Arduino Nicla Vision
The Arduino Nicla Vision is a 22.86 × 22.86 mm machine‑vision board built around the STMicroelectronics STM32H747AII6 — a dual‑core SoC combining a Cortex‑M7 at 400 MHz with a Cortex‑M4 at 200 MHz. The OpenMV firmware runs entirely on the M7 core. The board pairs the MCU with the GC2145 2 MP colour CMOS sensor, an LSM6DSOX 6‑axis IMU, an MP34DT06 MEMS microphone, a VL53L1CB time‑of‑flight ranger, Wi‑Fi + Bluetooth LE 5.1, and a battery charger / fuel gauge.
For full datasheet, photos, and dimensions see the Arduino Nicla Vision product page.
Highlights
  • STMicroelectronics STM32H747AII6 dual Cortex‑M7 (400 MHz) + Cortex‑M4 (200 MHz). OpenMV firmware runs on the M7 core only.
  • 2 MB internal flash plus 16 MB external QSPI flash (used for the application + ROMFS).
  • 1 MB internal SRAM.
  • GC2145 2 MP colour CMOS sensor.
  • Onboard IMU (LSM6DSOX accelerometer + gyroscope), MEMS microphone (MP34DT06JTR), and VL53L1CB time‑of‑flight ranger (up to ~4 m).
  • High‑speed USB (480 Mb/s) over Micro USB through an external ULPI PHY (USB3320C).
  • 13 user I/O pins on the Arduino edge headers — four digital LPIOs (D0–D3), three 1.8 V analog inputs (A0–A2), the SCL/SDA I²C pair, and the SCLK/CIPO/COPI/CS SPI quartet.
  • Battery support — Li‑Po connector on the back, BQ‑style charger, and MAX17262 fuel gauge over the internal PMIC bus.
  • 5‑pin ESLOV connector on the back for solder‑free I²C expansion.
The user digital pins are 3.3 V by default but routed through software‑programmable level shifters (VDDIO_EXT) that can be reconfigured to 1.8 V. The analog pins (A0–A2) are 1.8 V only — they bypass the level shifters and connect directly to the MCU. Driving 3.3 V into A0–A2 will damage the SoC.
Arduino Nicla Vision Pinout
Pin reference
Thirteen user pins are exposed on the Arduino edge headers (J1 and J2). Additional debug, recovery, and PMIC signals are routed to test pads on the back of the board.
Reference
GPIO / LPIO0 (J1‑1)
GPIO / LPIO3 (J2‑5)
1.8 V
ADC1 channel 4 (J1‑8)
1.8 V
ADC2 channel 2 (J1‑7)
1.8 V
ADC3 channel 5 (J1‑2)
SCLK
SPI4 SCK / TIM1 CH3N (J1‑6)
CIPO
SPI4 MISO / TIM1 CH3 (J1‑5)
COPI
SPI4 MOSI / TIM1 CH4 (J1‑4)
SPI4 NSS / TIM1 CH2 (J1‑3)
pull to GND (or press the on‑board switch) to reset the board
D0–D3 and SCLK/CIPO/COPI/CS sit behind the TXB0108 bidirectional level shifter — that part only supports push‑pull GPIO drive, so open‑drain bus traffic (e.g. a bit‑banged 1‑Wire or I²C on those pins) won’t work.
SCL/SDA sit behind a separate NTS0304 shifter that supports both push‑pull and open‑drain drive, which is why I²C 1 works there.
Both shifters are referenced to VDDIO_EXT (3.3 V by default from the on‑board PMIC), and their drive strength is limited compared with a direct GPIO — they are designed for signal‑level rather than power loads.
Power pins
Edge‑header pins:
  • VIN (J2‑9) — main 3.6 – 5 V system rail. The PMIC takes its input here.
  • VDDIO_EXT (J2‑7) — output of the level‑shifter rail, 1.8 V or 3.3 V (3.3 V by default). Use this to power external 1.8 V or 3.3 V peripherals attached to the LPIO/SPI/I²C pins so they speak the same logic level as the headers.
  • VBAT (J3‑2) — Li‑Po battery input. The on‑board PMIC charges the cell from VIN and reports state of charge through the fuel gauge.
  • NTC (J3‑1) — optional Li‑Po thermistor input.
  • GND (J2‑6) — common ground.
  • NC (J2‑8) — no connect.
Test pads on the back of the board:
  • +3V3 — main 3.3 V rail.
  • D_P / D_N — USB high‑speed data pair (post‑PHY).
USB and the ESLOV connector both feed VIN through a pair of LM66100 ideal diodes (one per source), so either supply can power the board on its own and the two never back‑drive each other. If you drive VIN externally on J2‑9, that takes precedence — the diodes simply stop conducting from USB / ESLOV once the external rail rises higher.
The board can therefore be powered through any of these paths:
  • Micro USB — 5 V into VIN through the USB‑side ideal diode.
  • ESLOV connector — up to 5 V on the VESLOV pin of J5, routed into VIN through the ESLOV‑side ideal diode (see ESLOV connector).
  • VIN pin (J2‑9) — drive a regulated 3.6 – 5 V supply directly.
  • Li‑Po battery — connect to the J4 battery connector on the back or to the VBAT/GND/NTC pads on J3 / J2‑6. Do not connect two batteries simultaneously.
ESLOV connector
J5 on the back of the board is a 5‑pin Molex solder‑free ESLOV connector:
Name
J5‑1
VESLOV
power input (≤ 5 V) — OR’d into VIN via an LM66100 ideal diode
J5‑2
INT
external interrupt input on PD9
J5‑3
SCL_EXT
shared with the J2 SCL pad — same I²C 1 bus as the user header
J5‑4
SDA_EXT
shared with the J2 SDA pad — same I²C 1 bus as the user header
J5‑5
common ground
ESLOV’s SCL_EXT/SDA_EXT and J2’s SCL/SDA are the same pins — one I²C 1 bus exposed on two connectors.
Use the battery life estimator to model how long the Nicla Vision will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins
  • RESET — both a momentary switch on top of the board and a pad (J3‑4 / test pad P5) tied to the SoC’s NRST line. Pull to GND to reset.
The Nicla Vision uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader — quickly press the reset button twice and the board enumerates as a DFU device. OpenMV IDE uses this mode to reflash the firmware.
The STM32 SWD signals are exposed on the back of the board through a row of test pads between the two J2 headers. Solder a 2.54 mm (100‑mil) header into them to attach an ST‑LINK or J‑Link adapter:
  • P1 / P2 — internal PMIC I²C bus on PF0 (SDA) and PF1 (SCL). This is machine.I2C(2) on the Nicla Vision and carries the PMIC, fuel gauge, and ToF traffic.
  • P3 — TMS / SWDIO (PA13)
  • P4 — TCK / SWCLK (PA14)
  • P5 — NRST
  • P6 — TDO / SWO (PB3)
  • P7 — +1V8 rail (the SoC’s I/O supply — also the right reference for the debug adapter).
  • P8 — VOTP_PMIC — factory programming only. Must be left unconnected.
All debug signals are 1.8 V referenced — the STM32H747’s I/O ring on this board runs from the +1V8 rail. Set your debug adapter for 1.8 V logic before connecting.
Onboard peripherals
The Nicla Vision has a single user RGB LED, software‑controllable through machine.LED:
A separate DL2 CHARGE LED on the side of the board is wired directly to the PMIC’s CHGB output — it lights while a Li‑Po battery is being charged from USB / ESLOV / VIN and is not user‑controllable.
Camera sensor
The GC2145 is driven through the csi — camera sensors module:
When you ask for a small framesize the GC2145 driver crops a proportionally small readout window from the sensor — by default the readout-to-output downscale ratio is capped at 3x to keep the frame rate up. csi.IOCTL_SET_FOV_WIDE raises that cap to 5x, which means the driver pulls from a wider area of the sensor when streaming small resolutions. The result is a noticeably wider field of view at small framesizes, at the cost of some throughput:
M4 core
Microphone
The on‑board MP34DT06JTR PDM microphone is captured through audio — Audio Module over the STM32’s DFSDM peripheral. Each buffer arrives as a signed‑16‑bit PCM bytearray, ready to feed into ulab/numpy for DSP — for example, a simple loudness detector:
The on‑board LSM6DSOX accelerometer + gyroscope is exposed through imu — imu sensor:
The IMU is wired to a dedicated internal SPI bus (SPI5) so it does not contend with the user SPI4 broken out on the headers.
Time‑of‑flight ranger
The on‑board ST VL53L1CB time‑of‑flight ranger sits on the internal PMIC I²C bus (I²C 2). Use the frozen vl53l1x — VL53L1X ToF distance sensor driver driver to get distance readings up to ~4 m:
import vl53l1x
tof = vl53l1x.VL53L1X(bus)
Battery fuel gauge
The Maxim MAX17262 ModelGauge m5 fuel gauge tracks the Li‑Po battery’s voltage, current, temperature, and state of charge. It sits on I²C 2 at address 0x36.
The MAX17262 has internal current sensing, so the current register reads out directly in microamps with no external Rsense factor to apply. Reading the fuel gauge is harmless — there is no driver shipped, but the registers documented in the MAX17262 datasheet can be read directly:
import struct
def read_reg(bus, addr, reg):
    v = read_reg(bus, addr, reg)
bus = I2C(2)
    print()
Current is signed two’s-complement: positive while charging, negative while discharging. TTE is only meaningful when current is negative; TTF only when current is positive.
Power management IC
The NXP MC34PF1550A0EP PMIC handles every regulator on the Nicla Vision — the +3V3 main rail, the +1V8 SoC core / I/O rail, VDDIO_EXT to the level shifters, and the Li‑Po charger. It sits on I²C 2 at address 0x08.
Reading PMIC registers is fine; writing to them is dangerous. Misconfiguring a buck regulator or charger setting can permanently damage the board, the battery, or both. Treat the PMIC as read‑only unless you know exactly what you’re doing.
The most useful thing the PMIC tells you that the fuel gauge can’t is the charger state machine — whether the board is currently running on USB / ESLOV / VIN, what stage of the charge cycle the Li‑Po is in, and whether the charger is in a thermal or watchdog fault. The charger registers live at an offset of 0x80 in the PF1550’s main I²C address space (see §22.2 of the PF1550 datasheet), so for example CHG_INT_OK at charger address 0x04 is read from PMIC register 0x84:
PMIC = 0x08
CHG_STATES = {
    0x0: "precharge",
    0x3: "end of charge",
    0x4: "done",
    0x6: "timer fault",
    0x7: "thermistor suspend",
    0x9: "battery overvoltage",
    0xA: "thermal shutdown",
bus = I2C(2)
    print()
Other read‑only registers worth a look in the datasheet (all at charger‑offset 0x80): 0x80 CHG_INT (latched charger interrupts — fault flags), 0x86 VBUS_SNS (the multi‑bit VBUS state including OVLO / UVLO / DPM), and 0x88 BATT_SNS (battery presence and overcurrent state).
Bus reference
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS (default VDDIO_EXT) and the level shifters limit the per‑pin drive strength to a few milliamps — they are designed for signal‑level rather than power loads.
out = Pin("D0", Pin.OUT)
UART4 shares its pins with I²C 1 — the same SDA/SCL pads carry both buses. Pick UART or I²C, not both, on those pins.
The D1/D2 silkscreen also reads UART_TX/UART_RX, but on this firmware those pins are routed to LPUART1, not to machine.UART. machine.UART(1) itself is reserved for the on‑chip Bluetooth controller and is not accessible on the headers.
The SCL/SDA pads on J2 and the ESLOV connector’s SCL_EXT/SDA_EXT pins land on the same I²C 1 bus — see ESLOV connector above for the ESLOV pinout.
SPI4
COPI
CIPO
SCLK
The Nicla Vision exposes three 12‑bit ADC channels on A0, A1, and A2. All three are 1.8 V referenced — read_u16 returns 0–65535 across 0–1.8 V at the pin:
The Nicla Vision’s ADC inputs are 1.8 V referenced (and have no level shifter in front of the SoC). Driving a 3.3 V signal in will saturate the converter and may damage the pin — divide higher voltages down externally.
Timer / channel
TIM1 CH3
TIM4 CH3, TIM16 CH1
TIM4 CH4, TIM17 CH1
SCLK
TIM1 CH3N
CIPO
TIM1 CH3
COPI
TIM1 CH4
Several pins share TIM1 channels:
  • TIM1 CH2 is on D1 and CS.
  • TIM1 CH3 is on D2 and CIPO; SCLK outputs the inverted complement (TIM1 CH3N) of the same channel.
  • TIM1 CH4 is on COPI alone.
Pick one consumer per timer channel. The SPI quartet pins (SCLK/CIPO/COPI/CS) also cannot be PWM‑driven while machine.SPI(4) is using them.
Software bit‑banged buses
Thermal sensor (off‑board)
The fir driver only talks to the sensor over I²C 1 — wire the module to the silkscreened SCL / SDA pads.
Timing
Virtual timers
Real‑time clock
Boot and runtime info
Firmware update (DFU)
The Nicla Vision uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader. Quickly press the reset button twice — the board re‑enumerates over USB as a DFU device and OpenMV IDE can flash a new firmware image.
Filesystem and boot order
The Nicla Vision firmware mounts up to two filesystems on boot:
When connected over USB, /flash also enumerates as a USB mass‑storage drive on the host, letting you edit boot.py, main.py, and any other files directly. Eject the drive before resetting the camera so the host flushes its cached writes.
Storage sizes
The Nicla Vision ships with:
Hard‑fault indicator
Software libraries
See the library index for the full list of modules — including which ones are unique to the Nicla Vision build.
