Servo Shield#
The Servo Shield drives up to eight hobby servos in parallel from the OpenMV Cam over I2C, using a PCA9685 servo / PWM controller.
Servo Shield
For full datasheet, photos, and ordering see the Servo Shield product page.
  • PCA9685 servo / PWM controller
  • Eight independent servo channels over I2C
  • Stacks with the Motor Shield and Pan and Tilt Shield
Servo Shield Pinout
I²C SCL — clock to the PCA9685
I²C SDA — data to the PCA9685
VIN rail
Powers the servos (from the camera’s VIN pin)
3.3V rail
Powers the PCA9685 logic
GND rail
Servo and camera common ground
The default I²C address is 0x40. Connect the on-board solder bridge to move the address to 0x60.
The shield draws servo power straight from the camera’s VIN pin. USB does not feed VIN on any OpenMV Cam, so VIN must be supplied externally (battery, bench supply, or similar) — pick a source rated for the combined stall current of every servo you plan to drive.
Usage#
Drive the eight servo channels through the PCA9685 over I²C. The pulse-width range varies between servos, so tune MIN_US and MAX_US to match yours — typical values are around 1000–2000 µs:
class PCA9685:
        self._bus = bus
        self._addr = address
        time.sleep_us(5)
        if duty == 0:
        elif duty == 0xFFF:
            on, off = 0, duty
        self._bus.writeto_mem(
def angle(channel, deg):
    for ch in range(8):
        angle(ch, 0)
    time.sleep_ms(2000)
    for ch in range(8):
        angle(ch, 180)
    time.sleep_ms(2000)
The PCA9685 also handles general 12-bit PWM at any frequency — reuse the same class with set_duty (0–4095) to, for example, fade an LED on channel 0 at 1 kHz. The helper below scales a 0.0–100.0% float onto the chip’s 0–4095 duty range:
def brightness(channel, pct):
    # Ramp up 0 → 100%.
    for pct in range(101):
        brightness(0, float(pct))
        time.sleep_ms(20)
    # Ramp down 100 → 0%.
        time.sleep_ms(20)
