND rail", "Common ground" Usage ----- Capture a heat-map from the on-board thermopile array via the :doc:`fir ` module:: import fir import image import time fir.init() clock = time.clock() while True: clock.tick() try: img = fir.snapshot(x_scale=10, y_scale=10, color_palette=image.PALETTE_IRONBOW, hint=image.BICUBIC, copy_to_fb=True) except OSError: continue print(clock.fps()) Read the raw per-pixel temperatures as a 16×4 ndarray of celsius floats. :func:`fir.read_ir` also returns the ambient temperature and the min/max seen in the frame:: import fir import time from ulab import numpy as np fir.init() w = fir.width() h = fir.height() while True: try: ta, ir, to_min, to_max = fir.read_ir() except OSError: continue grid = np.array(ir).reshape((h, w)) print("Ambient: %.1f C, range: %.1f to %.1f C, mean: %.1f C" % (ta, to_min, to_max, np.mean(grid))) time.sleep(1)
