OpenMV Cam M7
The OpenMV Cam M7 is a Cortex‑M7 machine‑vision board built around the STMicroelectronics STM32F765 at 216 MHz with 512 KB of internal SRAM and 2 MB of internal flash. The bundled OV7725 sensor captures 640×480 grayscale or 320×240 RGB565 frames at up to 150 FPS, and the 10‑pin user header exposes UART, I²C, SPI, CAN, ADC/DAC, and PWM peripherals.
OpenMV Cam M7
For full datasheet, photos, and dimensions see the OpenMV Cam M7 product page.
Highlights
  • STMicroelectronics STM32F765 Cortex‑M7 at 216 MHz.
  • 512 KB internal SRAM — no external SDRAM.
  • 2 MB internal flash (no external QSPI flash).
  • OV7725 sensor — 640×480 grayscale or 320×240 RGB565 at up to 150 FPS.
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total across the header), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
The M7 has no on‑board power management chip: there’s no battery connector, no battery charger, no battery‑voltage ADC, no charging / power‑status LEDs, and no hardware power button. Power the board from USB or VIN.
OpenMV Cam M7 OV7725 Pinout
Pin reference
SPI2 SCK / CAN2 TX
SPI2 NSS (CS) / CAN2 RX
TIM4 CH3
frame‑sync pad — wired to the camera sensor only
The SYN pad on the header is connected directly to the camera sensor’s trigger / exposure line — it does not route to the MCU on the M7. Drive or read it externally; you can’t toggle it from MicroPython.
Power pins
When both USB and VIN are present, whichever has the higher voltage powers the board — the on‑board diodes simply pick the stronger rail.
You may power the M7 by feeding 3.3 V directly into the 3.3V pin if you don’t want to go through the on‑board regulator. In that case, do not also apply VIN or USB power at the same time — back‑driving the regulator while another supply is active can permanently damage and destroy the camera.
Use the battery life estimator to model how long the M7 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins
The board exposes an SWD debug header (RST / SWCLK / SWDIO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters.
Onboard peripherals
The M7 has a single user RGB LED plus a pair of high‑power 850 nm IR LEDs:
Camera sensor
The OV7725 is driven through the csi — camera sensors module:
The sensor is soldered to the board on the M7 — it is not on a swappable module.
microSD card
Bus reference
CAN2
ADC and DAC
Timer / channel
TIM4 CH3
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8/P9 with pyb.Servo in the same script.
Software bit‑banged buses
Thermal sensor (off‑board)
Timing
Virtual timers
Real‑time clock
Boot and runtime info
USB bootloader window
Filesystem and boot order
The M7 firmware mounts up to three filesystems on boot:
Storage sizes
The M7 ships with:
  • /flash — 96 KB FAT filesystem, read/write.
  • /rom — 256 KB read-only memory-mapped ROMFS.
Hard‑fault indicator
Software libraries
See the library index for the full list of modules — including which ones are unique to the M7 build.
