Touch LCD Shield ================ The Touch LCD Shield gives the OpenMV Cam a 2.3 inch 320x240 capacitive multi-touch display so you can preview the camera output (and accept input) without a host computer. Two Qwiic headers make it easy to chain extra I2C devices. .. image:: ../touch-lcd-shield-hero.jpg :alt: Touch LCD Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Touch LCD Shield product page `_. Highlights ---------- * 2.3 inch TFT LCD, 320x240, 16-bit RGB565 * Capacitive multi-touch input * PWM-controllable backlight * Two Qwiic connectors for easy I2C device chaining Pinout ------ .. image:: ../pinout-touch-lcd-shield.png :alt: Touch LCD Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "LCD MOSI (SPI data to display)" "P1", "LCD TE (tearing-effect output)" "P2", "LCD SCLK (SPI clock)" "P3", "LCD SSEL (SPI chip select)" "P4", "Touch / Qwiic SCL (I²C clock — shared with Qwiic headers)" "P5", "Touch / Qwiic SDA (I²C data — shared with Qwiic headers)" "P6", "LCD backlight" "P7", "Touch / LCD RESET_N" "P8", "LCD RS (data / command select)" "P9", "Touch INT_N" "3.3V rail", "Powers the LCD and touch controllers" "GND rail", "Common ground" Usage ----- Drive the shield through the :class:`display.SPIDisplay` class. Stream camera frames to the 320×240 LCD:: import csi import time import display import image csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.QVGA) lcd = display.SPIDisplay(width=320, height=240, bgr=True, vflip=False, hmirror=False) clock = time.clock() while True: clock.tick() lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps()) Drive the backlight via PWM for adjustable brightness. Wrap :class:`machine.PWM` in a small backlight controller class and pass it to :class:`~display.SPIDisplay` through its ``backlight`` argument — :class:`~display.SPIDisplay` calls ``backlight(value)`` on the object whenever it needs to update the level:: import csi import time import display import image from machine import Pin, PWM class PWMBacklight: """Drives a backlight pin with machine.PWM (0–100 %).""" def __init__(self, pin, frequency=200): self._pwm = PWM(Pin(pin), freq=frequency, duty_u16=0) def backlight(self, value): self._pwm.duty_u16(int(value * 65535 / 100)) def deinit(self): self._pwm.deinit() csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.QVGA) lcd = display.SPIDisplay(width=320, height=240, bgr=True, vflip=False, hmirror=False, backlight=PWMBacklight("P6")) lcd.backlight(50) # 0–100 clock = time.clock() while True: clock.tick() lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps()) Read multi-touch input from the on-board FT6x36 capacitive controller — wired to the camera's I²C bus on P4/P5 with reset on P7 and IRQ on P9. The example below pairs touch with live camera streaming, drawing a red circle on the LCD wherever a finger is pressed:: from time import sleep_ms from array import array from machine import Pin, SoftI2C import csi import display import image import time _DEFAULT_ADDR = const(0x38) _DEV_MODE = const(0x00) _TD_STATUS = const(0x02) class FT6X36: FLAG_PRESSED = 0 FLAG_RELEASED = 1 FLAG_MOVED = 2 def __init__( self, bus, reset_pin, irq_pin, address=_DEFAULT_ADDR, width=320, height=240, reverse_x=False, reverse_y=False, touch_callback=None, ): self.bus = bus self.address = address self.width = width self.height = height self.reverse_x = reverse_x self.reverse_y = reverse_y self.touch_callback = touch_callback # reset_pin=None skips the reset pulse — useful when another # peripheral on the same line (e.g. the LCD) has already done it. if reset_pin is not None: self.rst_pin = Pin(reset_pin, Pin.OUT_PP, value=0) else: self.rst_pin = None self.irq_pin = None self.irq_pin_label = irq_pin # Reset the touch panel controller. self.reset() # Put the controller into normal operating mode. self._write_reg(_DEV_MODE, 0x00) # Scratch buffer for points (x, y, flag, id) — chip max 2. self.points_data = [array("H", [0, 0, 0, 0]) for _ in range(2)] self._touch_points_old = 0 self._touch_points = 0 def _read_reg(self, reg, size=1, buf=None): # FT6X36 expects two separate START/STOP transactions # (no repeated start), so don't use readfrom_mem here. self.bus.writeto(self.address, bytes([reg])) if buf is not None: self.bus.readfrom_into(self.address, buf) else: return self.bus.readfrom(self.address, size) def _write_reg(self, reg, val, size=1): if size == 1: buf = bytes([reg, val & 0xFF]) else: buf = bytes([reg, val & 0xFF, val >> 8]) self.bus.writeto(self.address, buf) def reset(self): if self.irq_pin is not None: self.irq_pin.irq(handler=None) if self.rst_pin is not None: self.rst_pin(0) sleep_ms(1) self.rst_pin(1) sleep_ms(39) self.irq_pin = Pin(self.irq_pin_label, Pin.IN, Pin.PULL_UP) if self.touch_callback is not None: self.irq_pin.irq( handler=self.touch_callback, trigger=Pin.IRQ_FALLING, hard=False, ) def read_points(self): regs = self._read_reg(_TD_STATUS, 13) n_points = min(regs[0] & 0x0F, 2) for i in range(0, n_points): base = 1 + i * 6 x = ((regs[base] & 0xF) << 8) | regs[base + 1] y = ((regs[base + 2] & 0xF) << 8) | regs[base + 3] if self.reverse_x: x = self.width - 1 - x if self.reverse_y: y = self.height - 1 - y self.points_data[i][0] = x self.points_data[i][1] = y self.points_data[i][2] = regs[base] >> 6 self.points_data[i][3] = regs[base + 2] >> 4 # Mark previously-active slots as released so the caller # sees a release event after a finger lifts. for i in range(n_points, 2): self.points_data[i][2] = self.FLAG_RELEASED # Latch touch count: rising immediate, falling debounced one read. if n_points >= self._touch_points: self._touch_points = n_points elif n_points <= self._touch_points_old: self._touch_points = self._touch_points_old self._touch_points_old = n_points return self._touch_points, self.points_data csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.QVGA) lcd = display.SPIDisplay(width=320, height=240, bgr=True, vflip=False, hmirror=False) # The LCD and touch controllers share P7 as a reset line. The LCD # has already pulsed it during its own init, so init the touch # controller after with reset_pin=None to skip a redundant pulse. bus = SoftI2C(scl=Pin("P4"), sda=Pin("P5"), freq=100_000) touch = FT6X36(bus, reset_pin=None, irq_pin="P9", reverse_y=True) clock = time.clock() # Some sensors return less than 240 lines at QVGA (e.g. 320x200 on # the N6). The display centers the frame, so map touch Y to image Y. y_offset = (touch.height - csi0.height()) // 2 while True: clock.tick() img = csi0.snapshot() n, points = touch.read_points() for i in range(n): x, y, flag, tid = points[i] if flag != FT6X36.FLAG_RELEASED: iy = y - y_offset if 0 <= iy < csi0.height(): img.draw_circle( (x, iy, 18), color=(255, 0, 0), thickness=2 ) lcd.write(img, hint=image.CENTER | image.SCALE_ASPECT_KEEP) print(clock.fps())
