OpenMV Cam RT1062
The OpenMV Cam RT1062 is a low‑power machine‑vision board built around the NXP i.MX RT1062 (Cortex‑M7 @ 600 MHz). The board pairs USB‑C high‑speed networking, Wi‑Fi/Bluetooth, and 10/100 Ethernet with an OV5640 5MP sensor on a removable carrier. The camera only draws ~30 µA from a LiPo battery in deep sleep, which makes it well suited to battery‑powered projects.
OpenMV Cam RT1062
For full datasheet, photos, and dimensions see the OpenMV Cam RT1062 product page.
Highlights
  • NXP i.MX RT1062 Cortex‑M7 at 600 MHz.
  • 32 MB external SDRAM (16‑bit @ 160 MHz, 320 MB/s) plus 1 MB internal SRAM and 16 MB QSPI flash (133 MHz 4‑bit SDR, 66 MB/s read); 4 KB EEPROM on R6+.
  • OV5640 5MP rolling‑shutter sensor.
  • Onboard IMU (12‑bit 3‑axis accelerometer, ±2/4/8 g).
  • High‑speed USB‑C (480 Mb/s, 1.5 A current limit), 10/100 Mb/s Ethernet (PoE‑capable via shield), Wi‑Fi a/b/g/n + Bluetooth 5.1 (chip antenna or U.FL option).
  • LiPo charger (500 mA on R6+, 100 mA on R4/R5), RTC with backup‑battery pads. Deep sleep draws ~30 µA on battery.
  • 14 I/O pins, all 3.3 V output / 3.3 V tolerant, 4 mA per pin, interrupt‑capable.
  • User RGB LED, user SW button, hardware power button (deep‑sleep / wake state machine), and a separate status LED for charging / USB / VIN power.
The RT1062’s I/O pins are not 5 V tolerant. Do not connect the device directly to a 5 V MCU like the Arduino Mega. Power the board through VIN only.
Pin reference
SPI1 MOSI / PWM2 B3
SPI1 MISO / CAN0 TX
SPI1 SCLK / PWM2 B3
SPI1 SS / CAN0 RX
I2C1 SCL / UART1 TX / PWM1 X2
I2C1 SDA / UART1 RX / PWM1 X3
PWM2 A0
PWM2 B0
PWM1 A3
PWM1 B3 / frame sync I/O
wakeup (active low, connect to GND to wake)
P12
RESET — pull to GND to reset the board (not a GPIO)
digital I/O
digital I/O
ON/OFF
header pad replicating the hardware power button (active low)
user button (active low)
ST
low on VIN power, high on USB power
CHG
active‑low; low while an attached LiPo battery is charging
PG
active‑low; low when VIN or USB power is present
The P10 frame‑sync line is a shared bus. It is wired to the MCU, the camera sensor’s trigger / exposure pin, and the user header all at once. Direction is application‑defined — the MCU, the sensor, or an external signal can drive it depending on how the sensor is configured. Make sure only one driver is active at a time.
ON/OFF and P11 are referenced to the always‑on RAW rail (not the switched 3.3 V rail), so they remain functional while the rest of the board is in deep sleep / low‑power mode. Both inputs are active low.
These pins go through level shifters so they can ride on the RAW rail. If you absolutely need 3.3 V‑direct GPIO behaviour on ON/OFF or P11 (for example to drive them from a 3.3 V MCU without going through the shifter), the board exposes pull‑up and 0‑ohm jumper pads that let you bypass the shifter. This is an advanced hardware rework — most users should leave it alone.
P13 and P14 are plain GPIO by default with no special function. The pads can optionally be re‑routed to other signals by reflowing the 0‑ohm resistor solder bridges on the back of the board:
  • P13 ↔ CHG status / JTAG TRSTB
  • P14 ↔ ST status / JTAG TDI
Most users won’t touch these jumpers — leave them at the GPIO default unless you specifically need power‑management read‑back or JTAG.
Power pins
  • 3.3V — regulated 3.3 V rail. Output only on the RT1062 — do not feed external power into this pin. Up to 1 A available for shields.
  • VIN — 5 V input. Powers the board and the on‑board LiPo charger.
  • RAW — input/output, always‑on (3.6 V – 5 V). Carries whichever source is active (VIN, USB, or attached battery), and can also be used as an input. You must drive RAW through a series diode when sourcing power into it — otherwise current will flow back into VIN/USB and damage the supply or the on‑board protection.
The on‑board power management chip automatically picks whichever of USB or VIN has the higher voltage to power the board and the battery charger. If a LiPo is attached it charges on the leftover headroom, and the controller falls back to the battery to keep the board running if VIN/USB sag or are unplugged.
The back of the board has solder pads for an external 3.3 V RTC backup battery. Wiring a coin cell to these pads keeps the RTC running while the rest of the board is unpowered.
Use the battery life estimator to model how long the RT1062 will run on a battery for a given active / deep-sleep duty cycle.
Ethernet pins
The RT1062 exposes the 10/100 Mb/s Ethernet PHY’s MDI pairs on dedicated pads next to the GPIO header. The MDI pins are not safe to wire straight to an RJ45 — Ethernet magnetics (an isolation transformer, either built into a magjack or on the shield) are required between the PHY and the cable. The OpenMV PoE shield includes them; if you’re rolling your own jack, use a magnetics‑ integrated RJ45 or an external transformer.
  • ETH_LED — link/activity LED. Active low when a link is up; flashes on traffic.
  • ETH_TXP / ETH_TXN — transmit pair.
  • ETH_RXP / ETH_RXN — receive pair.
The header also exposes four pads silkscreened Reserved. These are footprint‑compatible with the gigabit Ethernet pairs on the OpenMV N6 (DC P/N and DD P/N) so the same Ethernet / PoE shield can be plugged into either board. The RT1062’s PHY only does 10/100 Mb/s, so those four pads have no electrical connectivity — leave them unconnected.
Recovery and debug pins
  • SBL — pull to 3.3 V while powering the board to enter ROM bootloader (Serial Boot Loader) mode. OpenMV IDE uses this mode to reflash the on‑board bootloader.
A dedicated ARM 10‑pin SWD/JTAG header is fitted, compatible with ST‑LINK and SEGGER J‑Link adapters.
The RT1062 only exposes SWD debug through this connector by default. Full JTAG isn’t available out of the box.
Onboard peripherals
The RT1062 has two RGB LEDs:
  • Power LED — driven directly by the on‑board power management hardware, no software control. Use it to read what the supply is doing at a glance.
    While running:
    Channel
    Meaning
    Blue
    VIN is powering the board (off on USB)
    Green
    USB or VIN power present
    Red
    charging an attached LiPo battery
    In deep sleep all channels are off except Red, which still lights while a LiPo is charging.
Buttons
The RT1062 has two buttons:
  • SW — general‑purpose user button. Readable from code as a normal active‑low GPIO input:
    sw = Pin("SW", Pin.IN)
    print(sw.value())
  • Power button — driven by a dedicated power‑controller state machine on the RT1062 board, entirely in hardware. It is not exposed to user code; the controller decides what to do based on how long it’s held:
    • Hold for ~5 s while the board is running → state machine transitions to deep sleep.
    • Hold for ~1 s while the board is in deep sleep → state machine powers the system back up.
    Pulling the ON/OFF header pad low has the same effect as pressing the on‑board power button — useful for wiring an external switch or driving the line from another microcontroller.
Power status pins
Three active‑low status inputs from the on‑board power management chip:
  • PG — low when VIN or USB power is present. Always connected.
  • ST — low when the board is running on VIN, high when running on USB power. Not connected by default.
  • CHG — low while an attached LiPo battery is charging. Not connected by default.
Camera sensor
The OV5640 is driven through the csi — camera sensors module:
The OV5640 has an on-board JPEG compressor. Set csi.CSI.pixformat to csi.JPEG and the sensor delivers compressed frames straight to the cam over the camera bus, which makes high-resolution captures practical: csi.HD (1280×720), csi.FHD (1920×1080), and the full 5MP csi.WQXGA2 (2592×1944) all stream as JPEG. Tune the compression with csi.CSI.quality (0-100, higher = larger frames, more detail):
Machine learning
ml — Machine Learning runs quantised TFLite models on the Cortex‑M7 with CMSIS‑NN kernels — fast enough for compact detectors at a few frames per second. Models on the read‑only /rom filesystem load directly from flash without copying to RAM. Here’s a 128×128 BlazeFace detector overlaying the detected face and its six landmarks on every frame:
The RT1062 firmware does not wire the on‑board accelerometer up to the imu — imu sensor module. Talk to it directly over the internal I²C bus instead — the chip lives at address 0x15 and packs three signed 12‑bit acceleration channels plus an 8‑bit temperature byte starting at register 0x03:
ADDR     = 0x15
DATA_REG = 0x03
def s12(hi, lo):
    v = ((hi << 8) | lo) >> 4
bus = machine.I2C(2)
    temp_c = d[6] * 0.586 + 25.0
EEPROM
R6 boards and later include a generic 4 KB I²C EEPROM on the same internal bus as the accelerometer. (Earlier revisions don’t have one — calling these snippets on R4/R5 will time out on a missing I²C ack.) Use the standard machine.I2C readfrom_mem / writeto_mem API with a 16‑bit memory address:
EEPROM_SIZE = 4096
data = bytearray()
print(len(data), "bytes")
# Read it back
Both reads and writes must stay within a 32‑byte page. Split any larger transfer into one call per page, and add the ~5 ms write‑cycle delay between consecutive writes.
The on‑board CYW43‑family module is exposed via network — network configuration as a station interface. After connecting, ipconfig("addr4") returns the (ip, netmask) pair:
The same wireless module also exposes Bluetooth 5.1. Use aioble — Async BLE for asyncio‑friendly BLE — for example, advertise as a peripheral and wait for a central to connect:
Ethernet
When an RJ45 (with magnetics) is connected to the MDI pads, the 10/100 PHY appears as a LAN interface. DHCP runs automatically once the link comes up:
microSD card
Bus reference
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS and can sink/source up to 4 mA per pin.
SPI1
CAN1
CAN is not yet supported on this board in firmware v5.0.0.
can = CAN(1, 500_000)
The only user ADC pin is P6, which is full‑scale at ~3.3 V:
FlexPWM channel
PWM2 B3
PWM2 B3
PWM1 X2
PWM1 X3
PWM2 A0
PWM2 B0
PWM1 A3
PWM1 B3
Software bit‑banged buses
Thermal sensor (off‑board)
The fir driver only talks to the sensor over I²C 4 — wire the module to P4 (SCL) and P5 (SDA).
Timing
Virtual timers
Real‑time clock
machine.RTC keeps wall‑clock time across resets and (with the optional 3.3 V backup battery wired to the rear pads, see Power pins) across full power loss:
The RTC also runs through deep sleep, so you can use it as a wakeup source for machine.deepsleep().
Boot and runtime info
USB bootloader window
Filesystem and boot order
The RT1062 firmware mounts up to three filesystems on boot:
Storage sizes
The RT1062 ships with:
  • /flash — 4 MB FAT filesystem, read/write.
  • /rom — 8 MB read-only memory-mapped ROMFS, used to ship scripts and ML models that benefit from zero-copy mmap access.
Hard‑fault indicator
Software libraries
See the library index for the full list of modules — including which ones are unique to the RT1062 build.
