CMUcam3 Windows Quick Start Guide#
This is for advanced users. For more detailed instructions see Documentation. You can grab a bundled version of all of this software from the Downloads page.
Download and install cygwin
Make sure to install “Make”, “CVS”, “openssh”
Go to the Arm GNU Toolchain download site
Get the “EABI” or “Bare Metal” target for Windows
Install
Go to Flash Magic
Download and Install LPC ISP
Download cc3 source
Get a zip of the latest stable snapshot from our Downloads page
or checkout a fresh copy from svn by typing:
svn co https://cc3.svn.sourceforge.net/svnroot/cc3/trunk cc3
Open up Cygwin Shell
Go to cc3
cd c:to get to c drive, then cd into thecc3directorytyping
lswill list all of the files
Type
maketyping
make cleanwill remove all compiled files.make needs to be run in the root directory before you can compile individual projects
Startup in programming mode
Hold in push button while turning on power to startup in programming mode
Open LPC ISP and load compiled hex file
Browse to
cc3/projects/cmucam2/cmucam2_lpc2106-cmucam3.hexFlash board
Close ISP program
Open up a terminal program
Power Cycle Board
A Green Power LED should turn on
If the code is running correctly, the red LED will turn off and the blue and yellow LEDs will dimly illuminate
Make sure it prints a startup message
Use a Graphical User Interface to View Images and Focus Camera
Option 1: CMUcam3 Frame Grab Utility
Download the CMUcam3 Frame Grab Utility and install .NET (both on the Downloads page)
Double Click on “CMUcam3 Frame Grabber.exe”
Select Correct COM port and Press “Connect”
Click “Send” button to check for an “ACK” message to see if the port is connected
Click “Grab Frame” to grab a sample image
Option 2: CMUcam2 GUI
See the CMUcam2 GUI documentation
Check if GUI detects camera and can send frame
GUI does not set serial port correctly, so a terminal program must be run in between downloading from the ISP and use of the CMUcam2 GUI
