OV9665 Color CMOS SXGA Sensor#
Camera Interfacing#
The camera module has 24 pins on its flat pack connector (FPC). Shown below is the pin out for the camera module. Pin 1 is the right most pin on the FPC with the camera module facing right-side up.
Signal
Signal
1
NC
13
XCLK
2
AGND
14
Y8
3
SIO_D
15
DGND
4
AVDD
16
Y7
5
SIO_C
17
PCLK
6
Y6
7
VSYNC
19
Y2
8
PWDN
20
Y5
9
HREF
21
Y3
10
NC
22
Y4
11
DVDD
23
Y1
12
Y9
24
Y0
Power Control#
You need to supply 2.8V to 3.0V to the AVDD pin and 1.8V to 3.0V to the DVDD pin. You should power the AVDD and DVDD pins using separate low-noise power supplies. Additionally, the AGND and DGND pins should be separate for as long as possible in your setup for good picture quality.
Pull the RESET pin low to reset the camera module.
Pull the PWDN pin high to power down the camera module while in power down mode.
Control Bus#
The SIO_D and SIO_C pins are used to control the camera module. The SIO_D pin is the control bus’s data pin and the SIO_C pin is the control bus’s clock pin. See the initialization section for more details.
Data Bus#
The Y0 through Y9 pins on the camera module form a 10-bit data bus. For RGB565 and YUV422 mode Y0 and Y1 are unused. Y2 through Y9 are used to send an 8-bit byte where Y2 is the LSB and Y9 is the MSB.
While the HREF pin is high, Y2 through Y9 are valid. On the rising edge of the PCLK pin Y2 through Y9 should be sampled. Each pixel is transfered in 2 PCLK pulses. In SXGA mode the PCLK pin will go high 2,560 times while the HREF pin is high and the HREF pin will go high 1024 times. In VGA mode the PCLK pin will go high 1,280 times while the HREF pin is high and the HREF pin will go high 480 times. The SXGA resolution is 1280x1024 pixels and the VGA resolution is 640x480 pixels.
The VSYNC pin will go high and then low to mark the beginning of each frame.
In RGB565 mode, the camera module will send [MSB {R4, R3, R2, R1, R0, G5, G4, G3} LSB] every odd clock and [MSB {G2, G1, G0, B4, B3, B2, B1, B0} LSB] every even clock for each pixel.
In YUV422 mode, the camera module will send 8-bit YUV data where U and V are sent at half the bandwidth. The camera module sends Y0 on the first clock, followed by U on the second clock, followed Y1 on the third clock, followed by V on the fourth clock and then repeats the pattern. Y0, U, and V form pixel0 and Y1, U, and V, form pixel1. Two pixels are sent every four clocks.
Camera Initialization#
To control the OV9665 camera module you must communicate with it using the SCCB protocol – which is exactly the same as the I2C protocol. The device slave addresses are 0x60 for write and 0x61 for read. To initialize the camera you need to write 0x80 to register 0x12 to reset the camera and then delay for a second. After which you must send initialization register settings. Please note that the camera module requires a 10 MHz to 24 MHz (typically 24 MHz) clock input into its XCLK pin to operate.
SXGA Initialization#
To initialize the camera for SXGA mode send the following register settings. To set the frame rate in SXGA mode write the following values to register address 0x11: 0x80 for 15 FPS, 0x81 for 7.5 FPS, 0x82 for 5 FPS, 0x83 for 3.75 FPS, 0x84 for 3 FPS and etc. when XCLK is driven at 24 MHz. NOTE: The FPS value cannot be too low or the camera will fail to operate correctly.
\[\text{FPS} = \frac{15 \cdot (\text{XCLK}_\text{MHz} / 24)}{(\text{value} - \text{0x80}) + 1}\]
\[\text{PCLK Frequency} = \frac{\text{XCLK}_\text{MHz}}{(\text{value} - \text{0x80}) + 1}\]
VGA Initialization#
To initialize the camera for VGA mode send the following register settings. To set the frame rate in VGA mode write the following values to register address 0x11: 0x80 for 30 FPS, 0x81 for 15 FPS, 0x82 for 10 FPS, 0x83 for 7.5 FPS, 0x84 for 6 FPS, and etc. when XCLK is driven at 24 MHz. NOTE: The FPS value cannot be too low or the camera will fail to operate correctly.
\[\text{FPS} = \frac{30 \cdot (\text{XCLK}_\text{MHz} / 24)}{(\text{value} - \text{0x80}) + 1}\]
Color Mode#
Once the camera is initialized to either SXGA or VGA mode, at a particular frame rate, you must then setup the camera’s color output format. You can use either RGB565 or YUV422. Send these register settings to enter RGB565 mode and these register settings to enter YUV422 mode.
