CMUcam3 Frame Grabber#
The CMUcam3 Frame Grabber is a simple utility that can be used to test your CMUcam3. Its primary purpose is to act as a terminal program similar to HyperTerminal or Minicom. It also allows you to view jpeg images returned from the camera. You need run the CMUcam2 Emulation firmware on the camera to use this program. The Frame Grabber requires that you install .NET version 2.0 or later which can be found on our software page. Unfortunately, the CMUcam3 Frame Grabber only works in Windows. The source can be found in the tools directory (called cc3_image_viewer). For Linux or Mac, please try using the CMUcam2GUI.
To start the application:
Double click on CMUcam3 Frame Grabber
Select the correct COM port from the “Available COM Ports” drop down menu
Click the “Connect” button
Power on your CMUcam3 running the CMUcam2 Emulation Firmware (reboot if it is already on)
You should see text appear in the “Terminal Console” window
Press “Grab Image” to take a picture
Here is a description of the fields on the “Main” tab of the interface:
Available COM Ports
This shows a list of serial ports that Windows recognizes
Baud Rate
This allows you to change the baud rate if you want to use this program as a terminal client
Timeout
This sets the timeout for any serial replies that the program might be waiting on
This usually does not need to be changed
Connect
Opens a serial connection
Disconnect
Closes the serial connection
Send
This button will transmit any text that you typed in the text box located to the left of the button
The text box automatically adds a return character, so just clicking “Send” should get you an ACK response from the CMUcam2
By default the focus is on the input text box, so you can just type and press return to send data
CIF / QCIF
These buttons set the resolution of the image being displayed
By default the CMUcam3 will send a low-res image that is scaled to fill the full window
Grab Image
This sends the “SJ” (Send JPEG) command to the CMUcam3 and displays the result
Loop
This check box causes the client to automatically press “Grab Frame” every “Refresh Interval” milliseconds
If the CMUcam3 can not produce an image in the time specified, the program will timeout with an error
If this happens, increase the Refresh Interval, or decrease the image resolution
Refresh Interval
This parameter sets how often the “Grab Image” command is sent when “Loop” is checked
Stop
This stops the looped images from being grabbed
The “Settings” tab allows you to set a few common CMUcam3 features. Each button that you press is simply transmitting the corresponding CMUcam2 commands over the serial port.
Here is a description of the fields on the “Setting” tab of the interface:
Low Resolution / High Resolution
These buttons switch between High Resolution CIF (352x288) or Low Resolution QCIF (176x144)
This corresponds to the “HR 1” and “HR 0” serial commands
RGB / YCrCb
This selects the camera’s native pixel mode to be either RGB or YCrCb
This corresponds to the “CR 18 44” or “CR 18 36” CMUcam2 commands
Down Sample
This sets the firmware based down sampling amount
This corresponds to “DS X Y” where X and Y are the values set in each selection box
Window
This set the virtual window parameters for the camera
This corresponds to the “VW x0 y0 x1 y1” CMUcam2 command
Servo Controller
This allows you to set the servo position of the 4 CMUcam3 servo ports
This will cause any servos connected to the CMUcam3 to move
This corresponds to the “SV” CMUcam2 command
You can send any CMUcam2 command using the “Send” button and the text input box. For example, sending “GM” (Get Mean) returns the mean color of the image. To stop the streaming, simply click “Send” or press return. This program does not visualize most of the CMUcam2 commands. For visualization try using the CMUcam2GUI java program.
Troubleshooting#
Why does the camera freeze when I change properties while grabbing images in a loop?
Unfortunately, the CMUcam3 Frame Grabber isn’t smart enough to really keep track of what you are doing. So if you are looping images and you change the resolution to something larger, then it may send the next “Grab Frame” command before the high resolution image was done transferring. After this happens a few times, the Frame Grabber gets out of sync with the camera and the serial times out. Typically if you press “Stop” before changing parameters, and make sure that you set the “Refresh Interval” to a larger value for high resolution images, then you will not get communication or timeout errors.
Why can’t I loop with high resolution images?
This is the same problem as described by the previous question. If the “Refresh Interval” is too small, then the camera will request images faster than it can produce them.
