ppm-grab#
PPM-grab can be used to store raw images on the MMC card that can be used with the virtual-cam for testing algorithms.
Setting Up PPM-grab:
You will need the following:
CMUcam3, with power and a serial cable
MMC or SD card
MMC/SD card reader on your PC
Format the Memory Card using the FAT filesystem
DO NOT USE FAT32 which is the Windows Default
Flash the ppm-grab.hex firmware file onto the CMUcam
Go to the cc3/projects/ppm-grab directory
Type “make” to build the application
Turn off your CMUcam3 and bring it to the area that you want to monitor
Insert the MMC card and turn the CMUcam3 on
After 1 second, press the button on the CMUcam3 to take a picture
Make sure the led toggles after each press
if the led doesn’t toggle, look at the serial output of the camera to see if an error is reported
