OpenMV N6#
The OpenMV N6 is built around the STMicroelectronics STM32N657 (Cortex‑M55 @ 800 MHz) with a 1 GHz on‑chip NPU rated at 600 GOPS INT8. The board pairs the NPU with the PAG7936 1 MP global‑shutter sensor on a removable carrier, gigabit Ethernet, USB‑C high‑speed, Wi‑Fi, and Bluetooth 5.1, and runs YOLOv8/YOLOv11 inference at 30 FPS alongside live video streaming.
OpenMV N6
For full datasheet, photos, and dimensions see the OpenMV N6 product page.
  • STM32N657 Cortex‑M55 at 800 MHz (1280 DMIPS) with ARM Helium 128‑bit SIMD — 6.4 gigaops vector throughput.
  • 1 GHz NPU, 600 GOPS INT8 — runs YOLOv8/YOLOv11 detection at 30 FPS.
  • ISP for up to 5MP RAW Bayer, 2D GPU for scaling and 3D rotation, H.264 encode to 1080p, and hardware JPEG codec.
  • 64 MB external SDRAM (16‑bit @ 200 MHz DDR, 800 MB/s) plus 4.2 MB internal SRAM and 32 MB octal flash (200 MHz DDR, 400 MB/s).
  • PAG7936 1 MP color global‑shutter sensor.
  • Onboard IMU (accelerometer + gyroscope) and microphone for audio + motion fusion.
  • High‑speed USB‑C (480 Mb/s, 1.5 A current limit), gigabit Ethernet (PoE‑capable via shield), Wi‑Fi a/b/g/n + Bluetooth 5.1 (chip antenna or U.FL option).
  • LiPo charger (500 mA fast charge), battery‑voltage ADC, RTC with 8 KB backup RAM and a dedicated backup‑battery pin.
  • 18 I/O pins, all 3.3 V output / 3.3 V tolerant, 20 mA per pin, interrupt‑capable.
  • User RGB LED, user button, and a separate status LED for charging / USB / VIN power.
The N6’s I/O pins are not 5 V tolerant. Do not connect the device directly to a 5 V MCU like the Arduino Mega. Power the N6 through VIN only.
OpenMV N6 PAG7936 Pinout
SPI2 MOSI / I2S2 SDO
SPI2 MISO / I2S2 SDI
TIM12 CH1 (no ADC on this pin — see P6_ADC)
P6_ADC
dedicated 12‑bit ADC input (tied internally to P6)
TIM17 CH1
TIM15 CH2 / frame sync I/O
wakeup (active low, WKUP3)
P12
RESET — pull to GND to reset the board (not a GPIO)
UART7 RX
UART7 TX
P15
SPI4 CS
P16
SPI4 SCK
P17
SPI4 MISO
P18
SPI4 MOSI
user button (active low)
ONOFF (SW2)
deep‑sleep wakeup button (active low, WKUP2)
ST
low on VIN power, high on USB power
CHG
active‑low; low while an attached LiPo battery is charging
PG
active‑low; low when VIN or USB power is present
BAT_ADC
internal ADC channel measuring the attached LiPo battery voltage
The P10 frame‑sync line is a shared bus. It is wired to the MCU, the camera sensor’s trigger / exposure pin, and the user header all at once. Direction is application‑defined — the MCU, the sensor, or an external signal can drive it depending on how the sensor is configured (some sensors can use the same pin as a trigger input or an exposure output). Make sure only one driver is active at a time.
ONOFF and P11 are referenced to the always‑on RAW rail (not the switched 3.3 V rail), so they remain functional while the rest of the board is in deep sleep / low‑power mode. Both inputs are active low.
These pins go through level shifters so they can ride on the RAW rail. If you absolutely need 3.3 V‑direct GPIO behaviour on ONOFF or P11 (for example to drive them from a 3.3 V MCU without going through the shifter), the board exposes pull‑up and 0‑ohm jumper pads that let you bypass the shifter. This is an advanced hardware rework — most users should leave it alone.
P15–P18 are shared with the Gigabit Ethernet PHY, which is wired up and active by default. To use these pins as user I/O you must reflow the 0‑ohm resistor on the back of the board over to the GPIO position. This only disables gigabit Ethernet — 10/100 Mb/s Ethernet keeps working on its dedicated pins.
Power pins#
  • 3.3V — regulated 3.3 V rail. Output only on the N6 — do not feed external power into this pin. Up to 1 A available for shields.
  • VIN — 5 V input. Powers the board and the on‑board LiPo charger.
  • RAW — input/output, always‑on (3.6 V – 5 V). Carries whichever source is active (VIN, USB, or attached battery), and can also be used as an input. You must drive RAW through a series diode when sourcing power into it — otherwise current will flow back into VIN/USB and damage the supply or the on‑board protection.
The on‑board power management chip automatically picks whichever of USB or VIN has the higher voltage to power the board and the battery charger. If a LiPo is attached it charges on the leftover headroom, and the controller falls back to the battery to keep the board running if VIN/USB sag or are unplugged.
The back of the board has solder pads for an external 3.3 V RTC backup battery. Wiring a coin cell to these pads keeps the RTC and 8 KB of backup RAM running while the rest of the board is unpowered.
Use the battery life estimator to model how long the N6 will run on a battery for a given active / deep-sleep duty cycle.
Ethernet pins#
The N6 exposes the Ethernet PHY’s MDI pairs on dedicated pads next to the GPIO header. The MDI pins are not safe to wire straight to an RJ45 — Ethernet magnetics (an isolation transformer, either built into a magjack or on the shield) are required between the PHY and the cable. The OpenMV PoE shield includes them; if you’re rolling your own jack, use a magnetics‑integrated RJ45 or an external transformer.
  • ETH_LED — link/activity LED. Active low when a link is up; flashes on traffic.
  • DA P / DA N — pair A (TX in 10/100, used by all speeds).
  • DB P / DB N — pair B (RX in 10/100, used by all speeds).
  • DC P / DC N — pair C, only used at gigabit.
  • DD P / DD N — pair D, only used at gigabit.
10/100 Mb/s only needs pairs A and B. Gigabit needs all four pairs A–D.
Recovery and debug pins#
  • BOOT0 — pull to 3.3 V while powering the board to enter ROM bootloader mode. OpenMV IDE uses this mode to reflash the on‑board bootloader.
  • BOOT1 — switch that puts the board into developer mode for use with ST’s tooling (an ST‑LINK attached to the ARM 10‑pin SWD/JTAG header). Leave this disabled for normal operation with OpenMV firmware and tools.
A dedicated ARM 10‑pin SWD/JTAG header is fitted, compatible with ST‑LINK and SEGGER J‑Link adapters.
Onboard peripherals#
LEDs#
The N6 has two RGB LEDs:
  • Power LED — driven directly by the on‑board power management hardware, no software control. Use it to read what the supply is doing at a glance.
    While running:
    Channel
    Meaning
    Blue
    VIN is powering the board (off on USB)
    Green
    USB or VIN power present
    Red
    charging an attached LiPo battery
    In deep sleep all channels are off except Red, which still lights while a LiPo is charging.
User buttons#
The N6 has two buttons:
  • SW — general‑purpose user button. Active when pulled low.
  • ONOFF (SW2) — wakeup button. The only button that can bring the board out of deep sleep.
To put the board into deep sleep and have ONOFF (SW2) wake it back up, just call machine.deepsleep() — no wakeup configuration is required, the button is wired straight to the WKUP2 input:
You can also wire ONOFF up as a soft power switch. Trigger on the rising edge — the line settles high after the user releases the button, so the next press is unambiguously a wake event:
def power_off(_):
    machine.deepsleep()
# press it again to wake.
Power status pins#
Three active‑low status inputs let firmware see what the on‑board power management chip is doing:
  • ST — low when the board is running on VIN, high when running on USB power.
  • CHG — low while an attached LiPo battery is charging.
  • PG — low when VIN or USB power is present.
Camera sensor#
The PAG7936 is driven through the csi — camera sensors module:
The PAG7936 supports triggered mode — pixel integration lines up exactly with each csi.CSI.snapshot call rather than the free-running frame clock, useful for syncing capture to an external event or another sensor. Enable it through csi.CSI.ioctl with csi.IOCTL_SET_TRIGGERED_MODE. Frame rate drops to roughly half of free-running mode because the readout no longer pipelines with the next frame’s integration:
NPU#
The N6’s 1 GHz Neural‑ART NPU (600 GOPS INT8) is exposed through the ml — Machine Learning module. Models stored on the read‑only /rom filesystem load directly from flash without copying to RAM, so even large detectors fit comfortably alongside the live framebuffer. Run a YOLOv8 detector on every frame and draw the predictions on top of the live image:
# Visualization parameters.
n = len(model.labels)
model_class_colors = [
    for i in range(n)
    boxes = model.predict([img])
Microphone#
The on‑board mic is captured through audio — Audio Module. Each buffer arrives as a signed‑16‑bit PCM bytearray, which makes it trivial to feed into ulab/numpy for quick DSP. A simple loudness detector — print whenever the RMS volume crosses a threshold:
IMU#
The on‑board accelerometer + gyroscope under the camera module is exposed through imu — imu sensor:
Wi‑Fi#
The on‑board CYW43439 is exposed via network — network configuration as a station interface. After connecting, ipconfig("addr4") returns the (ip, netmask) pair:
Bluetooth#
The same CYW43439 also exposes Bluetooth 5.1. Use aioble — Async BLE for asyncio‑friendly BLE — for example, advertise as a peripheral and wait for a central to connect:
Ethernet#
When an RJ45 (with magnetics) is connected to the MDI pads, the gigabit PHY appears as a LAN interface. DHCP runs automatically once the link comes up:
microSD card#
Bus reference#
GPIO#
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS and can sink/source up to 20 mA per pin.
UART#
UART7
I²C#
SPI#
SPI4
P18
P17
P16
P15
CAN#
CAN1
can = CAN(1, 500_000)
ADC#
Both ADC channels go through an op‑amp buffered voltage divider before hitting the MCU, so read_u16() is mapped to a different full‑scale input voltage on each pin.
Full‑scale
Notes
P6_ADC
~3.3 V
general‑purpose pad, tied internally to P6
BAT_ADC
~5.0 V
internal channel for the LiPo battery
adc = ADC("P6_ADC")
bat = ADC("BAT_ADC")
PWM#
Timer / channel
TIM12 CH1
TIM17 CH1
TIM15 CH2
Software bit‑banged buses#
Thermal sensor (off‑board)#
Timing#
time#
Virtual timers#
Real‑time clock#
machine.RTC keeps wall‑clock time across resets and (with the optional 3.3 V backup battery wired to the rear pads, see Power pins) across full power loss:
The RTC also runs through deep sleep, so you can use it as a wakeup source for machine.deepsleep().
Watchdog#
Boot and runtime info#
USB bootloader window#
Filesystem and boot order#
The N6 firmware mounts up to three filesystems on boot:
Storage sizes#
The N6 ships with:
  • /flash — 4 MB FAT filesystem, read/write.
  • /rom — 24 MB read-only memory-mapped ROMFS, used to ship scripts and ML models that benefit from zero-copy mmap access.
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the N6 build.
