Lua API: framediff#
Description#
The framediff data structure holds information about the difference between two different frames taken with the CMUcam3. Internally, these frames are held in a “current” and “previous” template. Comparisons between those two templates are done using framediff_scanline_start, framediff_scanline and framediff_scanline_finish.
Example#
This example demonstrates an implementation using the CMUcam3 and frame differencing. It loops, taking pictures until one picture is different than the previous one, at which point it saves that picture to disk by calling save_picture.
-- get a new framediff, and initialize it
fdiff = framediff_new(16, 16);
fdiff:set_total_x(pixbuf_get_width());
fdiff:set_total_y(pixbuf_get_height());
fdiff:set_threshold(10);
img = image_new(pixbuf_get_width(), 1); -- need an image object for the framediff'ing
take_picture();
fdiff:set_load_frame(true);
-- take the first picture
if (framediff_scanline_start(fdiff) > 0) then
while pixbuf_read_rows(img, 1) > 0 do
framediff_scanline(img, fdiff);
end
framediff_scanline_finish(fdiff);
end
fdiff:set_load_frame(false);
-- now keep taking pictures until a picture is different than its predecessor
repeat
take_picture();
end
else
print("Error!");
end
fdiff:swap_templates(); -- put current template in previous template spot
until fdiff:get_num_pixels() > fdiff:get_threshold()
-- we got an image that was different! Save it to disk, and send it to the Camscripter
save_picture("Diff.ppm"):
print_picture();
Constructor#
See framediff_new in Lua API: Functions
Methods#
disposeget_coiget_load_frameget_num_pixelsget_template_heightget_template_widthget_thresholdget_total_xget_total_yset_coiset_load_frameset_total_xset_total_yset_thresholdswap_templates
dispose#
fdiff:dispose()
- Parameters:
none
- Return Values:
none
Provides a way to explicitly dispose of memory associated with this framediff data structure instead of waiting for the Lua garbage collector to dispose of that memory. Warning: Errors are likely to result from using a framediff after calling dispose on it, it’s highly recommended that you not do so.
get_coi#
fdiff:get_coi()
- Parameters:
none
- Return Values:
the channel of interest for this framediff structure.
Get the channel of interest for this structure. See the channel of interest constants in Lua API: Constants for possible return values.
get_load_frame#
fdiff:get_load_frame()
- Parameters:
none
- Return values:
whether or not we want to load a new frame
Get the value of load_frame for this framediff object. load_frame determines whether we need to load a new frame from the CMUcam3 before doing any differencing of the current and previous templates.
get_num_pixels#
- Parameters:
none
- Return Values:
the number of pixels of difference between the current template and the previous template
After using framediff_scanline_start, framediff_scanline and framediff_scanline_finish, call this method to get the number of pixels of difference that were found between the current and previous template.
get_template_height#
fdiff:get_template_height()
- Parameters:
none
- Return Values:
the height of the templates
Get the height of the templates being differenced.
get_template_width#
fdiff:get_template_width()
- Parameters:
none
- Return Values:
the width of the templates
Get the width of the templates being differenced.
get_total_x#
fdiff:get_total_x()
- Parameters:
none
- Return Values:
the total width to be analyzed
Get the total width, usually equivalent to pixbuf_get_width
get_total_y#
fdiff:get_total_y()
- Parameters:
none
- Return Values:
the total height to be analyzed
Get the total width, usually equivalent to pixbuf_get_height
set_coi#
fdiff:set_coi(integer channel_of_interest)
- Parameters:
channel_of_interestThe new channel of interest for frame differencing- Return Values:
none
Set the channel of interest for framedifferencing. The parameter channel_of_interest must be one of the channel of interest constants in Lua API: Constants.
set_load_frame#
fdiff:set_load_frame(boolean newValue)
- Parameters:
newValueThe new value- Return Values:
none
Control whether or not a new frame needs to be loaded in the course of the next round of frame differencing. If this is true, a new picture will be taken and stored as the current template for frame differencing purposes.
set_total_x#
fdiff:set_total_x(integer total_x)
- Parameters:
total_xthe new value for total_x- Return Values:
none
Set total_x for the framediff packet.
set_total_y#
fdiff:set_total_y(integer total_y)
- Parameters:
total_ythe new value for total_y- Return Values:
none
Set total_y for the framediff packet.
set_threshold#
fdiff:set_threshold(integer threshold)
- Parameters:
thresholdThe new threshold value- Return Values:
none
Set the threshold, in number of pixels difference, that determines whether one frame is considered “different” from another frame.
swap_templates#
- Parameters:
none
- Return Values:
none
Swaps the current and previous template in this framediff structure. This function puts the current_template in the previous_template, and vice versa.
