Arduino Nano 33 BLE Sense#
This board is no longer supported. The last OpenMV firmware release for the Arduino Nano 33 BLE Sense is 4.7.0. No further firmware updates, bug fixes, or new features will be issued for this target. The information below is preserved for users running 4.7.0 or earlier.
The Arduino Nano 33 BLE Sense is a 45 × 18 mm Arduino‑Nano‑form‑factor board built around the Nordic Semiconductor nRF52840 — a single ARM Cortex‑M4 with FPU running at 64 MHz with 256 KB of internal SRAM and 1 MB of internal flash. BLE comes from the on‑die radio, and the board carries a 9‑axis IMU, an LPS22HB barometer, an HTS221 / HS3003 temperature / humidity sensor, an APDS9960 ambient light / colour / proximity / gesture sensor, and an MP34DT05 PDM microphone. The OpenMV firmware drives all of these from MicroPython.
For full datasheet, photos, and dimensions see the Arduino Nano 33 BLE Rev2 product page.
  • Nordic nRF52840 Cortex‑M4 with FPU at 64 MHz with 256 KB internal SRAM and 1 MB internal flash.
  • Bluetooth LE 5.0 via the on‑die radio and Nordic SoftDevice s140.
  • 9‑axis IMU — LSM9DS1 on Rev 1, BMI270 + BMM150 on Rev 2. The frozen imu driver probes both at boot.
  • LPS22HB barometer, HTS221 / HS3003 temperature and humidity sensor, APDS9960 ambient light / colour / proximity / gesture sensor, and MP34DT05 PDM microphone.
  • Micro USB connector for power, programming, and a CDC REPL.
  • 22 user I/O pins on the standard Nano headers — TX/RX, D2–D13 (digital), A0–A7 (analog).
Reference
UART1 TX
UART1 RX
PWM / SPI0 MOSI
PWM / SPI0 MISO
PWM / SPI0 SCK
ADC / PWM
ADC / PWM
ADC / PWM
ADC / PWM
A4 / I2C_SDA
ADC / PWM / I2C0 SDA
A5 / I2C_SCL
ADC / PWM / I2C0 SCL
A6
ADC / PWM
A7
ADC / PWM
press the on‑board RESET button or pull to GND to reset
LED_BUILTIN
Orange user LED on D13
The Nano 33 BLE Sense’s I/O pins are 3.3 V only — they are not 5 V tolerant. Driving 5 V into them will damage the nRF52840.
Power pins#
  • VIN — 4.5 – 21 V input. Powers the board through the on‑board regulator. Also fed via a diode from the USB 5 V rail, so USB and VIN can be present at the same time without back‑driving each other.
  • +5V — unconnected by default.
  • +3V3 — 3.3 V regulator output.
  • AREF — analog reference pin. Not wired to the nRF52840 on this board — the ADC is always referenced to 3.3 V.
The Nano 33 BLE Sense can be powered through either path:
  • Micro USB — supplies 5 V to the on‑board regulator.
  • VIN pin — drive a regulated 4.5 – 21 V supply.
A solder jumper on the bottom of the board labelled VUSB bridges +5V to the USB 5 V rail. Close it to make the +5V header pin actually carry 5 V.
A normally‑closed solder jumper on the output of the on‑board 4.5–21 V switching regulator can be cut to disable the regulator, so the board can be powered directly from an external 3.3 V supply on +3V3.
Recovery and debug pins#
  • RESET — both an exposed pad and a momentary RESET button on the top of the board, tied to the nRF52840’s reset line. Pull to GND or press the button to reset.
The Nano 33 BLE Sense uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader. Quickly press the RESET button twice — the board enters bootloader mode and OpenMV IDE can flash a new firmware image.
The nRF52840’s SWD signals are exposed on plated pads on the back of the board. All debug signals are 3.3 V referenced.
Onboard peripherals#
LEDs#
The Nano 33 BLE Sense has a user RGB LED — driven through the silkscreened LED_RED, LED_GREEN, and LED_BLUE channels — plus a separate orange LED_BUILTIN on D13. All four are software‑controllable through machine.LED:
LED("LED_BUILTIN").on()
A separate green power LED on the board lights whenever the +3.3 V rail is up and is not user‑controllable.
Camera sensor#
The OpenMV firmware on the Nano 33 BLE Sense supports the OmniVision OV7670 parallel CMOS sensor. The board has no on‑board image sensor — wire an OV7670 module to the silkscreened header pins listed below and drive it through the csi — camera sensors module:
The OV7670 takes 14 pins. The firmware wires them as follows:
Sensor signal
Nano 33 BLE Sense pin
HSYNC
VSYNC
PXCLK
MXCLK
POWER
A5 (I²C 0)
A4 (I²C 0)
The OV7670’s I²C control bus is the same external I²C 0 exposed on A5/A4. The sensor sits at 7‑bit address 0x21 — user devices on that bus must avoid this address when the camera is wired up.
IMU#
The 9‑axis IMU is exposed through the frozen imu module, which auto‑detects whether the board has the LSM9DS1 (Rev 1) or the BMI270 + BMM150 (Rev 2) and presents a unified imu.IMU class. The sensors sit on the internal I²C 1 bus (P14 / P15):
from machine import I2C, Pin
from imu import IMU
sensor = IMU(bus)
For direct access to features like tap detection or the FIFO, import the matching frozen driver (lsm9ds1, bmi270, or bmm150) and instantiate it on the same bus.
Environmental sensors#
The barometer (LPS22HB) and temperature / humidity sensor (HTS221 on Rev 1, HS3003 on Rev 2) share the same internal I²C 1 bus as the IMU:
from lps22h import LPS22H
from hts221 import HTS221
lps = LPS22H(bus)
    hts = HTS221(bus)
    from hs3003 import HS3003
    hts = HS3003(bus)
Light / colour / proximity / gesture#
The Broadcom APDS9960 sits on the same internal I²C 1 bus and provides ambient light, RGB colour, proximity, and gesture sensing:
apds = APDS9960(bus)
apds.enableLightSensor()
    time.sleep_ms(250)
Microphone#
The on‑board MP34DT05 PDM microphone is captured through audio — Audio Module. Each buffer arrives as signed‑16‑bit PCM bytearray, ready to feed into ulab/numpy for DSP:
Bluetooth#
The nRF52840’s Bluetooth LE 5.0 radio runs on the Nordic SoftDevice s140 and is exposed through the legacy ubluepy module — the modern bluetooth / aioble — Async BLE APIs are not enabled in this build. Both peripheral (GATT server, advertise) and central (GAP observer / scanner + connect) roles are available.
Advertise as a peripheral with a single Environmental Sensing service and a notifiable temperature characteristic — the event_handler callback fires on connect, disconnect, and CCCD writes:
        LED("LED_GREEN").off()
svc.addCharacteristic(char)
periph = Peripheral()
periph.addService(svc)
Scan for nearby advertising devices in central role:
from ubluepy import Scanner
See the ubluepy reference for the full API — UUID, Service, Characteristic, Peripheral, Scanner, ScanEntry, and the constants namespace.
Bus reference#
GPIO#
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS — 15 mA per pin, 25 mA total across all GPIOs.
UART#
Use the silkscreen names TX/RX with machine.UART:
I²C#
I2C0
I2C_SDA / A4
I2C_SCL / A5
P15
Both buses need their pins passed explicitly to machine.I2C:
bus0.scan()
bus1.scan()
Bus 1 is the internal sensor bus on P14/P15 (not on the user headers) — it serves the IMU, barometer, environmental sensor, and APDS9960. The frozen sensor drivers use it directly; user code can scan it too but the addresses are already taken by the on‑board sensors.
SPI#
The CS line is not driven by the SPI peripheral — configure D10 as an output and toggle it manually around the transfer:
from machine import SPI, Pin
D13 doubles as the orange LED_BUILTIN — driving SPI on this bus will blink the LED in time with the bus clock.
ADC#
The nRF52840 has eight 12‑bit ADC channels (SAADC) exposed on A0–A7, all 3.3 V referenced — read_u16 returns 0–65535 across 0–3.3 V at the pin. The board’s AREF pin is not wired, so the reference is always 3.3 V:
PWM#
The nRF52840 exposes four PWM peripherals (PWM0–PWM3), each driving four channels, for 16 hardware PWM slots in total. Unlike fixed‑function ports, the peripherals route through the GPIOTE matrix — any GPIO can be a PWM output, so there is no pin‑to‑slice mapping. The cost of that flexibility is two constraints baked into the silicon:
  • All four channels inside a module share a single period/frequency.
  • Each channel has its own duty cycle and polarity.
Conceptually the 16 slots look like this:
Module
Ch 0
Ch 1
Ch 2
Ch 3
PWM0
duty
duty
duty
duty
PWM1
duty
duty
duty
duty
PWM2
duty
duty
duty
duty
PWM3
duty
duty
duty
duty
Each row runs at one frequency; the four cells in a row each drive an independently‑chosen pin with its own duty cycle. Different rows can run at completely different frequencies.
Drive any silkscreened pin (or the on‑board LEDs) via machine.PWM:
Auto‑allocation consumes a whole module per call. When you create a PWM without device=/channel= kwargs, the driver grabs the first free module and binds your pin to its channel 0 only. The remaining three channels of that module sit idle and are only reachable through explicit device=/channel=. That caps unaided PWM(Pin(...)) calls at four before the driver raises ValueError: all PWM devices in use — even though twelve slots are technically still free.
To use more than four PWMs, or to deliberately share a frequency across pins, pass device (0–3) and channel (0–3):
            freq=1_000, duty_u16=32768)
            freq=1_000, duty_u16=16384)
            freq=20_000, duty_u16=49152)
Duty cycle accepts duty (0–100%), duty_u16 (0–65535), or duty_ns. Add invert=1 to flip the output polarity (handy for the active‑low RGB LED).
Because frequency is a per‑module property, calling pwm.freq(new_freq) on any channel of a module re‑runs nrfx_pwm_init for the whole module and changes the frequency seen by every other channel sharing it.
Allowed frequencies span roughly 4 Hz to 5.3 MHz, derived from the 16 MHz base clock with prescalers 1/2/4/8/16/32/64/128 and a 15‑bit period counter. The driver picks the closest divisor automatically — freq() reports the requested value, not the exact achievable one.
Software bit‑banged buses#
Thermal sensor (off‑board)#
The fir driver only talks to the sensor over I²C 0 — wire the module to the I2C_SCL / I2C_SDA pads (A5 / A4).
Timing#
time#
Virtual timers#
Real‑time clock#
machine.RTC keeps wall‑clock time across resets. The nRF52840’s RTC is tied to the on‑chip oscillator and does not survive full power loss — set the time on every cold boot if it matters to your application:
Watchdog#
Boot and runtime info#
Firmware update#
Filesystem and boot order#
The Nano 33 BLE Sense firmware mounts a single filesystem on boot:
  • Internal flash — always mounted at /flash and used as the working directory. Holds main.py and README.txt by default; created on the very first boot.
After mounting, the interpreter then runs scripts from /flash:
  • boot.py is executed on every soft reset.
  • main.py is executed only on cold boot, immediately after boot.py.
/flash is not exposed as a USB mass‑storage drive on this board.
Storage sizes#
The Nano 33 BLE Sense ships with:
  • /flash — 64 KB FAT filesystem, read/write.
The Nano 33 BLE Sense build does not include a ROMFS; ship Python modules on /flash directly.
Software libraries#
See the library index for the full list of modules — including which ones are unique to the Nano 33 BLE Sense build.
