OpenMV Cam M7#
The OpenMV Cam M7 is a Cortex‑M7 machine‑vision board built around the STMicroelectronics STM32F765 at 216 MHz with 512 KB of internal SRAM and 2 MB of internal flash. The bundled OV7725 sensor captures 640×480 grayscale or 320×240 RGB565 frames at up to 150 FPS, and the 10‑pin user header exposes UART, I²C, SPI, CAN, ADC/DAC, and PWM peripherals.
OpenMV Cam M7
For full datasheet, photos, and dimensions see the OpenMV Cam M7 product page.
  • STMicroelectronics STM32F765 Cortex‑M7 at 216 MHz.
  • 512 KB internal SRAM — no external SDRAM.
  • 2 MB internal flash (no external QSPI flash).
  • OV7725 sensor — 640×480 grayscale or 320×240 RGB565 at up to 150 FPS.
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The M7 has no on‑board power management chip: there’s no battery connector, no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Power the board from USB or VIN.
OpenMV Cam M7 OV7725 Pinout
SPI2 SCK / CAN2 TX
SPI2 NSS (CS) / CAN2 RX
TIM4 CH3
frame‑sync pad — wired to the camera sensor only
The SYN pad on the header is connected directly to the camera sensor’s trigger / exposure line — it does not route to the MCU on the M7. Drive or read it externally; you can’t toggle it from MicroPython.
Power pins#
When both USB and VIN are present, whichever has the higher voltage powers the board — the on‑board diodes simply pick the stronger rail.
You may power the M7 by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the M7 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
The board exposes an SWD debug header (RST / SWCLK / SWDIO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters.
Onboard peripherals#
LEDs#
The M7 has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor#
The OV7725 is driven through the csi — camera sensors module:
The sensor is soldered to the board on the M7 — it is not on a swappable module.
microSD card#
Bus reference#
GPIO#
UART#
I²C#
SPI#
CAN#
CAN2
ADC and DAC#
PWM#
Timer / channel
TIM4 CH3
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8/P9 with pyb.Servo in the same script.
Software bit‑banged buses#
Thermal sensor (off‑board)#
Timing#
time#
Virtual timers#
Real‑time clock#
Watchdog#
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The M7 firmware mounts up to three filesystems on boot:
Storage sizes#
The M7 ships with:
  • /flash — 96 KB FAT filesystem, read/write.
  • /rom — 256 KB read-only memory-mapped ROMFS.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the M7 build.
