The threshold editor ==================== Colour tracking with :meth:`~image.Image.find_blobs` lives and dies by its threshold tuple -- the six LAB numbers (or two grayscale numbers) that decide which pixels count as the target. The threshold editor, under Tools → Machine Vision → Threshold Editor, turns finding those numbers from guesswork into a visual adjustment: drag sliders, watch which pixels light up, copy the tuple out when the target is solid white and everything else is black. .. admonition:: Screenshot needed ``figures/threshold-editor.png`` -- the Threshold Editor dialog tuning a LAB threshold on a colourful scene: source image on the left, binary preview on the right with the target object white, the six LAB min/max sliders below, and the resulting threshold tuple visible in the output field. Capture the whole dialog. The editor opens against either the live frame buffer or an image file from disk. It shows the source image and a binary preview side by side -- white pixels in the preview are the pixels the current threshold tracks -- with a min and max slider per channel underneath. Choose grayscale or LAB with the selector, drag the sliders until the binary preview isolates the target, and copy the threshold tuple from the output field into the script. An *Invert* checkbox flips the selection, and *Reset Sliders* starts over from wide-open. The practical procedure: point the camera at the real scene under the real lighting, run a script so the frame buffer holds a representative frame, open the editor on the frame buffer, and narrow each channel in turn -- usually A and B first for a coloured target, then L last and as loosely as possible, since lighting moves L far more than it moves A and B. Editing a tuple in place ------------------------ The editor is also wired into the script editor. Select an existing threshold tuple in a script -- ``(30, 100, 15, 127, 15, 127)`` or a grayscale pair -- right-click it, and choose the threshold-editor entry from the context menu. The editor opens preloaded with those values and, on OK, writes the adjusted numbers back over the selection (Cancel discards them). Retuning a deployed script for new lighting is a thirty-second job done this way.
