OpenMV Cam M4#
The OpenMV Cam M4 is a compact Cortex‑M4 machine‑vision board built around the STMicroelectronics STM32F427 at 180 MHz with 256 KB of internal SRAM and 1 MB of internal flash. The bundled OV7725 sensor captures 320×240 grayscale or RGB565 frames, and the 9‑pin user header exposes UART, I²C, SPI, CAN, ADC/DAC, and PWM peripherals.
The OV7725 was the standard sensor on production M4 boards. Very early variants of the M4 shipped with the OmniVision OV2640 instead — same QVGA preview pipeline, but the OV2640 can also capture up to UXGA (1600×1200) JPEG frames. Both sensors are driven through the same csi — camera sensors API.
OpenMV Cam M4
For full datasheet, photos, and dimensions see the OpenMV Cam M4 product page.
  • STMicroelectronics STM32F427 Cortex‑M4 at 180 MHz.
  • 256 KB internal SRAM — no external SDRAM.
  • 1 MB internal flash (no external QSPI flash).
  • OV7725 sensor (or OV2640 on very early M4 variants) — 320×240 8‑bit grayscale or RGB565; the OV2640 can additionally capture up to UXGA (1600×1200) JPEG.
  • 9 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The M4 has no on‑board power management chip: there’s no battery connector, no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Power the board from USB or VIN.
OpenMV Cam M4 OV7725 Pinout
SPI2 MOSI
SPI2 MISO
SPI2 SCK / CAN2 TX
SPI2 NSS (CS) / CAN2 RX
SWCLK
ARM SWD clock (debugger access)
SWDIO
ARM SWD data (debugger access)
Power pins#
When both USB and VIN are present, whichever has the higher voltage powers the board — the on‑board diodes simply pick the stronger rail.
You may power the M4 by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the M4 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
SWCLK and SWDIO are broken out as ordinary header pins (not a dedicated SWD connector). Wire RESET, SWCLK, SWDIO, GND, and 3.3 V to an ST‑LINK or SEGGER J‑Link adapter to debug the board.
Onboard peripherals#
LEDs#
The M4 has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor#
The bundled sensor (OV7725 on standard boards, OV2640 on very early variants) is driven through the csi — camera sensors module:
The sensor is soldered to the board on the M4 — it is not on a swappable module.
On OV7725 boards the sensor’s FSIN (frame‑sync) pin is wired to the MCU but firmware support for it has not been added.
On OV2640 boards the sensor’s STROBE, FREX (frame exposure), and EXPST (exposure reset) pins are wired to the MCU but firmware support for them has not been added.
Servo headers#
The back side of the board has two servo connector solder pads that break out the standard 3‑pin servo header (signal / VIN / GND) for P7 and P8. The signal pins map straight to TIM4 channels 1 and 2 (the same channels used by pyb.Servo), and the V+ pin on each header is wired directly to VIN, so the servos draw their current from the input rail rather than the 3.3 V regulator.
Solder a pair of right‑angle 3‑pin headers into the pads and connect two hobby servos to drive a pan‑and‑tilt mount:
from pyb import Servo
pan.angle(0)
tilt.angle(0)
microSD card#
Bus reference#
GPIO#
UART#
I²C#
SPI#
CAN#
CAN2
ADC and DAC#
PWM#
Timer / channel
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8 with pyb.Servo in the same script.
Software bit‑banged buses#
Thermal sensor (off‑board)#
Timing#
time#
Virtual timers#
Real‑time clock#
Watchdog#
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The M4 firmware mounts up to three filesystems on boot:
Storage sizes#
The M4 ships with:
  • /flash — 32 KB FAT filesystem, read/write.
  • /rom — 128 KB read-only memory-mapped ROMFS.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the M4 build.
