TV Shield#
The TV Shield gives the OpenMV Cam an NTSC analog video output via a VS23S010 SPI-to-NTSC video generator, driving an on-board RCA jack so you can plug a composite video display straight into the camera.
For full datasheet, photos, and ordering see the TV Shield product page.
VS23S010 SPI-to-NTSC chip
352x240 NTSC SIF output at 60 Hz
On-board RCA jack for composite video
Pin | Function |
P0 | SPI MOSI — data to the VS23S010 |
P2 | SPI clock |
P3 | SPI chip select |
3.3V rail | Powers the VS23S010 |
GND rail | Common ground (also routed to the on-board RCA jack) |
The NTSC video output, VIN, and GND are also broken out to through-hole pads on the bottom of the shield — solder wires there to take the wired composite video signal off the board.
Usage#
Drive the shield through the TVDisplay class exposed by the display module. Stream camera frames out the RCA jack at 352×240 SIF:
csi0.framesize(csi.SIF)
tv = display.TVDisplay()
tv.write(csi0.snapshot())
