The keypoints editor ==================== Keypoint matching with :meth:`~image.Image.find_keypoints` works from a saved descriptor file -- the ``.orb`` file a script writes with :func:`image.save_descriptor` after extracting keypoints from a reference object (the keypoints examples in the Examples menu show the capture workflow). Real descriptors usually pick up junk: corners of the background, specular highlights, features that belong to the scene rather than the object. The keypoints editor, under Tools → Machine Vision → Keypoints Editor, is the cleanup tool. *Edit File* opens a descriptor (``.orb`` or ``.lbp``) alongside the image it was extracted from -- the editor finds the matching image file saved next to the descriptor -- and draws every keypoint on the image. Select the outliers with the mouse and remove them with the delete key; checkboxes toggle the visibility of each detection octave to work through the scales one at a time. Saving writes the trimmed descriptor back, first copying the previous descriptor and image to ``.bak`` files (an earlier ``.bak`` is replaced). *Merge Files* combines several descriptor files into one. Capture descriptors of the same object from a few angles and distances, merge them, and the result matches the object across more poses than any single capture would.
