OpenMV Cam H7
The OpenMV Cam H7 is a Cortex‑M7 machine‑vision board built around the STMicroelectronics STM32H743 at 480 MHz with 1 MB of internal SRAM, 2 MB of internal flash, and a hardware JPEG codec. The board ships in two sensor revisions — the H7 with the OV7725 and the H7 R2 with the ON Semi MT9M114 — but the firmware, pinout, and Python API are identical.
OpenMV Cam H7
For full datasheet, photos, and dimensions see the OpenMV Cam H7 product page.
Highlights
  • STMicroelectronics STM32H743 Cortex‑M7 at 480 MHz (1027 DMIPS).
  • 1 MB internal SRAM — no external SDRAM.
  • 2 MB internal flash (no external QSPI flash).
  • OV7725 sensor (or MT9M114 on the H7 R2).
  • LiPo battery connector (no on‑board charger — supply a charged cell or run from VIN/USB).
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The H7 has no on‑board power management chip: there’s no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Connect a pre‑charged LiPo to the battery JST or run the board from USB / VIN.
OpenMV Cam H7 OV7725 Pinout
Pin reference
TIM4 CH3
frame‑sync pad — wired to the camera sensor only
The SYN pad on the header is connected directly to the camera sensor’s trigger / exposure line — it does not route to the MCU on the H7. Drive or read it externally; you can’t toggle it from MicroPython.
Power pins
A 3.7 V LiPo connector is also present, but the H7 does not have a battery charger — connect a pre‑charged cell, or supply VIN / USB instead.
When both USB and VIN/LiPo are present, the VIN/LiPo input wins — the on‑board power switch picks it over USB to power the board.
The battery connector and VIN are tied together on the H7. Do not plug in a LiPo and apply VIN at the same time — the two supplies will fight each other and can damage the battery, the board, or both.
You may power the H7 by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the H7 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins
The board exposes an SWD debug header (RST / SWCLK / SWDIO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters.
Onboard peripherals
The H7 has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor
The OV7725 (or MT9M114 on the H7 R2) is driven through the csi — camera sensors module:
microSD card
Bus reference
ADC and DAC
Timer / channel
TIM4 CH3
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8/P9 with pyb.Servo in the same script.
Software bit‑banged buses
Thermal sensor (off‑board)
Timing
Virtual timers
Real‑time clock
Boot and runtime info
USB bootloader window
Filesystem and boot order
The H7 firmware mounts up to three filesystems on boot:
Storage sizes
The H7 ships with:
  • /flash — 128 KB FAT filesystem, read/write.
  • /rom — 128 KB read-only memory-mapped ROMFS.
Hard‑fault indicator
Software libraries
See the library index for the full list of modules — including which ones are unique to the H7 build.
