CMUcam3 Linux Quick Start Guide#
This is for advanced users. For more detailed instructions see Documentation.
Make sure you already have the following installed
Make
Subversion
Openssh
Download from our Downloads page:
Linux ARM-gcc compiler
Linux LPC-ISP Installer
Not as root, install the files into a subdirectory of your home directory, and add to your local PATH
Download cc3 source
Get a zip of the latest stable snapshot from our Downloads page
or checkout a fresh copy from svn by typing:
svn co https://cc3.svn.sourceforge.net/svnroot/cc3/trunk cc3
Install gcc
bunzip2 arm-200xqx-xx-arm-none-eabi-i686-pc-linux-gnu.tar.bz2tar xvf arm-200xqx-xx-arm-none-eabi-i686-pc-linux-gnu.tarAdd:
/arm-200xqx/bindirectory to your path
Install LPC-ISP
unzip lpc21isp_unix.zipcd lpc21isp_unixmakeAdd the directory with lpc21isp to your path
Open up a new shell
Go to cc3
Type Make
Startup in programming mode
Hold in push button while turning on power to startup in programming mode
Load compiled hex file
cdtocc3/projects/cmucam2/Flash board with
cmucam2_lpc2106-cmucam3.hexAssuming your COM port is
/dev/ttyS0type:./lpc21isp cmucam2_lpc2106-cmucam3.hex /dev/ttyS0 115200 14746
Open up a terminal program
Power Cycle Board
A Green Power LED should turn on
If the code is running correctly, the red LED will turn off and the blue and yellow LEDs will dimly illuminate
Make sure it prints a startup message
Open Minicom or some other terminal program
Configure Minicom as described on our Minicom page.
Restart the board and wait 5 seconds
You should see the following:
CMUcam2 v1.00 c6 :
Try typing “gv” followed by enter to see if two-way serial communication is working
