QWIIC Shield#
The QWIIC Shield gives the OpenMV Cam two daisy-chainable Qwiic (JST-SH 4-pin) connectors wired to its I2C pins, so SparkFun Qwiic ecosystem boards can plug straight in.
For full datasheet, photos, and ordering see the QWIIC Shield product page.
Two Qwiic JST-SH connectors for daisy-chaining I2C peripherals
Routes the OpenMV Cam’s P4 (SCL) and P5 (SDA) pins
Compatible with the SparkFun Qwiic ecosystem
No on-board pull-ups (use software pull-ups or external)
Pin | Function |
P4 | Qwiic SCL — I²C clock to both Qwiic connectors |
P5 | Qwiic SDA — I²C data to both Qwiic connectors |
3.3V rail | Powers connected Qwiic devices |
GND rail | Common ground (also routed to both Qwiic connectors) |
Usage#
Scan for connected Qwiic devices on the I²C bus. The shield does not fit pull-up resistors on board — enable internal pull-ups in software, or rely on pull-ups built into the connected Qwiic boards:
freq=100_000)
