WiFi Shield#
The WiFi Shield adds 2.4 GHz Wi-Fi to OpenMV Cams that don’t have on-board networking, using the Atmel WINC1500 module. It plugs into the bottom of any OpenMV Cam header.
WiFi Shield
For full datasheet, photos, and ordering see the WiFi Shield product page.
Supported only on the OpenMV Cam, M4, M7, H7, and H7 Plus.
  • 2.4 GHz Wi-Fi b/g/n via the Atmel WINC1500 module
  • TLS 1.2 hardware crypto for HTTPS / MQTTS
WiFi Shield Pinout
SPI MOSI — data to the WINC1500 module
SPI MISO — data from the WINC1500 module
SPI clock
SPI chip select
Chip enable
Module reset
Module interrupt
3.3V rail
Powers the WINC1500 module
GND rail
Common ground
Usage#
Drive the shield through the network.WINC class. In the default station mode, connect to a Wi-Fi network and print the assigned IP:
SSID = "your-network"
KEY = "your-password"
wlan.connect(SSID, KEY)
    print("connecting...")
The shield can also run as a Wi-Fi access point — pass MODE_AP to the constructor and call start_ap() to bring the AP up:
The WINC1500’s AP implementation accepts only one client at a time and supports only OPEN and WEP security modes.
The WINC1500’s own firmware can be inspected and updated from the camera. Print the running firmware version with:
wlan = network.WINC()
The latest stable image (winc_19_7_6.bin) ships inside the OpenMV IDE at <openmv-ide-install-dir>/share/qtcreator/firmware/WINC1500/ and is compatible only with the newer ATWINC1500-MR210PB hardware. To flash it, copy the .bin to the camera’s SD card, eject the card so the FAT cache is flushed, reset the board, and run:
fw_dump() reads the current image back out to a file the same way. See the network.WINC class for the full method list.
