Simple Track Color#
This is a very simple example of how to use the cc3-ilp to track colors. The color in this example is hard-coded to a bright red object. The output on a terminal program (115,200 8N1) will look something like this:
centroid = 0,0 bounding box = 0,0,0,0 num pix= 0 density = 0
centroid = 144,91 bounding box = 124,85,175,106 num pix= 462 density = 431
centroid = 118,103 bounding box = 70,92,171,112 num pix= 1169 density = 578
centroid = 96,110 bounding box = 40,97,141,122 num pix= 1393 density = 551
The code looks like this:
#include <stdio.h>
#include <stdlib.h>
#include <cc3.h>
#include <cc3_ilp.h>
#include <cc3_color_track.h>
void simple_track_color(cc3_track_pkt_t* t_pkt);
int main(void) {
cc3_track_pkt_t t_pkt;
cc3_uart_init (0,
CC3_UART_RATE_115200,
CC3_UART_MODE_8N1,
CC3_UART_BINMODE_TEXT);
cc3_camera_init ();
//cc3_camera_set_colorspace(CC3_COLORSPACE_YCRCB);
cc3_camera_set_resolution(CC3_CAMERA_RESOLUTION_LOW);
//cc3_pixbuf_frame_set_subsample(CC3_SUBSAMPLE_NEAREST, 2, 2);
// init pixbuf with width and height
cc3_pixbuf_load();
// Load in your tracking parameters
t_pkt.lower_bound.channel[CC3_CHANNEL_RED] = 150;
t_pkt.upper_bound.channel[CC3_CHANNEL_RED] = 255;
t_pkt.lower_bound.channel[CC3_CHANNEL_GREEN] = 0;
t_pkt.upper_bound.channel[CC3_CHANNEL_GREEN] = 50;
t_pkt.lower_bound.channel[CC3_CHANNEL_BLUE] = 0;
t_pkt.upper_bound.channel[CC3_CHANNEL_BLUE] = 50;
t_pkt.noise_filter = 2;
while(true) {
simple_track_color(&t_pkt);
printf( "centroid = %d,%d bounding box = %d,%d,%d,%d num pix= %d density = %d\n",
t_pkt.centroid_x, t_pkt.centroid_y,
t_pkt.x0,t_pkt.y0,t_pkt.x1,t_pkt.y1,
t_pkt.num_pixels, t_pkt.int_density );
void simple_track_color(cc3_track_pkt_t * t_pkt)
cc3_image_t img;
img.channels = 3;
img.width = cc3_g_pixbuf_frame.width;
img.height = 1; // image will hold just 1 row for scanline processing
img.pix = cc3_malloc_rows (1);
if (img.pix == NULL) {
return;
cc3_pixbuf_load ();
if (cc3_track_color_scanline_start (t_pkt) != 0) {
while (cc3_pixbuf_read_rows (img.pix, 1)) {
// This does the HSV conversion
// cc3_rgb2hsv_row(img.pix,img.width);
cc3_track_color_scanline (&img, t_pkt);
cc3_track_color_scanline_finish (t_pkt);
free (img.pix);
return;
Tracking Multiple Colors#
The following example tracks bright red and green within the same frame without rewinding the FIFO. Loading the scanline into memory is a relatively slow operation. Once the scanline resides in memory computation over it is fast.
#include <stdio.h>
#include <stdlib.h>
#include <cc3.h>
void simple_track_color_2(cc3_track_pkt_t* t_pkt,cc3_track_pkt_t* t_pkt2);
int main(void) {
cc3_track_pkt_t t_pkt1;
cc3_track_pkt_t t_pkt2;
cc3_uart_init (0,
CC3_UART_MODE_8N1,
cc3_camera_init ();
cc3_pixbuf_load();
// Track Red
t_pkt1.lower_bound.channel[CC3_CHANNEL_RED] = 150;
t_pkt1.upper_bound.channel[CC3_CHANNEL_RED] = 255;
t_pkt1.lower_bound.channel[CC3_CHANNEL_GREEN] = 0;
t_pkt1.upper_bound.channel[CC3_CHANNEL_GREEN] = 50;
t_pkt1.lower_bound.channel[CC3_CHANNEL_BLUE] = 0;
t_pkt1.upper_bound.channel[CC3_CHANNEL_BLUE] = 50;
t_pkt1.noise_filter = 2;
// Track Green
t_pkt2.lower_bound.channel[CC3_CHANNEL_RED] = 0;
t_pkt2.upper_bound.channel[CC3_CHANNEL_RED] = 50;
t_pkt2.lower_bound.channel[CC3_CHANNEL_GREEN] = 150;
t_pkt2.upper_bound.channel[CC3_CHANNEL_GREEN] = 255;
t_pkt2.lower_bound.channel[CC3_CHANNEL_BLUE] = 0;
t_pkt2.upper_bound.channel[CC3_CHANNEL_BLUE] = 50;
t_pkt2.noise_filter = 2;
while(true) {
simple_track_color_2(&t_pkt1,&t_pkt2);
printf( "red centroid = %d,%d bounding box = %d,%d,%d,%d num pix= %d density = %d\n",
t_pkt1.centroid_x, t_pkt1.centroid_y,
t_pkt1.x0,t_pkt1.y0,t_pkt1.x1,t_pkt1.y1,
t_pkt1.num_pixels, t_pkt1.int_density );
printf( "green centroid = %d,%d bounding box = %d,%d,%d,%d num pix= %d density = %d\n",
t_pkt2.centroid_x, t_pkt2.centroid_y,
t_pkt2.x0,t_pkt2.y0,t_pkt2.x1,t_pkt2.y1,
t_pkt2.num_pixels, t_pkt2.int_density );
void simple_track_color_2(cc3_track_pkt_t * t_pkt,cc3_track_pkt_t * t_pkt2)
cc3_image_t img;
img.channels = 3;
img.height = 1;
return;
cc3_pixbuf_load ();
if (cc3_track_color_scanline_start (t_pkt) != 0 && cc3_track_color_scanline_start (t_pkt2) != 0) {
// Use the same scanline twice since it is already in memory and hence quick to operate upon
cc3_track_color_scanline (&img, t_pkt2);
cc3_track_color_scanline_finish (t_pkt2);
free (img.pix);
return;
