WiFi Shield =========== The WiFi Shield adds 2.4 GHz Wi-Fi to OpenMV Cams that don't have on-board networking, using the Atmel WINC1500 module. It plugs into the bottom of any OpenMV Cam header. .. image:: ../wifi-shield-hero.jpg :alt: WiFi Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `WiFi Shield product page `_. .. note:: Supported only on the OpenMV Cam, M4, M7, H7, and H7 Plus. Highlights ---------- * 2.4 GHz Wi-Fi b/g/n via the Atmel WINC1500 module * TLS 1.2 hardware crypto for HTTPS / MQTTS Pinout ------ .. image:: ../pinout-wifi-shield.png :alt: WiFi Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "SPI MOSI — data to the WINC1500 module" "P1", "SPI MISO — data from the WINC1500 module" "P2", "SPI clock" "P3", "SPI chip select" "P6", "Chip enable" "P7", "Module reset" "P8", "Module interrupt" "3.3V rail", "Powers the WINC1500 module" "GND rail", "Common ground" Usage ----- Drive the shield through the :ref:`network.WINC ` class. In the default station mode, connect to a Wi-Fi network and print the assigned IP:: import network import time SSID = "your-network" KEY = "your-password" wlan = network.WINC() # station mode by default wlan.connect(SSID, KEY) while not wlan.isconnected(): print("connecting...") time.sleep_ms(1000) print("Wi-Fi IP:", wlan.ifconfig()[0]) The shield can also run as a Wi-Fi access point — pass ``MODE_AP`` to the constructor and call ``start_ap()`` to bring the AP up:: import network wlan = network.WINC(network.WINC.MODE_AP) wlan.start_ap("openmv-cam", security=network.WINC.OPEN) print("AP IP:", wlan.ifconfig()[0]) .. note:: The WINC1500's AP implementation accepts only one client at a time and supports only ``OPEN`` and ``WEP`` security modes. The WINC1500's own firmware can be inspected and updated from the camera. Print the running firmware version with:: import network wlan = network.WINC() print("Firmware version:", wlan.fw_version()) The latest stable image (``winc_19_7_6.bin``) ships inside the OpenMV IDE at ``/share/qtcreator/firmware/WINC1500/`` and is compatible only with the newer ATWINC1500-MR210PB hardware. To flash it, copy the ``.bin`` to the camera's SD card, eject the card so the FAT cache is flushed, reset the board, and run:: import network wlan = network.WINC(mode=network.WINC.MODE_FIRMWARE) wlan.fw_update("winc_19_7_6.bin") ``fw_dump()`` reads the current image back out to a file the same way. See the :ref:`network.WINC ` class for the full method list.
