OpenMV Pure Thermal
The OpenMV Pure Thermal is a full‑system thermal imaging board built around the STMicroelectronics STM32H743 (Cortex‑M7 @ 480 MHz) with 64 MB of external SDRAM, 32 MB of QSPI flash, a hardware JPEG codec, a 4.3” 800×480 IPS capacitive touchscreen, an HDMI output, a FLIR® Lepton® thermal socket, and a 5MP OV5640 visible‑light camera. It also packs Wi‑Fi, a microSD socket, a laser rangefinder, a buzzer, and a high‑power white illuminator.
OpenMV Pure Thermal
For full datasheet, photos, and dimensions see the OpenMV Pure Thermal product page.
Highlights
  • STMicroelectronics STM32H743XI Cortex‑M7 at 480 MHz.
  • 64 MB external SDRAM (~400 MB/s) plus 1 MB internal SRAM.
  • 2 MB internal flash + 32 MB external QSPI flash (~50 MB/s read).
  • OV5640 5MP rolling‑shutter visible‑light sensor.
  • FLIR® Lepton® socket — accepts any Lepton 1/2/2.5/3/3.5 module, radiometric or non‑radiometric, with per‑pixel temperature in degrees Celsius.
  • 4.3” 800×480 IPS capacitive touchscreen (24‑bit colour @ 60 Hz) with up to 5‑point gesture support.
  • HDMI output via TFP410 DVI serializer — up to 1280×720 @ 60 Hz.
  • Wi‑Fi via WINC1500; MJPEG over RTSP supported out of the box.
  • Full‑speed USB‑C (12 Mb/s, 900 mA current‑limited) — appears as VCP + USB mass storage to the host, also handles charging.
  • VL53L1CX laser rangefinder (up to ~4 m).
  • Buzzer with software‑controlled volume / frequency.
  • High‑power white LED illuminator in addition to the user RGB status LED.
  • LiPo battery connector with USB charging at 500 mA.
  • 10 I/O pins, 5 V tolerant with 3.3 V output, 25 mA per pin (120 mA total), interrupt‑capable. P6 is not 5 V tolerant when used in ADC or DAC mode.
  • ARM 10‑pin SWD connector for ST‑LINK / J‑Link debugging.
  • Qwiic connector for I²C peripherals.
The board has a slot on its bottom‑left edge for an optional ¼”–20 tripod nut. It isn’t fitted from the factory — solder one into the slot if you want to mount the board on a standard camera tripod.
OpenMV Pure Thermal pinout
Pin reference
digital I/O
frame‑sync pad — not connected
VIN
shield VIN pad — not connected
BUZZER
on‑board piezo buzzer (TIM2/PWM driven)
RGB status LED red channel (active low)
RGB status LED green channel (active low)
RGB status LED blue channel (active low)
LED_WHITE
high‑power white illuminator LED
The SYN and VIN pads on the shield/header have no electrical connection on the Pure Thermal — they’re there for header compatibility only. Power the board through USB‑C or the on‑board LiPo battery connector instead (see Power pins below). Note also that the VIN pad is silkscreened VBAT on the board (a labelling mistake) — the position is the standard OpenMV‑header VIN pin and is not connected either way.
Power pins
  • 3.3V — regulated 3.3 V rail. Up to 250 mA available for shields.
The Pure Thermal is powered through USB‑C or the on‑board LiPo battery connector. The USB‑C port is current‑limited to 900 mA total and also handles LiPo charging at 500 mA, so plugging a battery in alongside USB is supported.
The on‑board power button toggles the system rails on and off and works whether the board is being powered from USB or from the LiPo. Hold the button for a couple of seconds to switch state — a quick tap is ignored to prevent accidental shutdown.
Source selection follows two simple rules:
  • The battery only powers the board when its voltage is above 3 V. Below that threshold the on‑board PMIC disconnects the battery to protect it from over‑discharge.
  • When USB is present, USB powers the board and any attached LiPo charges in the background.
The LiPo connector also features reverse‑voltage protection, so plugging the battery in backwards won’t damage the board.
The board also routes the battery voltage and a battery current sense signal back to MCU ADC channels, but firmware support for either has not been added yet.
Recovery and debug pins
  • RESET — pull to GND to reset the board. The Pure Thermal also has a dedicated RESET button on the board that does the same thing.
  • BOOT0 — pull to 3.3 V while powering the board to enter the STM32 ROM bootloader (DFU mode). OpenMV IDE uses this mode to reflash the on‑board bootloader. A dedicated BOOT0 button on the board does the same thing — hold it while applying power.
The board exposes an SWD debug header (RST / SWCLK / SWDIO / SWO) next to the GPIO header, compatible with ST‑LINK and SEGGER J‑Link adapters. A separate ARM 10‑pin SWD connector is also fitted — it carries the same SWD signals (no full JTAG) but in the standard 0.05” 10‑pin form factor.
The SWO trace pin is shared with the on‑board FLIR® Lepton®’s SPI clock. SWO can’t be used at the same time as the Lepton — pick one or the other.
A third PURE Modules Debug connector is fitted on the board. It breaks out a handful of debug‑oriented signals (SWCLK, SWDIO, RST, SPI2_MISO, SPI2_MOSI, VBUS, 3.3 V, GND, and two GPIO pins) for attaching companion modules. The two GPIO pins on this connector are driven by an internal bit‑banged I²C bus rather than a hardware peripheral.
All three debug connectors (the inline SWD header, the ARM 10‑pin SWD connector, and the PURE Modules Debug connector) are referenced to 3.3 V — make sure your debug adapter is configured for 3.3 V logic before connecting.
Onboard peripherals
The Pure Thermal has three LEDs on the board:
  • White illuminator — driven through LED_WHITE. LED_WHITE is wired active high in hardware while the firmware treats every other on‑board LED as active low, so use low() / high() rather than on() / off() (which would invert the sense):
    light = LED("LED_WHITE")
  • Charging LED — driven directly by the on‑board power management hardware, no software control. It works whether the system rails are on or off (i.e. with the power button in either position).
    Colour
    Meaning
    Blue
    charging — see errata: may not turn off when charging completes
    Green
    charge complete — see errata: may not trigger reliably
    Red
    low battery (≤ 3.2 V, only when not actively charging)
Buzzer
The on‑board piezo buzzer is wired to a timer channel — drive it with machine.PWM for tones with software‑controlled frequency (pitch) and duty cycle (volume):
beep.deinit()
Camera sensor
The OV5640 is the primary CSI on the Pure Thermal — pass cid=csi.OV5640 to address it explicitly:
cam = csi.CSI(cid=csi.OV5640)
cam.reset(hard=True)
cam.framesize(csi.WVGA)
The OV5640 has an on-board JPEG compressor. Set csi.CSI.pixformat to csi.JPEG and the sensor delivers compressed frames straight to the cam over the camera bus, which makes high-resolution captures practical: csi.HD (1280×720), csi.FHD (1920×1080), and the full 5MP csi.WQXGA2 (2592×1944) all stream as JPEG. Tune the compression with csi.CSI.quality (0-100, higher = larger frames, more detail):
The OV5640 has a voice-coil-actuator autofocus lens. Trigger a single autofocus pass via csi.CSI.ioctl with csi.IOCTL_TRIGGER_AUTO_FOCUS — the sensor sweeps the focus motor once and locks on whatever’s in front of it:
Re-issue the ioctl any time the scene changes — the autofocus is one-shot, not continuous.
The OV5640’s STROBE output (used for synchronised flash / IR illumination) is wired up to the MCU on the Pure Thermal, but firmware support for it has not been added yet.
Thermal Camera Sensor
The FLIR® Lepton® socket appears as a second CSI on the same csi — camera sensors API. Pass cid=csi.LEPTON to address it, and skip the hardware reset:
lepton.reset(hard=False)
lepton.framesize(csi.QVGA)
    img = lepton.snapshot()
The Lepton’s VSYNC output (one pulse per thermal frame) is wired up to the MCU on the Pure Thermal, but firmware support for it has not been added yet.
Both CSIs can run side by side. The example below pulls a colour frame from the OV5640 and a thermal frame from the Lepton, then overlays the Lepton on top of the colour frame using an Ironbow palette and an alpha mask that fades to transparent at low intensity:
import math
for i in range(256):
csi0.reset(hard=True)
csi0.framesize(csi.WVGA)
csi1.reset(hard=False)
csi1.pixformat(csi.GRAYSCALE)
csi1.framesize(csi.QVGA)
    img0 = csi0.snapshot()
    img0.draw_image(
        img1, 0, 0,
        alpha_palette=alpha_pal,
        hint=image.BILINEAR,
Machine learning
ml — Machine Learning runs quantised TFLite models on the Cortex‑M7 with CMSIS‑NN kernels — fast enough for compact detectors at a few frames per second. Models on the read‑only /rom filesystem load directly from flash without copying to RAM. Here’s a 128×128 BlazeFace detector overlaying the detected face and its six landmarks on every frame from the visible‑light camera:
Laser rangefinder
The on‑board ST VL53L1CX time‑of‑flight ranger is wired to I²C bus 2. Use the frozen vl53l1x — VL53L1X ToF distance sensor driver driver to get distance readings up to ~4 m:
import vl53l1x
bus = I2C(2)
tof = vl53l1x.VL53L1X(bus)
LCD output
The 4.3” on‑board LCD is 800 × 480 (WVGA) and is driven through the display — display driver module’s RGB display interface — pass framesize=display.FWVGA to match its native resolution:
lcd.write(img)
The backlight is wired to a GPIO, so backlight() accepts True / False (or any 0–100 value, where 0 is off and anything non‑zero is on):
Touchscreen
The capacitive touch controller is the FT5X06; multi‑touch positions and gesture events are exposed through ft5x06 — Touch Screen Driver. Register a callback to react to touches and read the active points inside it:
import ft5x06
touch = ft5x06.FT5X06()
def on_touch(n):
        x = touch.get_point_x(i)
        y = touch.get_point_y(i)
        print("touch", i, "at", x, y)
    gesture = touch.get_gesture()
        print("gesture:", gesture)
HDMI output
The firmware also fans the LCD framebuffer out to the on‑board tfp410 — DVI/HDMI Controller HDMI serializer, so an external monitor mirrors what’s on the LCD. Instantiate tfp410.TFP410 to enable the HDMI output:
import tfp410
hdmi = tfp410.TFP410()
If you only want HDMI output and don’t care about the on‑board LCD, turn the backlight off and bump the framebuffer resolution above WVGA. The TFP410 supports up to 1280×720 @ 60 Hz, so for example:
The on‑board panel is fixed at 800×480, so anything above WVGA is only meaningful on the external HDMI monitor.
To know when an HDMI monitor has been plugged in or unplugged, register a hot‑plug callback on the TFP410. The callback fires with True on attach and False on detach:
def on_hotplug(connected):
You can also poll the connection state at any time with isconnected() (only when no callback is registered).
The HDMI port also carries the DDC (display data) and CEC (consumer electronics control) channels, exposed through the class DisplayData – Display Data class. Use it to read the attached monitor’s EDID block (so you can adapt to its native resolution / refresh rate) or to send/receive CEC frames for controlling other HDMI devices on the same wire:
print(len(edid), "byte EDID")
dd.send_frame(0, 1, b"\x04")
Wi‑Fi runs over a Microchip WINC1500 module, exposed through the class WINC – WiFi shield driver interface:
wlan = network.WINC()
Due to part shortages, some Pure Thermal units shipped without the WINC1500 module populated. If network.WINC raises an error or never connects, check the board for a missing Wi‑Fi module — the rest of the camera works exactly the same way without it.
microSD card
Bus reference
The on‑board Qwiic connector breaks out one of these I²C buses for plug‑and‑play modules. The Qwiic line is level‑shifted to 5 V through open‑drain transistors, so the bus is limited to standard mode (100 kHz) and fast mode (400 kHz) only — don’t try to run fast‑mode‑plus or higher rates through the Qwiic header.
The Qwiic connector outputs 5 V to power attached modules; it cannot be used to power the Pure Thermal itself — power the board through USB‑C or the LiPo battery connector instead.
ADC and DAC
Timer / channel
TIM4 is shared with pyb.Servo — instantiating a servo reconfigures the whole timer for 50 Hz operation, so don’t mix machine.PWM on P7/P8 with pyb.Servo in the same script.
Software bit‑banged buses
Thermal sensor (off‑board)
In addition to the on‑board FLIR Lepton, the firmware also includes the fir — thermal sensor driver (fir == far infrared) driver for externally wired I²C thermal imagers:
Timing
Virtual timers
Real‑time clock
If a LiPo battery is connected, the RTC keeps time even while the system rails are off (powered down via the on‑board power button). With only USB plugged in, pressing the power button cuts power to the RTC as well — so wall‑clock time will not survive a power cycle without a battery attached.
wdt = WDT(timeout=5_000)
Boot and runtime info
USB bootloader window
A running script can re‑enter the bootloader on demand by calling machine.bootloader().
Filesystem and boot order
The Pure Thermal firmware mounts up to three filesystems on boot:
  • boot.py is executed on every soft reset.
  • main.py is executed only on cold boot, immediately after boot.py.
Dropping a boot.py or main.py onto the SD card overrides the copy in flash without touching it.
When connected over USB, the boot filesystem (/sdcard if a card is present, otherwise /flash) also enumerates as a USB mass‑storage drive on the host. Eject the drive before resetting the camera so the host flushes its cached writes.
Files created or modified by code running on the OpenMV Cam will not show up on the host until the drive is re‑mounted. Use the SD card for any data the script writes back, and remount before reading those files from the host.
Storage sizes
The Pure Thermal ships with:
  • /flash — 24 MB FAT filesystem, read/write.
  • /rom — 8 MB read-only memory-mapped ROMFS, used to ship scripts and ML models that benefit from zero-copy mmap access.
Hard‑fault indicator
If the user RGB LED is rapidly cycling through all colours — fast enough that it tends to look like a twinkling white LED rather than distinct hues — the firmware has hit an unrecoverable hard fault. Reflash the firmware to recover.
Hardware errata
A handful of board‑level quirks are documented in the Pure Thermal hardware errata. Key items to be aware of:
  • Battery connector interference — components on the PCB sit directly under the LiPo battery connector, and the protruding wedge on the battery cable’s plug can catch on them when the cable is removed, sometimes pulling parts off the board. Trim the wedge off the cable plug with flush cutters before first use.
  • RTC stops while the board is powered off — the load capacitance on the 32 kHz crystal (Y2) is too high. Removing C96 and C97 (the pair flanking the crystal next to the STM32) lets the RTC keep running on backup power. Most boards ship with these caps already removed; if your RTC loses time when unplugged, check those positions. See GitHub issues #1536 and #1600 for the full thread.
  • Charging indicator LED stays blue — the charger may end its charge cycle anywhere between 4.15 V and 4.19 V without flipping the indicator from blue (charging) to green (charged). The battery is still fully charged in this case; trust a voltage measurement, not the LED.
  • Silkscreen mislabels VIN as VBAT — the pad in the standard OpenMV‑header VIN position is silkscreened VBAT on the Pure Thermal. The label is wrong, but it doesn’t matter in practice because the pad has no electrical connection either way.
Software libraries
See the library index for the full list of modules — including which ones are unique to the Pure Thermal build.
