OpenMV Cam H7 Plus#
The OpenMV Cam H7 Plus pairs the STMicroelectronics STM32H743 (Cortex‑M7 @ 480 MHz) with 32 MB of external SDRAM, 32 MB of QSPI flash, a hardware JPEG codec, and the OV5640 5MP camera module on a removable carrier. The extra memory is well suited to high‑resolution capture and large image buffers.
OpenMV Cam H7 Plus
For full datasheet, photos, and dimensions see the OpenMV Cam H7 Plus product page.
  • STMicroelectronics STM32H743 Cortex‑M7 at 480 MHz (1027 DMIPS).
  • 32 MB external SDRAM (32‑bit @ 100 MHz, 400 MB/s) plus 1 MB internal SRAM.
  • 2 MB internal flash + 32 MB external QSPI flash (~100 MB/s read).
  • OV5640 5MP rolling‑shutter sensor.
  • LiPo battery connector (no on‑board charger — supply a charged cell or run from VIN/USB).
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The H7 Plus has no on‑board power management chip: there’s no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Connect a pre‑charged LiPo to the battery JST or run the board from USB / VIN.
digital I/O
frame‑sync pad — wired to the camera sensor only
The SYN pad on the header is connected directly to the camera sensor’s trigger / exposure line — it does not route to the MCU on the H7 Plus. Drive or read it externally; you can’t toggle it from MicroPython.
Power pins#
A 3.7 V LiPo connector is also present, but the H7 Plus does not have a battery charger — connect a pre‑charged cell, or supply VIN / USB instead.
When both USB and VIN/LiPo are present, the VIN/LiPo input wins — the on‑board power switch picks it over USB to power the board.
The battery connector and VIN are tied together on the H7 Plus. Do not plug in a LiPo and apply VIN at the same time — the two supplies will fight each other and can damage the battery, the board, or both.
You may power the H7 Plus by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the H7 Plus will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
The board exposes an SWD debug header (RST / SWCLK / SWDIO / SWO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters.
The SWO trace pin is shared with the camera header’s SPI clock line. SWO can’t be used at the same time as any camera module that communicates with the MCU over SPI — for example the FLIR® Lepton® Adapter Module — pick one or the other.
Onboard peripherals#
LEDs#
The H7 Plus has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor#
The OV5640 is driven through the csi — camera sensors module:
The OV5640 has an on-board JPEG compressor. Set csi.CSI.pixformat to csi.JPEG and the sensor delivers compressed frames straight to the cam over the camera bus, which makes high-resolution captures practical: csi.HD (1280×720), csi.FHD (1920×1080), and the full 5MP csi.WQXGA2 (2592×1944) all stream as JPEG. Tune the compression with csi.CSI.quality (0-100, higher = larger frames, more detail):
Machine learning#
ml — Machine Learning runs quantised TFLite models on the Cortex‑M7 with CMSIS‑NN kernels — fast enough for compact detectors at a few frames per second. Models on the read‑only /rom filesystem load directly from flash without copying to RAM. Here’s a 128×128 BlazeFace detector overlaying the detected face and its six landmarks on every frame:
microSD card#
Bus reference#
GPIO#
UART#
I²C#
SPI#
CAN (FDCAN)#
ADC and DAC#
PWM#
Timer / channel
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8 with pyb.Servo in the same script.
Software bit‑banged buses#
Thermal sensor (off‑board)#
Timing#
time#
Virtual timers#
Real‑time clock#
Watchdog#
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The H7 Plus firmware mounts up to three filesystems on boot:
Storage sizes#
The H7 Plus ships with:
  • /flash — 24 MB FAT filesystem, read/write.
  • /rom — 8 MB read-only memory-mapped ROMFS, used to ship scripts and ML models that benefit from zero-copy mmap access.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the H7 Plus build.
