Touch LCD Shield#
The Touch LCD Shield gives the OpenMV Cam a 2.3 inch 320x240 capacitive multi-touch display so you can preview the camera output (and accept input) without a host computer. Two Qwiic headers make it easy to chain extra I2C devices.
For full datasheet, photos, and ordering see the Touch LCD Shield product page.
2.3 inch TFT LCD, 320x240, 16-bit RGB565
Capacitive multi-touch input
PWM-controllable backlight
Two Qwiic connectors for easy I2C device chaining
Pin | Function |
P0 | LCD MOSI (SPI data to display) |
P1 | LCD TE (tearing-effect output) |
P2 | LCD SCLK (SPI clock) |
P3 | LCD SSEL (SPI chip select) |
P4 | Touch / Qwiic SCL (I²C clock — shared with Qwiic headers) |
P5 | Touch / Qwiic SDA (I²C data — shared with Qwiic headers) |
P6 | LCD backlight |
P7 | Touch / LCD RESET_N |
P8 | LCD RS (data / command select) |
P9 | Touch INT_N |
3.3V rail | Powers the LCD and touch controllers |
GND rail | Common ground |
Usage#
Drive the shield through the display.SPIDisplay class. Stream camera frames to the 320×240 LCD:
height=240,
bgr=True,
vflip=False,
hmirror=False)
Drive the backlight via PWM for adjustable brightness. Wrap machine.PWM in a small backlight controller class and pass it to SPIDisplay through its backlight argument — SPIDisplay calls backlight(value) on the object whenever it needs to update the level:
class PWMBacklight:
def backlight(self, value):
def deinit(self):
self._pwm.deinit()
height=240,
bgr=True,
vflip=False,
hmirror=False,
backlight=PWMBacklight("P6"))
lcd.backlight(50) # 0–100
Read multi-touch input from the on-board FT6x36 capacitive controller — wired to the camera’s I²C bus on P4/P5 with reset on P7 and IRQ on P9. The example below pairs touch with live camera streaming, drawing a red circle on the LCD wherever a finger is pressed:
from time import sleep_ms
from array import array
_DEFAULT_ADDR = const(0x38)
_DEV_MODE = const(0x00)
_TD_STATUS = const(0x02)
class FT6X36:
FLAG_PRESSED = 0
FLAG_RELEASED = 1
FLAG_MOVED = 2
def __init__(
self,
bus,
reset_pin,
irq_pin,
address=_DEFAULT_ADDR,
width=320,
height=240,
reverse_x=False,
reverse_y=False,
touch_callback=None,
self.bus = bus
self.address = address
self.width = width
self.height = height
self.reverse_x = reverse_x
self.reverse_y = reverse_y
if reset_pin is not None:
self.rst_pin = None
self.irq_pin = None
self.irq_pin_label = irq_pin
self.reset()
self._touch_points_old = 0
self._touch_points = 0
if buf is not None:
if size == 1:
def reset(self):
if self.irq_pin is not None:
if self.rst_pin is not None:
self.rst_pin(0)
sleep_ms(1)
self.rst_pin(1)
sleep_ms(39)
self.irq_pin.irq(
handler=self.touch_callback,
trigger=Pin.IRQ_FALLING,
hard=False,
def read_points(self):
for i in range(0, n_points):
base = 1 + i * 6
if self.reverse_x:
x = self.width - 1 - x
if self.reverse_y:
y = self.height - 1 - y
self.points_data[i][0] = x
self.points_data[i][1] = y
for i in range(n_points, 2):
self._touch_points = n_points
height=240,
bgr=True,
vflip=False,
hmirror=False)
x, y, flag, tid = points[i]
iy = y - y_offset
if 0 <= iy < csi0.height():
img.draw_circle(
