AE3 Battery Shield
The AE3 Battery Shield powers the OpenMV AE3 from a wide range of supplies — 5–36 V, a 3.7 V Li‑Po cell, or 1.8–5.5 V for 3 alkaline cells in series — and adds an SPI microSD card socket on P0–P3. All three power inputs land on JST terminals; the shield ships with a JST‑to‑pigtail adapter for the wide input and a JST‑to‑DC‑barrel‑jack adapter for the alkaline input.
AE3 Battery Shield
For full datasheet, photos, and ordering see the AE3 Battery Shield product page.
Highlights
  • HV PWR — 5–36 V, reverse‑voltage tolerant to −36 V. Powers the AE3 at 3.3 V (up to 600 mA).
  • BAT — 3.7 V single‑cell Li‑Po. Powers the AE3 at 3.0 V (up to 800 mA). The on‑board charger runs at a 100 mA charge current whenever 3.3 V is available on the shield — supplied by USB, HV PWR, or 3.3 V fed to the AE3 through its Qwiic connector. A 6.25 hr safety timer caps the supported battery capacity at 625 mAh.
  • LV PWR — 1.8–5.5 V for 3 alkaline cells in series, reverse‑voltage tolerant to −5.5 V. Powers the AE3 at 3.0 V (up to 800 mA).
  • microSD card socket wired to P0–P3 over SPI, with a software‑controlled power switch on P11.
The shield ships with a case that holds the AE3 firmly against the connector. Four corner M1.6 mounting holes let you bolt the shield down to an enclosure or fixture.
Use the battery life estimator to model how long the AE3 powered through this shield will run on a given battery for a given active / deep-sleep duty cycle.
Pin reference
microSD SPI MOSI
microSD SPI MISO
microSD SPI SCLK
microSD SPI CS
Charger power‑good (low when 3.3 V is present on the shield — USB, HV PWR, or Qwiic 3.3 V; charging only happens while this is low)
Charger charging (low while the Li‑Po is being charged)
Li‑Po battery voltage monitor — shield divides 0–5 V down to 0–1.8 V at the pin
LV input voltage monitor — shield divides 0–6 V down to 0–1.8 V at the pin
microSD power enable (drive high to power the card)
HV PWR in
5–36 V on a JST terminal (reverse‑voltage tolerant; JST‑to‑pigtail adapter included)
BAT in
3.7 V single‑cell Li‑Po on a JST terminal
LV PWR in
1.8–5.5 V on a JST terminal for 3 alkaline cells in series (reverse‑voltage tolerant; JST‑to‑DC‑barrel‑jack adapter included)
3.3V rail
Powers the AE3 and the shield’s on‑board electronics
GND rail
Common ground
Usage
Plug an AE3 onto the shield and connect any one of the three power inputs — the shield ORs the rails internally and feeds the AE3 from whichever source is present.
With only BAT connected (no USB, HV PWR, or Qwiic 3.3 V feeding the shield), the AE3 runs at 3.0 V off the Li‑Po, the charger is idle, and both status LEDs are off.
The microSD socket is exposed on the AE3’s SPI bus through machine.SPI and the standard sdcard driver. Drive P11 high to power the card, then wrap the block device in a VfsFat and mount it at /sdcard:
import sdcard
machine.Pin("P11", machine.Pin.OUT, value=1)  # enable card power
spi = machine.SPI(0)
cs  = machine.Pin("P3", machine.Pin.OUT, value=1)
sd  = sdcard.SDCard(spi, cs, baudrate=20_000_000)
print(os.listdir("/sdcard"))
Watch the charger status by reading its two status pins. P6 (power‑good) goes low as soon as 3.3 V is present on the shield — from USB, HV PWR, or 3.3 V fed back through the AE3’s Qwiic — which is also when the charger is allowed to run. P7 (charging) goes low while the Li‑Po is actually being charged. Both pins also drive on‑board status LEDs — P6 lights a green LED, P7 lights a red LED:
pg  = Pin("P6", Pin.IN, Pin.PULL_UP)
if not pg.value():
    print("Charger powered")
    if not chg.value():
        print("Battery charging")
Monitor the Li‑Po battery and LV input voltages on P8 and P9. The shield divides each supply down to the AE3’s 1.8 V ADC range, so scale the reading back up by the input’s full‑scale range:
lipo = ADC("P8")    # 0–5 V at the input
lv   = ADC("P9")    # 0–6 V at the input
    vlv  = lv.read_u16()  * 1.8 / 65535 * (6.0 / 1.8)
    print("Li‑Po:", vbat, "V  LV:", vlv, "V")
