Wireless TV Shield ================== The Wireless TV Shield combines a VS23S010 SPI-to-NTSC video generator with an MM213TL 5.8 GHz analog video transmitter so the OpenMV Cam can broadcast its frames to an FPV receiver. .. image:: ../wireless-tv-shield-hero.jpg :alt: Wireless TV Shield :width: 400px :align: center For full datasheet, photos, and ordering see the `Wireless TV Shield product page `_. Highlights ---------- * VS23S010 SPI-to-NTSC chip * MM213TL 5.8 GHz analog video transmitter * 352x240 NTSC output at 60 Hz * FPV / drone video downlink Pinout ------ .. image:: ../pinout-wireless-tv-shield.png :alt: Wireless TV Shield Pinout :width: 700px Pin reference ------------- .. csv-table:: :header: "Pin", "Function" :widths: 20, 80 "P0", "SPI MOSI — data to the VS23S010" "P2", "SPI clock" "P3", "SPI chip select" "3.3V rail", "Powers the VS23S010 and 5.8 GHz transmitter" "GND rail", "Common ground (also routed to the front-edge video breakout)" .. note:: The NTSC video output, VIN, and GND are also broken out to through-hole pads on the bottom of the shield — solder wires there to take the wired composite video signal off the board. Usage ----- Drive the shield through the :doc:`TVDisplay class ` exposed by the :doc:`display module `. Stream camera frames over the 5.8 GHz FPV downlink — ``IOCTL_CHANNEL`` selects which of the eight Boscam channels (1–8) the transmitter uses:: import csi import display import time csi0 = csi.CSI() csi0.reset() csi0.pixformat(csi.RGB565) csi0.framesize(csi.SIF) tv = display.TVDisplay() tv.ioctl(display.IOCTL_CHANNEL, 8) clock = time.clock() while True: clock.tick() tv.write(csi0.snapshot()) print(clock.fps())
