Arduino Portenta H7
The Arduino Portenta H7 is a 66 × 25 mm industrial dev board built around the STMicroelectronics STM32H747XI — a dual‑core SoC combining a Cortex‑M7 at 400 MHz with a Cortex‑M4 at 200 MHz. The OpenMV firmware runs entirely on the M7 core and is designed to be used with the Portenta Vision Shield (Ethernet or LoRa edition), which adds a Himax HM01B0 / HM0360 camera, dual PDM microphones, and a microSD slot to the base Portenta H7.
Arduino Portenta H7
For full datasheet, photos, and dimensions see the Arduino Portenta H7 product page.
Highlights
  • STMicroelectronics STM32H747XI dual Cortex‑M7 (400 MHz) + Cortex‑M4 (200 MHz). OpenMV firmware runs on the M7 core only; the M4 core is exposed through openamp for Inter‑Processor Communication.
  • 8 MB external SDRAM plus 2 MB internal flash and 16 MB external QSPI flash.
  • High‑speed USB‑C (480 Mb/s).
  • 22 user I/O pins on the Arduino MKR‑style top headers — D0–D14 (digital) plus A0–A6 (analog).
  • Two 80‑pin high‑density connectors on the bottom expose the full STM32H747 fabric — DCMI, DSI, Ethernet RMII, FDCAN, SDIO, SAI/I²S, UARTs, additional SPI/I²C/timers, and so on. Shields like the Vision Shield mate to these connectors.
  • JTAG / SWD broken out on the bottom HD connectors for advanced debug.
  • Battery support — 3.7 V Li‑Po JST connector plus on‑board charger and battery monitor.
Arduino Portenta H7 Pinout
Pin reference
22 user pins are exposed on the Arduino MKR‑style top edge headers — 15 digital (D0-D14) plus 7 analog (A0-A6). Many more SoC pins are available through the bottom 80‑pin high‑density connectors for shield work; see Arduino’s full pinout PDF for that mapping.
Reference
TIM8 CH3N
TIM1 CH1 / SPI5 NSS
TIM1 CH2 / SPI5 MISO
TIM1 CH1 / I2C3 SCL
TIM5 CH4 / SPI2 NSS
SPI2 MOSI (shared with A3 / A5)
SPI2 SCK
SPI2 MISO (shared with A2 / A4)
I2C3 SDA
I2C3 SCL
USART1 RX / TIM1 CH3
D14
USART1 TX / TIM1 CH2
ADC12 IN0 (analog only)
ADC12 IN1 (analog only)
ADC123 IN12 (analog only; shared with D10)
ADC12 IN13 (analog only; shared with D8)
A4
ADC123 IN12 (shared with D10)
A5
ADC12 IN13 (shared with D8)
A6
DAC1 OUT1 / ADC12 IN18
A7
TIM3 CH1 / ADC12 IN3 (not exposed on the headers)
D20
alias of D8 / A3 / A5
D21
alias of A6 — DAC1 OUT1
press the on‑board switch or pull to GND to reset
A0-A3 are analog-only pads on the STM32H747 with no GPIO function — treat them as ADC inputs only. A2/A4 and A3/A5 share their physical pins with D10 and D8 respectively, so you can’t drive PWM or SPI on those while reading them as analog. A7 lives on the bottom HD connectors.
Power pins
MKR header pins:
  • VIN — main system rail into the on‑board PMIC. Fed via a diode from the +5V rail, the MKR VIN pin, or the bottom 80‑pin HD connectors.
  • +5V — 5 V rail fed from USB, the ESLOV connector, or the MKR +5V pin itself.
  • +3V3 — main 3.3 V rail (PMIC switching regulator output).
  • AREF — analog voltage reference for the ADC pins. Defaults to 3.3 V; drive externally to use a different reference.
Battery input:
  • Li‑Po JST on the front of the board accepts a 3.7 V Li‑Po cell. The PMIC charges it whenever +5V or VIN is present.
The Portenta H7 can be powered through any of these paths:
  • USB‑C — supplies 5 V to the on‑board PMIC.
  • ESLOV connector — up to 5 V on VESLOV (see ESLOV connector).
  • VIN pin — drive a regulated 5 V supply directly.
  • Li‑Po battery — connect to the JST on the front.
ESLOV connector
On the side of the board is a 5‑pin solder‑free ESLOV connector:
Name
1
VESLOV
5 V power output (same rail as the MKR header’s +5V)
2
INT
external interrupt input on D7
3
SCL_EXT
shared with the MKR header D12 pad — same I²C 3 bus as the user header
4
SDA_EXT
shared with the MKR header D11 pad — same I²C 3 bus as the user header
5
common ground
ESLOV’s SCL_EXT/SDA_EXT and the MKR header’s D12/D11 are the same pins — one I²C 3 bus exposed on two connectors.
Use the battery life estimator to model how long the Portenta H7 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins
  • RESET — both an exposed pin on the top header and a momentary switch on the side of the board, tied to the SoC’s NRST line. Pull to GND or press the button to reset.
The Portenta H7 uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader. Quickly press the reset button twice — the board re‑enumerates over USB as a DFU device and OpenMV IDE can flash a new firmware image.
The STM32 SWD signals are exposed on the bottom HD connector J1:
  • J1‑73 — NRST
  • J1‑75 — SWDIO (PA13)
  • J1‑77 — SWCLK (PA14)
  • J1‑79 — SWO (PB3)
Wire them up via a Portenta Breakout, the official Arduino debug adapter, or a custom carrier with a 1.27 mm header. All debug signals are 3.3 V referenced.
When the Portenta Vision Shield is attached, the same SWD/JTAG signals are routed up to the standard 20‑pin ARM Cortex Debug JTAG header on the shield (1.27 mm / 0.05″ pitch).
Onboard peripherals
The Portenta H7 has a single user RGB LED, software‑controllable through machine.LED:
A separate orange charge LED next to the battery JST lights when the on‑board charger is sourcing current into a connected Li‑Po; it is not user‑controllable.
Camera sensor (Vision Shield)
With the Portenta Vision Shield (Ethernet or LoRa edition) attached, the Himax sensor is driven through the csi — camera sensors module:
cam.pixformat(csi.GRAYSCALE)
Two Vision Shield revisions are supported:
  • HM0360 — 640 × 480 monochrome.
While the Vision Shield camera is initialised, the following MKR header pins are claimed by the firmware and cannot be used:
MKR pin
Reason
TIM1 CH1 — camera master clock
TIM1 CH1 (alt) — camera master clock
I²C 3 SDA — shared with the camera; bus is usable but avoid the sensor’s I²C address (0x24)
I²C 3 SCL — shared with the camera; bus is usable but avoid the sensor’s I²C address (0x24)
A6 / D21
DCMI HSYNC — also disables the DAC
A7
DCMI PXCLK
Machine learning
ml — Machine Learning runs quantised TFLite models on the Cortex‑M7 with CMSIS‑NN kernels — fast enough for compact detectors at a few frames per second. Models on the read‑only /rom filesystem load directly from flash without copying to RAM. Here’s a 128×128 BlazeFace detector overlaying the detected face and its six landmarks on every frame from the Vision Shield camera:
csi0.pixformat(csi.GRAYSCALE)
csi0.window((240, 240))
M4 core
Microphone (Vision Shield)
The Vision Shield carries dual PDM microphones captured through audio — Audio Module over the STM32’s SAI4 peripheral. Each buffer arrives as signed‑16‑bit PCM bytearray, ready to feed into ulab/numpy for DSP — for example, a simple loudness detector:
Pass channels=2 to audio.init to receive interleaved samples from both mics.
Battery fuel gauge
The Maxim MAX17262 ModelGauge m5 fuel gauge tracks the Li‑Po battery’s voltage, current, temperature, and state of charge. It sits on I²C 1 at address 0x36.
The MAX17262 has internal current sensing, so the current register reads out directly in microamps with no external Rsense factor to apply. Reading the fuel gauge is harmless — there is no driver shipped, but the registers documented in the MAX17262 datasheet can be read directly:
import struct
def read_reg(bus, addr, reg):
    v = read_reg(bus, addr, reg)
bus = I2C(1)
    print()
Current is signed two’s-complement: positive while charging, negative while discharging. TTE is only meaningful when current is negative; TTF only when current is positive.
Power management IC
The NXP PF1550 PMIC handles every regulator on the Portenta H7 — the +3V3 main rail, the +1V8 SoC core / I/O rail, and the Li‑Po charger. It sits on I²C 1 at address 0x08.
Reading PMIC registers is fine; writing to them is dangerous. Misconfiguring a buck regulator or charger setting can permanently damage the board, the battery, or both. Treat the PMIC as read‑only unless you know exactly what you’re doing.
The most useful thing the PMIC tells you that the fuel gauge can’t is the charger state machine — whether the board is currently running on USB / ESLOV / VIN, what stage of the charge cycle the Li‑Po is in, and whether the charger is in a thermal or watchdog fault. The charger registers live at an offset of 0x80 in the PF1550’s main I²C address space (see §22.2 of the PF1550 datasheet), so for example CHG_INT_OK at charger address 0x04 is read from PMIC register 0x84:
PMIC = 0x08
CHG_STATES = {
    0x0: "precharge",
    0x3: "end of charge",
    0x4: "done",
    0x6: "timer fault",
    0x7: "thermistor suspend",
    0x9: "battery overvoltage",
    0xA: "thermal shutdown",
bus = I2C(1)
    print()
Other read‑only registers worth a look in the datasheet (all at charger‑offset 0x80): 0x80 CHG_INT (latched charger interrupts — fault flags), 0x86 VBUS_SNS (the multi‑bit VBUS state including OVLO / UVLO / DPM), and 0x88 BATT_SNS (battery presence and overcurrent state).
LoRa (Vision Shield)
The LoRa edition of the Vision Shield adds a Murata CMWX1ZZABZ LoRaWAN module wired to the Portenta H7 over UART. The lora module wraps the AT‑command firmware and supports OTAA or ABP join, uplink, and downlink:
from lora import Lora
from lora import BAND_EU868
appEui = "1234567890123456"
except LoraErrorTimeout as e:
lora.set_port(3)
    if lora.available():
        data = lora.receive_data()
        if data:
    lora.poll()
Use BAND_US915 / BAND_AS923 / BAND_AU915 etc. for non‑EU regions, and switch to lora.Lora.join_ABP() if your network server uses ABP activation.
While the LoRa module is in use, the driver claims the following MKR header pins as control lines for the Murata CMWX1ZZABZ — they cannot be used:
MKR pin
Reason
LoRa module BOOT pin
LoRa module RST pin
Ethernet (Vision Shield)
The Ethernet edition of the Vision Shield adds an RJ45 jack with magnetics wired to the STM32H747’s 10/100 Ethernet MAC over RMII. Plug in an Ethernet cable and the PHY appears as a LAN interface; DHCP runs automatically once the link comes up:
microSD card (Vision Shield)
Bus reference
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS and can sink/source up to 20 mA per pin (140 mA total across the whole header).
out = Pin("D0", Pin.OUT)
D14
UART6
I2C3
i2c = I2C(3, freq=400_000)
The D11/D12 pads on the MKR header and the ESLOV connector’s SDA_EXT/SCL_EXT pins land on the same I²C 3 bus — see ESLOV connector above for the ESLOV pinout.
The Portenta H7 exposes eight 12‑bit ADC channels on A0–A7. All are 3.3 V referenced — read_u16 returns 0–65535 across 0–3.3 V at the pin:
DAC
A single 12‑bit DAC channel is exposed on DAC1 (A6 / D21) through pyb.DAC:
dac = DAC("DAC1")
Timer / channel
TIM8 CH3N
TIM1 CH1, TIM8 CH3N
TIM1 CH2, TIM8 CH2N
TIM3 CH2, TIM8 CH2
TIM3 CH1, TIM8 CH1
TIM1 CH1
TIM5 CH4
TIM1 CH3
D14
A7
TIM3 CH1
Several pins share timer channels:
  • TIM1 CH1 is on D1 and D6.
  • TIM1 CH2 is on D2 and D14.
  • TIM8 CH3N is on D0 and D1.
Pick one consumer per timer channel.
TIM1 is reserved for the camera master clock when the Vision Shield is initialised through csi — camera sensors — D1, D2, D6, D13, and D14 cannot be PWM‑driven while the camera is active.
Software bit‑banged buses
Thermal sensor (off‑board)
The fir driver only talks to the sensor over I²C 3 — wire the module to D12 (SCL) and D11 (SDA).
Timing
Virtual timers
Real‑time clock
machine.RTC keeps wall‑clock time across resets. The HD connector also exposes a COINCELL pad that can back the RTC from a CR2032 across power loss:
Boot and runtime info
Firmware update (DFU)
Filesystem and boot order
The Portenta H7 firmware mounts up to three filesystems on boot:
  • microSD card — if a Vision Shield is attached and a card is inserted, it is mounted at /sdcard.
When connected over USB, the boot filesystem (/sdcard if a card is present, otherwise /flash) also enumerates as a USB mass‑storage drive on the host, letting you edit boot.py, main.py, and any other files directly. Eject the drive before resetting the board so the host flushes its cached writes.
Storage sizes
The Portenta H7 ships with:
  • /sdcard — full size of whatever microSD card is inserted in a Vision Shield (when present), read/write.
Hard‑fault indicator
Software libraries
See the library index for the full list of modules — including which ones are unique to the Portenta H7 build.
