Battery Shield#
The Battery Shield powers OpenMV Cams from a 1.8-5.5 V source through a 2.1 mm DC barrel jack, making it ideal for alkaline-battery deployments. It also accepts a wide 6-36 V input with reverse-voltage protection.
Battery Shield
For full datasheet, photos, and ordering see the Battery Shield product page.
  • 1.8-5.5 V DC barrel jack input for battery deployments
  • 6-36 V wide input with reverse-voltage and surge protection
  • 0-6 V ADC input on P6 for monitoring the DC barrel jack voltage
Use the battery life estimator to model how long an OpenMV Cam powered through this shield will run on a given battery for a given active / deep-sleep duty cycle.
Battery Shield Pinout
0–6 V ADC input (level-shifted to 0–2.8 V on P6) for monitoring the DC barrel jack voltage
BARREL in
1.8–5.5 V input on the DC barrel jack
PWR in
RAW out
3.5 V at up to 800 mA — direct from the barrel jack
5.6 V at up to 600 mA — regulated from the wide input via OR’ing diode
3.3V rail
GND rail
Common ground
The barrel-jack voltage divider feeds P6 through a 0-ohm resistor on the back of the shield. Remove the resistor to free P6 for unrelated use.
A single 0-ohm resistor on the back of the shield selects whether the DC barrel jack feeds RAW out (default) or VIN out — move the resistor to the other pad pair to switch. Useful for legacy OpenMV Cams that take their power on VIN rather than RAW.
Usage#
Read the DC barrel jack voltage on P6 (the shield level-shifts 0–6 V down to 0–2.8 V before driving the pin):
barrel = ADC("P6")
