OpenMV Cam H7#
The OpenMV Cam H7 is a Cortex‑M7 machine‑vision board built around the STMicroelectronics STM32H743 at 480 MHz with 1 MB of internal SRAM, 2 MB of internal flash, and a hardware JPEG codec. The board ships in two sensor revisions — the H7 with the OV7725 and the H7 R2 with the ON Semi MT9M114 — but the firmware, pinout, and Python API are identical.
OpenMV Cam H7
For full datasheet, photos, and dimensions see the OpenMV Cam H7 product page.
  • STMicroelectronics STM32H743 Cortex‑M7 at 480 MHz (1027 DMIPS).
  • 1 MB internal SRAM — no external SDRAM.
  • 2 MB internal flash (no external QSPI flash).
  • OV7725 sensor (or MT9M114 on the H7 R2).
  • LiPo battery connector (no on‑board charger — supply a charged cell or run from VIN/USB).
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The H7 has no on‑board power management chip: there’s no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Connect a pre‑charged LiPo to the battery JST or run the board from USB / VIN.
OpenMV Cam H7 OV7725 Pinout
TIM4 CH3
frame‑sync pad — wired to the camera sensor only
The SYN pad on the header is connected directly to the camera sensor’s trigger / exposure line — it does not route to the MCU on the H7. Drive or read it externally; you can’t toggle it from MicroPython.
Power pins#
A 3.7 V LiPo connector is also present, but the H7 does not have a battery charger — connect a pre‑charged cell, or supply VIN / USB instead.
When both USB and VIN/LiPo are present, the VIN/LiPo input wins — the on‑board power switch picks it over USB to power the board.
The battery connector and VIN are tied together on the H7. Do not plug in a LiPo and apply VIN at the same time — the two supplies will fight each other and can damage the battery, the board, or both.
You may power the H7 by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the H7 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
The board exposes an SWD debug header (RST / SWCLK / SWDIO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters.
Onboard peripherals#
LEDs#
The H7 has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor#
The OV7725 (or MT9M114 on the H7 R2) is driven through the csi — camera sensors module:
microSD card#
Bus reference#
GPIO#
UART#
I²C#
SPI#
CAN (FDCAN)#
ADC and DAC#
PWM#
Timer / channel
TIM4 CH3
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8/P9 with pyb.Servo in the same script.
Software bit‑banged buses#
Thermal sensor (off‑board)#
Timing#
time#
Virtual timers#
Real‑time clock#
Watchdog#
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The H7 firmware mounts up to three filesystems on boot:
Storage sizes#
The H7 ships with:
  • /flash — 128 KB FAT filesystem, read/write.
  • /rom — 128 KB read-only memory-mapped ROMFS.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the H7 build.
