Thermopile Shield#
The Thermopile Shield gives the OpenMV Cam a 16x4 thermal-sensor array over I2C for low-resolution thermal imaging and per-pixel temperature measurement.
Thermopile Shield
For full datasheet, photos, and ordering see the Thermopile Shield product page.
  • 16x4 thermal sensor array, 60 deg x 16 deg field of view
  • Object temperatures from -50 C to 300 C
Thermopile Shield Pinout
I²C SCL — clock to the thermopile array
I²C SDA — data to the thermopile array
3.3V rail
Powers the thermopile
GND rail
Common ground
Usage#
Capture a heat-map from the on-board thermopile array via the fir module:
fir.init()
Read the raw per-pixel temperatures as a 16×4 ndarray of celsius floats. fir.read_ir() also returns the ambient temperature and the min/max seen in the frame:
fir.init()
w = fir.width()
h = fir.height()
