Running scripts =============== The start button -- the green arrow below the connect button, or ``Ctrl+R`` -- sends the script in the current editor tab to the connected camera and executes it. The stop button that replaces it halts the running script. That pair of buttons is the core loop of all development on the camera: edit, start, watch, stop, edit again. Two details of that loop are worth being precise about. First, the script is sent to the camera's RAM and executed there -- starting a script writes nothing to the camera's storage, and the script is gone after a reset. Second, what runs is the *current editor tab*, exactly as shown, saved or not. There is no separate upload step and no stale copy on the camera to get out of sync with the editor. While a script runs, its ``print()`` output streams into the serial terminal and every frame it captures appears in the frame buffer viewer. When a script raises an unhandled exception, the traceback prints to the serial terminal and the IDE jumps the editor to the offending line -- for a multi-file application it opens the named file from the camera's drive to do so. Making a script permanent ------------------------- To make a camera run a script without the IDE -- on power-up, standalone, in the field -- the script has to be stored on the camera as ``main.py``. Tools → Save open script to OpenMV Cam (as main.py) writes the current editor tab to the camera's drive under that name -- offering on the way to strip comments and compress whitespace, which shrinks the file but ships an unreadable copy -- and Tools → Reset OpenMV Cam restarts the camera so it boots into the stored script. Together they are the deploy step: from then on the camera runs the script whenever it has power, IDE or not. While a reset camera is running its stored ``main.py``, the IDE can still connect to it -- with Stop Script on Connect/Disconnect active (the default), connecting halts the stored script and returns control to the editor. .. seealso:: :doc:`../../production/shipping/freezing-scripts` for what ``main.py`` means in the camera's boot sequence, and for moving a finished application out of editable storage entirely. The camera's drive ------------------ The camera's flash filesystem (and SD card, when one is inserted) mounts on the host as a USB flash drive. Tools → Open OpenMV Cam Drive folder opens it in the platform's file manager -- the place to copy library modules, model files, and assets the script imports or loads, and to retrieve images and logs the script saved. The drive path also appears in the status bar. Files a script creates do not show up on the host right away: the host caches the filesystem from the moment the drive mounts, so a snapshot saved by the running script stays invisible until the drive remounts. Tools → Reset OpenMV Cam remounts it -- the quick way to get at what the script just wrote. One caution: the camera and the host share that filesystem, and simultaneous writes from both sides can corrupt it. Copy files while no script is writing to storage, and eject cleanly before pulling the card.
