OpenMV AE3#
The OpenMV AE3 is built around the Alif Ensemble E3 — a dual ARM Cortex‑M55 SoC (400 MHz HP core + 160 MHz HE core) with two on‑chip NPUs (400 MHz / 204 GOPS HP NPU + 160 MHz / 46 GOPS HE NPU). The board pairs the NPUs with the PAG7936 1 MP global‑shutter sensor, USB‑C high‑speed, Wi‑Fi, Bluetooth 5.1, an LSM6DSM IMU, a microphone, and an 8×8 VL53L8CX time‑of‑flight rangefinder, all on a 30 × 30 mm board.
OpenMV AE3
For full datasheet, photos, and dimensions see the OpenMV AE3 product page.
  • Alif Ensemble E3 — dual ARM Cortex‑M55 with Helium 128‑bit SIMD, 400 MHz HP core + 160 MHz HE core (~640 / ~256 DMIPS, CoreMark 1748 / 752).
  • Dual NPUs: 400 MHz / 204 GOPS HP NPU + 160 MHz / 46 GOPS HE NPU for AI/ML — runs YOLO object detection alongside other workloads.
  • Hardware 2D GPU for scaling.
  • 13.5 MB internal SRAM plus 5.5 MB on‑chip MRAM and 32 MB external octal flash (100 MHz 8‑bit DDR, 200 MB/s read).
  • 4 KB backup RAM with the on‑chip RTC.
  • PAG7936 1 MP color global‑shutter sensor.
  • Onboard IMU (LSM6DSM accelerometer + gyroscope), microphone, and VL53L8CX 8×8 time‑of‑flight sensor (up to 4 m).
  • High‑speed USB‑C (480 Mb/s) with EMI filtering and TVS protection, Wi‑Fi a/b/g/n + Bluetooth 5.1 (chip antenna or U.FL option).
  • 10 user I/O pins — P0–P3 on the side headers, P4–P5 on the Qwiic connector, and P6–P9 on the B2B header on the back. Additional debug and recovery lines are also routed to the B2B header.
  • All pins 3.3 V output / 3.3 V tolerant, 25 mA per pin, interrupt‑capable. ADC inputs are 1.8 V referenced.
  • User RGB LED, user button, recovery switch, Qwiic connector.
  • 80 µA deep sleep at 3.3 V (24 mA idle, 50–60 mA active).
The AE3’s I/O pins are not 5 V tolerant. Do not connect the device directly to a 5 V MCU like the Arduino Mega — use a level shifter for any 5 V signal.
OpenMV AE3 PAG7936 Pinout
The AE3 exposes 10 user pins on the side headers (P0–P9). Additional signals — including JTAG and the recovery line — are routed to a B2B (board‑to‑board) header on the back of the board for shields and carrier boards.
Reference
1.8 V
I2C1 SDA / UART3 CTS / TIM9 T0 (B2B only)
1.8 V
I2C1 SCL / UART3 RTS / TIM9 T1 (B2B only)
1.8 V
I3C SDA / UART3 RX / TIM5 T0 / ADC ch S10 (B2B only)
1.8 V
I3C SCL / UART3 TX / TIM5 T1 / ADC ch S11 (B2B only)
1.8 V
GPIO / JTAG TCK (B2B only)
1.8 V
GPIO / JTAG TDO (B2B only)
1.8 V
GPIO / JTAG TMS (B2B only)
1.8 V
GPIO / JTAG TDI (B2B only)
user button (active low)
P0–P5 are on the side headers (3.3 V referenced); P6–P9 are exposed only on the B2B header on the back of the board and are 1.8 V referenced. Driving 3.3 V into a 1.8 V‑referenced pin will damage the SoC — make sure any signal connected to the B2B header is at 1.8 V.
Power pins#
  • 3.3V — the AE3’s main power rail. The same 3.3 V rail is exposed on the GPIO header solder pads, the Qwiic connector, and the B2B header on the back of the board.
  • 1.8V — exposed on the B2B header as an output only. Use it to power 1.8 V‑logic peripherals on a B2B carrier; do not drive it from outside the board.
The AE3 has no VIN pin and no LiPo charger. It can be powered through any of three paths:
  • USB‑C — the on‑board regulator drops 5 V from USB to 3.3 V and injects that onto the 3.3 V rail.
  • Qwiic connector — drive a regulated 3.3 V supply into the Qwiic header to power the board from a Qwiic module.
  • GPIO header / B2B 3.3 V pads — drive a regulated 3.3 V supply into any of the 3.3 V pads on the I/O header or the B2B connector.
The USB regulator feeds the rail through an ideal diode, so external 3.3 V supplies on the Qwiic / GPIO / B2B side can power the board even while USB is still attached without back‑driving the USB regulator.
Use the battery life estimator to model how long the AE3 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
  • RESET — pull to GND to reset the board. Releasing it lets the SoC start up normally.
There is a recovery switch on the front (camera‑side) face of the board, in the bottom‑left corner. When enabled, it forces the AE3’s SE UART out over USB so OpenMV IDE can reflash the on‑board bootloader. The same recovery mode can be triggered remotely by pulling the RECOVERY pin on the B2B connector low.
The AE3 supports both SWD and full JTAG debugging:
  • The 1.8 V SWD header on the side of the board is for a Tag-Connect ECV3-06-CTX cable and breaks out the four SWD signals (TCK / TMS / TDO / RSTN) plus GND.
  • The B2B header on the back of the board exposes the same debug pins (P10 = TCK, P11 = TDO, P13 = TMS, P14 = TDI) plus the system RSTN and a separate JTAG RSTN. These pins can be used for either SWD (TCK + TMS) or full JTAG; the JTAG RSTN line is only needed in full-JTAG mode.
All debug signals are 1.8 V referenced — make sure your debug adapter is configured for 1.8 V logic before connecting.
Onboard peripherals#
LEDs#
The AE3 has a single user RGB LED, software‑controllable through machine.LED:
User button#
The AE3 has a single user button (SW):
sw = Pin("SW", Pin.IN)
print(sw.value())
To put the board into deep sleep and have SW wake it back up, just call machine.deepsleep() — no wakeup configuration is required, the button is wired straight to a wake input:
To reach the 80 µA deep sleep figure you must put the IMU to sleep first with imu.sleep():
imu.sleep(True)
machine.deepsleep()
With the IMU left running the board draws about 500 µA in deep sleep. Note that putting the IMU to sleep disables waking the board on IMU interrupts.
You can also wire SW up as a soft power switch. Trigger on the rising edge — the line settles high after the user releases the button, so the next press is unambiguously a wake event:
def power_off(_):
    machine.deepsleep()
# press it again to wake.
Camera sensor#
The PAG7936 is driven through the csi — camera sensors module:
The PAG7936 supports triggered mode — pixel integration lines up exactly with each csi.CSI.snapshot call rather than the free-running frame clock, useful for syncing capture to an external event or another sensor. Enable it through csi.CSI.ioctl with csi.IOCTL_SET_TRIGGERED_MODE. Frame rate drops to roughly half of free-running mode because the readout no longer pipelines with the next frame’s integration:
NPU#
The AE3’s two on‑chip NPUs (400 MHz / 204 GOPS HP NPU + 160 MHz / 46 GOPS HE NPU) are exposed through the ml — Machine Learning module. Models stored on the read‑only /rom filesystem load directly from flash without copying to RAM, so even large detectors fit comfortably alongside the live framebuffer. Run a YOLOv8 detector on every frame and draw the predictions on top of the live image:
# Visualization parameters.
n = len(model.labels)
model_class_colors = [
    for i in range(n)
    boxes = model.predict([img])
HE core#
The AE3 packages two Cortex‑M55 cores in one MCU: the high-performance (HP) core that runs the main MicroPython instance, the camera, the HP NPU, USB, and so on; and the high-efficiency (HE) core that sits at much lower power and boots into a small MicroPython instance of its own. Both cores share an Open-AMP / RPMsg message bus, so the HP core can dispatch Python functions to the HE core, get results back, and keep the two halves decoupled.
The simplest entry point is the @openamp.async_remote decorator. It marshals a Python function, ships it to the HE core, and the HE core runs it as an asyncio task. After registering tasks, instantiate openamp.RemoteProc with the HE firmware’s flash address and call rproc.start() to boot the second core. With no callback, the decorated function’s print() output is forwarded over the default endpoint to the HP core’s stdout — handy for a “hello world”:
async def task1(ept):
        await asyncio.sleep(1)
For bidirectional messaging, pass a callback to the decorator. The callback runs on the HP core whenever the HE task calls ept.send():
        ept.send(f"count = {count}")
The HE core has its own HE NPU (160 MHz, 46 GOPS), so it can run a second ML model in parallel with whatever the HP core’s HP NPU is busy with. A useful split is to put a small always-on trigger / classifier model on the HE side and let the HP core react only when something interesting is flagged — keyword spotting from the on-board microphone is a good fit because it’s continuous, low-bandwidth, and the HE core stays at much lower power than HP. The frozen ml.apps.MicroSpeech helper recognizes “Yes” and “No” out of the box — say the words loudly and clearly into the on-board mic to trigger detection:
        if label:
            ept.send(label)
For a richer split, run BlazeFace on the HP NPU while the HE core handles keyword spotting in the background — the HP loop overlays the most recent heard keyword on the camera frame:
label = None
label_ticks = 0
LABEL_HOLD_MS = 2000
    global label, label_ticks
    label = data.decode()
    label_ticks = time.ticks_ms()
        if l:
            ept.send(l)
                                  ((0, 0, 255),), format=None)
    if label is not None:
                            color=(255, 0, 0), scale=2)
            label = None
The HE core is well suited to always-on or low-rate workloads that you don’t want competing with the camera/NPU pipeline on the HP side — small ML inference, lightweight DSP on microphone or IMU data, and similar background jobs.
A few constraints to keep in mind:
  • Stick to the microphone and IMU when driving peripherals from the HE core — those are what the HE side is designed for. Each peripheral can only be owned by one core at a time, so pick HP or HE for it and stick with that for the lifetime of the script.
  • Each @openamp.async_remote task body must marshal to under 500 bytes of mpy bytecode — keep the function small and factor heavier logic into separate library modules that get frozen into the firmware.
  • Imports inside the dispatched function only see modules that exist on the HE core’s filesystem. The HE core has its own /rom ROMFS — separate from the HP core’s /rom — so modules and ML models you want available on HE need to be baked into the HE-side ROMFS image, not the HP one.
Microphone#
The on‑board mic is captured through audio — Audio Module. Each buffer arrives as a signed‑16‑bit PCM bytearray, which makes it trivial to feed into ulab/numpy for quick DSP. A simple loudness detector — print whenever the RMS volume crosses a threshold:
IMU#
The on‑board LSM6DSM accelerometer + gyroscope is exposed through imu — imu sensor:
Time‑of‑flight sensor#
The AE3 carries a VL53L8CX 8×8 multi‑zone time‑of‑flight sensor that returns up to 64 distance readings per frame, with a maximum range of ~4 m. It’s exposed through the tof — time-of-flight sensor driver module — call tof.init() to start the sensor and tof.read_depth() to grab a depth frame as a flat list of millimetre readings (one per zone):
import tof
tof.init()
The depth array can also be drawn over a colour frame from the main sensor — tof.draw_depth() paints it onto an existing image.Image, while tof.snapshot() returns a freshly rendered depth image:
import tof
tof.init()
cam.framesize(csi.VGA)
# back to the live preview.
        # them as "closest".
            if depth[i] == 0.0:
                depth[i] = dmax
    except RuntimeError:
        tof.reset()
    # the right.
    img.set(b)
Wi‑Fi#
The on‑board CYW43439 is exposed via network — network configuration as a station interface. After connecting, ipconfig("addr4") returns the (ip, netmask) pair:
Bluetooth#
The same CYW43439 also exposes Bluetooth 5.1. Use aioble — Async BLE for asyncio‑friendly BLE — for example, advertise as a peripheral and wait for a central to connect:
Bus reference#
GPIO#
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS and can sink/source up to 25 mA per pin.
UART#
RTS
CTS
UART5
UART3 is the only bus with hardware flow control. Because P6–P9 sit on the B2B header and are 1.8 V referenced, UART3 only works through a level shifter or a B2B carrier — don’t connect 3.3 V logic to it directly.
I²C#
LPI2C
The on‑board Qwiic connector breaks out I2C2 at 3.3 V.
I2C1 and I2C2 can also be used in target (slave) mode through machine.I2CTarget to expose a memory region to another I²C controller:
The LPI2C peripheral is not exposed in firmware. It would only support target (slave) mode if exposed, and I2C1 and I2C2 already cover both controller and target operation.
SPI#
ADC#
The Alif Ensemble E3 exposes two 12‑bit ADC channels on P8 and P9 (B2B header only). Both inputs are 1.8 V referenced — read_u16 returns 0–65535 across 0–1.8 V at the pin:
adc = ADC("P8")
The AE3’s ADC inputs are 1.8 V referenced, not 3.3 V. Driving a raw 3.3 V signal in will saturate the converter and may damage the pin — divide higher voltages down externally.
PWM#
Timer / channel
TIM0 T1
TIM0 T0
TIM1 T1
TIM1 T0
TIM2 T1
TIM2 T0
TIM9 T0 (B2B only)
TIM9 T1 (B2B only)
TIM5 T0 (B2B only)
TIM5 T1 (B2B only)
Software bit‑banged buses#
Thermal sensor (off‑board)#
The firmware includes the fir — thermal sensor driver (fir == far infrared) driver for an externally wired AMG8833 8 × 8 thermal imager. Connect the module to the I²C bus listed below, then read frames with fir.init() + fir.snapshot():
The fir driver only talks to the sensor over I²C 1 — wire the module to P4 (SCL) and P5 (SDA).
Timing#
time#
Virtual timers#
Real‑time clock#
machine.RTC keeps wall‑clock time across resets, backed by 4 KB of on‑chip backup RAM that survives deep sleep:
The RTC also runs through deep sleep, so you can use it as a wakeup source for machine.deepsleep().
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The AE3 firmware mounts up to two filesystems on boot:
When connected over USB, /flash also enumerates as a USB mass‑storage drive on the host, letting you edit boot.py, main.py, and any other files directly. Eject the drive before resetting the camera so the host flushes its cached writes.
Because the OS treats the drive as a passive block device, files created or modified by code running on the OpenMV Cam will not show up until the host re‑mounts the drive. If both the OS and the OpenMV Cam write the same filesystem at the same time, the OS will win and overwrite changes made by the camera.
Storage sizes#
The AE3 ships with:
  • /flash — 8 MB FAT filesystem, read/write.
  • /rom on the HP core — 24 MB read-only memory-mapped ROMFS for scripts and data the HP core loads at startup.
  • /rom on the HE core — 1 MB read-only ROMFS owned by the HE core. Modules and ML models you want available to @openamp.async_remote tasks have to be baked into this image, not the HP one.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the AE3 build.
